Author Topic: How do I enable bluetooth on my MSI CR600 laptop  (Read 2281 times)
furreverdoggrooming
  • Neo
« on: 02-November-12, 01:24:31 »
I'm trying to pair my laptop to a set of bluetooth speakers.
I've opened the bluetooth assistant.  I click on the ENABLE button and get this message: "Please plug in the bluetooth device and click OK button."
I'm confused because isn't the point of having a bluetooth device that you AREN'T plugging it in?  I have no trouble pairing my phone or bluetooth speakers to other devices but my laptop doesn't seem to want to do this the easy way. HELP!
  • T9246ED, Бивша комета
  • Administrator
  • Online Online
    • MSI BIOS/EC-FW Mods
Re: How do I enable bluetooth on my MSI CR600 laptop
« Reply #1 on: 02-November-12, 01:29:13 »
have you activated the bluetooth ? if yes, does the led light which confirm that's activated?
furreverdoggrooming
  • Neo
« Reply #2 on: 02-November-12, 01:56:54 »
SVET: thanks for the quick reply.  Just to be on the safe side and make sure I'm not just being a bonehead: What are the steps to activating the bluetooth?  I thought clicking the "enable" button was the trick, but perhaps I'm wrong.
  • Administrator
  • Online Online
« Reply #3 on: 02-November-12, 02:08:13 »
look in your manual how to activate the bluetooth: http://www.msi.com/product/nb/CR600.html#/?div=Manual
furreverdoggrooming
  • Neo
« Reply #4 on: 02-November-12, 04:23:15 »
Tried looking it up in the manual, all the manual says is that the light will turn blue when it's activated, doesn't say HOW to activate.  If I could figure this out on my own I wouldn't be asking on here.  I thought this was a help forum.
  • Administrator
  • Online Online
« Reply #5 on: 02-November-12, 14:05:55 »
On page 2.9, point 3 from manual:
Quick Launch Buttons
Press the quick launch buttons to activate the specific applications or tools. With the help of
these quick launch buttons, users will be able to do work more efficiently.
Wireless
LAN/ Bluetooth
Š
Press this button repeatedly to turn the WLANor Bluetoothfunction on or off recurrently
  • Lightning!
    • event.msi.com/vga/lightning/
« Reply #6 on: 02-November-12, 16:42:05 »
For using Quick Launch Buttons install System Control Manager (SCM) for CR Series: http://www.msi.com/service/download/utility-14214.html
MSI Z87 MPOWER MAX (MS-7815) Bios 1.7B4
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
2*MSI GTX 780Ti GAMING 3G @ 1210/3500 (SLI)
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
jerrydoco
  • Neo
« Reply #7 on: 03-November-12, 18:24:41 »
Hi there, had a similar issue with my CR700 when I bought it...   The tech spec said it came all blue tooth enabled so I spent many an unhappy hour trying to enable/disable and then re-loading drivers etc.... only to find out that it actually does not come all enabled and you have to use a blue tooth dongle. I contacted MSI who sent me one. It is a small USB device that once you stick it in a spare USB slot on your pc and then the drivers are loaded.... hey presto. My Blue Tooth enabled immediately. Hope this helps.
furreverdoggrooming
  • Neo
« Reply #8 on: 04-November-12, 19:30:15 »
I think this is probably what I need as well.  I feel like I've tried everything else.  Thanks jerry, I'll give them a call.   :)
