PLEASE READ THIS....
xmad..????
The memory is in slots 1 & 2 as required and showing 16384GB.. 8192MB ea. Am I missing someting? I see the correct memory, and still question how the question is only 7.XX usable? Ram speed: 800.1KHz X2=DDR3 1600
10-10-10-30 is the correct timings..
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231489&Tpk=F3-12800CL10D unusual timings as compared to others..but accurate.
I do not see a problem. Scubacads123 can you please tell me how and why you believe only 7.XX is the only usable memory? Again if you have a program that shows the amount of memory being used, and it shows only 7.XX.. that will have nothing to do with your available 16GB. Although you have 16GB installed..that is the 'Total' usable available memory..not what is being 'currently'used. When memory is installed..it is not all used, at all times. Possiblt only 3.XXGB.. on a 32bit OS could be maxed out, on a constant basis. It is possible..unless you do CAD or another demanding program that you may 'never' use all the 16GB. That is not a bad thing. Head room is a good thing.
