Author Topic: Z77a G45 won't boot! (new system)  (Read 1795 times)
Dellorto
  • Neo
« on: 11-November-12, 11:12:27 »
Hi!
I just bought a new computer with the setup:
Intel i5 3570k
MSI GTX 660 ti Power Edition OC
Corsair Vengeance 1600MHz 2x4Gb
MSI Z77A G45
Fractal design Integra 650W
And the thing is that when I start the computer, it doesn't boot. On the screen it only shows "-" in the upper left corner and in the lower right corner it says "A2" and it then changes to say "B2". Then after 2 minutes that screen dissapears. After that a "-" starts flashing continually in the left section of the screen and nothing more happens.
But I tried with no harddrives in and only the OS boot cd and then it went through the same process but it did get into the installation of W7 but since there were no HDD:s in I couldn't install it.(Still skipping the boot phase)
I also tried with a HDD that had w7 installed but since that was configured for another setup it went through the same process but bluescreened immediately when the windows logo showed up.
I've tried to start with only one RAM and switch the RAM slots but still no progress.
I've tried to reset the CMOS too.
Checked all the cables.
POST doesn't show up either.
What might the problem be?
  • Lightning!
    • MSI Gaming
Re: Z77a G45 won't boot! (new system)
« Reply #1 on: 11-November-12, 14:59:41 »
Most likely the card has a GOP supporting vbios (necessary for full Win8 compatibility; http://msdn.microsoft.com/en-us/library/windows/hardware/hh997769.aspx) while your board is using an older bios not supporting GOP.
You need to flash the board to a GOP supporting bios: >> http://www.msi.com/service/download/bios-19847.html << using onboard vga (having the GTX660ti removed)
>>Use the MSI HQ Forum USB flasher<<
After flashing retry with GTX660ti.
If it won't even come up with onboard vga we need to dig deeper.
MSI Z97 MPOWER MAX AC (MS-7888) Bios 1.7 beta 2
Core i7 4770K (C0) @ 4300.54 MHz, 1.232V
2*8GB Corsair CMZ16GX3M2A2133C10 (1:8) 1066.9 MHz (DDR3-2133) @ 10-11-11-31-2T 1.5v
2*MSI GTX 780TI GAMING 3G (SLI)@ 1202/3500
250GB Samsung 840 EVO SSD + 512GB Crucial MX100 SSD + 128 GB Samsung 830 SSD
Corsair RM1000 +12V: 83.30A • +3.3V: 25A • +5V: 25A
Windows 8.1 Pro
Dellorto
  • Neo
« Reply #2 on: 11-November-12, 16:29:36 »
The onboard VGA doesn't give a signal to the screen, the light just stays yellow :(
  • Lightning!
    • MSI Gaming
« Reply #3 on: 11-November-12, 18:56:22 »
What light? Have you removed the GTX660? If so try reseating cpu and only use one stick of ram.
Windows 8.1 Pro
Dellorto
  • Neo
« Reply #4 on: 11-November-12, 19:48:04 »
The light on the screen. The light showing that the screen is sleeping.
  • Lightning!
    • MSI Gaming
« Reply #5 on: 11-November-12, 19:52:51 »
Aha, then go on:
Windows 8.1 Pro
Dellorto
  • Neo
« Reply #6 on: 11-November-12, 20:00:41 »
My local store said that it sounded like a motherboard problem since it skips though the "boot" screen and that I can't get picture with the onboard VGA :(
  • Lightning!
    • MSI Gaming
« Reply #7 on: 11-November-12, 20:03:07 »
Could also be the cpu. Please go on as I asked you to. If you are convinced of the store's info just rma the board.
Windows 8.1 Pro
Dellorto
  • Neo
« Reply #8 on: 11-November-12, 20:08:15 »
So shall I plug in the DVI cord to the motherboard then?
Dellorto
  • Neo
« Reply #9 on: 11-November-12, 20:09:02 »
Do I have to remove the VGA card fully or just unplug the double 6pins?
  • Lightning!
    • MSI Gaming
« Reply #10 on: 11-November-12, 20:48:14 »
Exactly.
Remove it.
Windows 8.1 Pro
