Author Topic: GT60 Win7 install  (Read 661 times)
tweidner
  • Winki
GT60 Win7 install
« on: 14-November-12, 23:36:11 »
Hi All,
I am new here and I will be a new owner of a GT60 one in a day or two... I have a quick Q.
Does the laptop come with a full version of Win7 or is it a pre installed version? Am I better off installing a full version?
I do have a copy of Win7 64bit Home Premium (that I use on my desktop), can I just use that disk with the win cdkey from the o/s that comes with the laptop to install the full version, or do I have to go out and purchase a new Win7?
Thanks for the help,
  • Lightning!
    • MSI Gaming
Re: GT60 Win7 install
« Reply #1 on: 15-November-12, 07:15:58 »
Pre installed, newly released GT60 come with Win8. Why should you be better off with installing another one? It is a normal Windows that has the same features like a Win7 Home Premium/Win 8 you buy seperately and install.
If you have a Win 7 DVD you should have a key anyway. None the less you don't get a separate key for the pre installed-OS so no. If you have no valid key for your Win7 on disc you'd have to buy another Windows if you don't want to use the pre-installed OS
MSI Z87 MPOWER MAX (MS-7815) Bios 1.8
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
MSI R9 290X LIGHTNING @ 1150/3000
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
