Author Topic: MSI N630GT-MD4GD3 GeForce GT 630 4GB  (Read 2344 times)
pcdoc444
  • Neo
« on: 14-October-12, 14:32:23 »
Hi everyone
 I just joined up & i have a question about this video card  . Why is this card so much cheaper than most of the MSI video cards i found this card on Newegg for only $79.99 . This card has 4gigs of DDR3 ram ?
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: MSI N630GT-MD4GD3 GeForce GT 630 4GB
« Reply #1 on: 14-October-12, 14:38:25 »
cause its budget model, more VRAM doesn't mean fastern card
badboy2k
« Reply #2 on: 14-October-12, 15:04:14 »
the 630GT is a low end Nvidia card and having 4GB of ram is overkill on that type of card unless your trying to run 2 huge resolution monitors for genaral stuff like watching films ect!
the GPU isn't for gaming as its quite slow and the ram is only DDR3 not DDR5 so its very slow in comparison at fast repeating frames! its cheap because its a BASIC video card for low end systems and nothing more.
if you plan on gaming you would need a 650 GT or GTX or better for any meaningfull performace in games.
Cooler: corsair H100 cooler
pcdoc444
  • Neo
« Reply #3 on: 17-October-12, 00:25:59 »
How about a N640GT-MD2GD3 Its a MSI .Found it on Newegg for $99.99 would this do for some gaming
  • Lightning!
    • MSI Gaming
« Reply #4 on: 17-October-12, 00:31:13 »
Depends on what gaming means for you. Of course any current 3d game is out of reach with settings on high. It is a low-end card pretty much not meant for serious gaming. Expect minmum to sometimes medium settings in most games running fairly smooth. A gaming recommendation would cost a lot more.
MSI Z87 MPOWER MAX (MS-7815) Bios 1.8
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
MSI R9 290X LIGHTNING @ 1150/3000
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
pcdoc444
  • Neo
« Reply #5 on: 17-October-12, 00:42:24 »
Maybe this video card will do better
    GeForce GTX 550 Ti (Fermi)
    1GB GDDR5
    PCI Express 2.0 x16
  • Lightning!
    • MSI Gaming
« Reply #6 on: 17-October-12, 00:46:23 »
Better look into something like a GTX650 or a Radeon HD7770
Windows 8.1 Pro
pcdoc444
  • Neo
« Reply #7 on: 17-October-12, 10:33:35 »
Here is a good card what do you guys think
EVGA SuperClocked 02G-P4-2653-KR GeForce GTX 650 2GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP
  • Lightning!
    • MSI Gaming
« Reply #8 on: 17-October-12, 11:33:11 »
We can't advice or recommend buying a non MSI product
Windows 8.1 Pro
pcdoc444
  • Neo
« Reply #9 on: 17-October-12, 13:17:18 »
Sorry bout that how about this MSI
MSI N550GTX-Ti MD1GD5 V2 GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
 Would this one do for playing games like Max Payne 3  etc. I am trying to get all of our new computer parts correct before i order them
RemusM
  • Memory Expert
  • Marshall
    • Necromanthus
« Reply #10 on: 17-October-12, 13:28:06 »
That's a budget (mid-range) graphics card good for everything.
Including for playing games.
 :biggthumbsup:
Mainboard: HC85
Processor: Zilog Z80 3.5MHz
System RAM: 48KB
PSU: 5V/3A
OS: BASIC Spectrum Sinclair
note: NO overclocking!
  • Lightning!
    • MSI Gaming
« Reply #11 on: 17-October-12, 14:05:33 »
I'd go for a latest card: >>GTX 650<< or >>Radeon HD 7770<<
Windows 8.1 Pro
badboy2k
« Reply #12 on: 17-October-12, 14:31:53 »
i agree a MSI N650PE1GD5/OC NVIDIA GTX650 PE you should be able to get for the same price and its a newer card because the 550ti units are now getting rare the price is holding up so go for a 650 as they cost the same!
RemusM
  • Memory Expert
  • Marshall
    • Necromanthus
« Reply #13 on: 17-October-12, 15:01:58 »
Quote from: badboy2k
You are both right.
However ...
1) He wants a MSI N550GTX-Ti
2) GTX 550Ti is a little bit faster (in games) than GTX 650.
Reason: 192bit vs 128bit
 :beerchug:
Mainboard: HC85
System RAM: 48KB
PSU: 5V/3A
