Author Topic: Video Engine Load  (Read 2054 times)
dude
  • Afterburner
Video Engine Load
« on: 13-March-13, 16:39:38 »
Attached is my system at idle. Even while gaming or whatever Video Engine Load stays at zero. What is Video Engine Load?
My Build
Board: MSI Z77A-G45 GAMING
Bios: Version H.20
VGA:GTX 760
PSU: Seasonic X650 Gold
Intel Core I5-3570K  oc@ 4.7GHz  LGA 1155 77W
MEM: 8GB DDR3 1600Mhz
HDD: M4 256 GB SSD WD 500Gb X2
OS: Windows 8.1 Pro 64bit
Antec Kuhler 920
badboy2k
Re: Video Engine Load
« Reply #1 on: 13-March-13, 22:43:38 »
let me guess you have a Nvidia based Graphics card and are running a version of the 300 or higher drivers?
that is a driver problem with all Nvidia 300 and above versions and is nothing to worry about!
Video Engine Load is a output signal monitor (how much information is being sent to the screen) but the latest drivers from Nvidia have seemingly left it out!
Cooler: corsair H100 cooler
dude
  • Afterburner
« Reply #2 on: 13-March-13, 22:47:59 »
Mark this thread solved, you are exactly right on my card and drivers. Thank you....google search gave me no answers.
My Build
Bios: Version H.20
VGA:GTX 760
Antec Kuhler 920
badboy2k
« Reply #3 on: 13-March-13, 23:04:21 »
your very welcome! every manufacturers ones do that under the latest drivers 300+ showing 0% on the Video Engine Load so its nothing to worry yourself over as its just a driver problem with a missing monitor program inside it for that section!
glad to have helped!
dude
  • Afterburner
« Reply #4 on: 14-March-13, 00:43:18 »
I'm going to guess those drivers are the same reason speccy no longer reads my GPU temps. Thanks again.
My Build
Bios: Version H.20
VGA:GTX 760
Antec Kuhler 920
Froggy Gremlin
  • Power Edition
  • Master Air OC'er
« Reply #5 on: 14-March-13, 01:01:03 »
Some idiot at nVidia that disabled the PCI-E 3.0 function for X79's in the driver package is also probably responsible for these 'side effects' that are now showing up in utility applications.
Life Can Be Very Fulfilling Without Win 8/8.1, SSD's, RAID, Current AMD GPU's, G.Skill RAM, Hackers, Crackers, & Crypto Mining!
IXOYE
