Author Topic: MPOWER z87 board shuts down right after boot  (Read 981 times)
Seekax
  • Neo
« on: 28-June-13, 21:01:27 »
Today i got my msi z87 mpower board, 4x4GB corsair vengeance pro 2133 cl9 ram and a 4770k. I am using my old AX650, which definitely works and the H60 i had.
I can't pass posting, i crash literally within a split second after i press the power button. both 8pins and the 24 pin are  plugged in properly, i removed all RAM besides one, which i moved around the slots as well, i removed the GPU, i reseated the h60 and reapplied the thermal paste, i reseated the cpu, i reseated all cables 4 times. it just doesn't work.
the first time it would run but didn't show an image, after about a minute it turned off completely, after reseating the cables it now crashes immediately. I am completely out of ideas, if you guys don't come up with anything good i will have to RMA :(
xmad
  • Salisbury MD
Re: MPOWER z87 board shuts down right after boot
« Reply #1 on: 28-June-13, 21:23:01 »
Please list all components: >>Posting Guide<<
Try to boot with a single stick of RAM in DIMM 2.
No hard drives or any other parts. Just ram, cpu, cooler, psu.
Prior to the test, re-seat the cpu and inspect the cpu socket pins with a  bight light and magnifying glass or hd zoom.
If it works with the single stick of ram, test each stick by itself in this manner. If they all work then try DIMM 2 & 4 then all of them again.
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: X79A-GD65 (8D)
Bios: 4.6
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 780TI 3GB in SLI
PSU: Corsair AX1200I
Cooler: Corsair 80I
SSD: Corsair Neutron GTX 240 GB SSD
Startech Raid Controller Card
HDD: 2x Seagate 500gb 7200 in Raid 0
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8.1 Pro in UEFI mode
Corsair Link
Corsair H-100I Cooler
Seekax
  • Neo
« Reply #2 on: 28-June-13, 21:25:31 »
There really isn't much more to the system atm, i unplugged nearly everything. no ssd, no hdds, no odd, not even peripherals besides a monitor. i use the palit geforce gtx 770 4gb jetstream, but i already used a different gpu to make sure that isn't the problem. i reseated the cpu twice, checked for bent pins etc, no problems. i will go through all of the ram, but i don't have high hopes for that either.
xmad
  • Salisbury MD
« Reply #3 on: 28-June-13, 21:36:22 »
I would also try with onboard vga if applicable and also another PSU or call corsair and make sure the PSU in particular you have works with the Z87 most of them however do.
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Seekax
  • Neo
« Reply #4 on: 28-June-13, 21:39:37 »
tried both, to no avail. i put my old ram in the board, 1333 team group elite 4gb, didn't work either. i think i will stop bothering and just RMA both the CPU and the mainboard. i am pretty sure on of them is causing the problems.
xmad
  • Salisbury MD
« Reply #5 on: 28-June-13, 21:45:19 »
I would also verify with Corsair as there are known issues with many pre- z87 mainboards. You can probably tell them the model and s/n and they will let you know.
After that you are most likely correct.
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Froggy Gremlin
  • Power Edition
« Reply #6 on: 28-June-13, 22:00:27 »
Could well be the universal industry wide PSU compatibility problem rearing it's head. Testing with the discrete graphics card removed and connecting via onboard port is recommended.
Life Is Very Good Without Any Win 8/8.1, SSD's, RAID, Current AMD GPU's, G.Skill RAM, Hackers, Crackers, & Crypto Mining!
0ut1awed
  • Neo
« Reply #7 on: 25-August-13, 01:09:02 »
Sorry for the thread revival but this post is the whole reason I joined this site.
The same thing is happening to my buddies setup that he just built...
MSI Z87 MPOWER Max
i5 4670k
8gbx2 of 1600mhz ddr3 PNY ram
Thermaltake 850w PSU Corsair gs700 PSU
So the story goes that he hooked up everything correctly and the machine turned on for a second then immediately off (exactly as described above). Being the new pc builder that he was, he stuck a PCI-E 6 pin cord into the remaining 8 pin cpu atx female port on the mobo (which I have never seen before. I guess it's for extreme voltage with ln2 cooling?). This caused it to fail while making his PSU smoke and die.
The PSU was for sure dead so we went out and purchased another one, the Corsair gs700w. When we hooked everything back up, the issue picked up right where it left off. The thing just turns on for not even a second then immediately powers down. We tried it simply with the 8 and 24 pin atx plugged up to the mobo, same issue. Removed the ram, same issue. Took out the cpu, same issue.
Sadly we don't have a way to test the cpu but I can let him borrow some of my memory to test.
I thought for sure that he had blown his mobo when originally describing it to me. The fact that it was doing this BEFORE the PSU failure makes me think that isn't it though.
« Last Edit: 25-August-13, 01:16:56 by 0ut1awed »
XFM
  • Marshall
  • PC troll
« Reply #8 on: 25-August-13, 02:33:22 »
"...hooked up everything correctly..."
 "...he stuck a PCI-E 6 pin cord into the remaining 8 pin cpu atx female port..."
 If that's true then it's not the same problem the OP had. Obviously if he did what is stated in the second statement then the first statement is not true.
 Anyway if you are asking for help/advice then start your own topic instead of resurrecting/hijacking this topic.
Z77A-GD65 (B3)/BIOS 10.5, i7 2700K
Zalman CNPS9900A LED HSF
Corsair Vengeance Pro 2x4GB CMY8GX3M2A1600C9A
W7 Home Premium/SP1 x64
Corsair TX650W +12V~52A (original version)
300GB WDVelociRaptor3000HLHX S-ATA 6.0
600GB WDVelociRaptor6000HLHX S-ATA 6.0
Lite-On CD/DVD S-ATA combo burner w/LightScribe
MSI 560 HAWK
DIYPC Solar-M1-G Black SECC case
HANNS-G HE245 monitor
0ut1awed
  • Neo
« Reply #9 on: 25-August-13, 03:31:35 »
I think you read into my post a little too much.
You are correct but BEFORE he plugged up the PCI-E to the extra CPU atx, the exact same issue was occurring. I might have questioned it if there was anything even minimally different after the new PSU, but it's the exact same. The old PSU obviously malfunctioned but the system itself seemed to show no signs of change.
I actually made the same mistake years ago with my intel core 2 duo. It seemed to fry my hdd but the rest of the system was fine. I guess it could just be chance on what does and doesn't die in the process. Point still is that his seems unchanged though.
« Last Edit: 25-August-13, 03:38:49 by 0ut1awed »
Sea Dog
  • Trinergy
  • Avast Ye Mateys!
« Reply #10 on: 25-August-13, 03:42:34 »
Recommend a new detailed thread of your own including all of the systems components. The MPower and the MPower Max are not the same board as the OP to begin with. They do not share the same UEFI/BIOS's, etc..
Recent Acquisitions: Z68A-GD80(G3), Z77A-GD80, X79A-GD65(8D) Played Around With A Z87-MPower Max, 4770k
P67A-GD65(B3)/i7 2700k/Zalman 9900/GTX 680's SLI/Corsair 2X4GB 2133/WD 600 V.Raptor & 640 Caviar Black/iHAS424/Lian-Li 60BPlus II/Samsung T220/Corsair HX850/W7 Ultimate 64 SP1 (Mothballed)
MSI X58 Pro-E/i7 950/Zalman 9900/ASUS 4870X2 Tri-Fan/Corsair 3X2GB PC3-12800/WD 300 V.Raptor/WD 640 Caviar Black/Lite-On iHAS422/Lian-Li 60BPlus II W/Samsung T220/Corsair TX850/W7 Ultimate 64 SP1
MSI P45 Platinum/E8600 (EO)/Zalman 9900/ASUS 4870/Corsair 2X1GB PC2-8500 @ 1067/2X WD 150 Raptor X's/Lite-On LH-20A1L/Lian Li 60BPlus II/Samsung 906BW/Thermaltake TP 850W/XP SP3
0ut1awed
  • Neo
« Reply #11 on: 25-August-13, 05:12:39 »
Okay, I'll do that then. Thanks to both of you!
