Author Topic: i gEFORCE 4 tI-4200  (Read 533 times)
fredvoll
i gEFORCE 4 tI-4200
« on: 25-August-02, 22:24:44 »
I while ago i bought a MSI K7T266 Pro motherboard.
That didn't have AGP Pro.
Since i had an old Voodo3-card that was not a problem.
But yeasterday i got a MSI Geforce4 Ti-4200 (MS-8870) graphics adapter. I have had nothing but problems with that thing.
Whichever driver i am using, after clean re-installs with win-98 (Oh yes i need to have a win-98 version), but my screen always went black either upon changing the display settings or entering windows.
Therefor i wonder if i NEED a AGP-Pro slot to deliever enough current to the graphics adapter, or if is my NoName 300 W PSU that doesn't deliever the goods.
I've heard that AGP-slots only deliever 25 W or something while a AGP Pro delievers 50 W with ease.
jeroen
Hi
« Reply #1 on: 25-August-02, 22:44:23 »
Try to set AGP comp. driving to manual and EA maybe this will help
Jeroen
Wonkanoby
  • Lightning
(No subject)
« Reply #2 on: 25-August-02, 23:58:30 »
if mr no name s not good for 200 watts combined
then is not going to work
some 300 watts can do it a lot cannot
read good articles for more info
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
fredvoll
(No subject)
« Reply #3 on: 26-August-02, 04:44:14 »
For the time being i'va found a temporary solution.
Got rid of the new TwinMos 512MB RAM-modules and put in the old 256 MB moulde i know works perfectly.
Then i used a Aopen 300 W PSU and i actually managed to insatll driverset NVidida 27.20 from a clean install.
So i think t probebly was the PSU , but the 300 W i have now doesn't deliever more than 10 W more, on the sheeth, but being more "Quality" an wieghing a whole lot more than my Elite 300 W i guess the AOpen produces at least 30+ W under load.
All though i still gonna check the 512MB Modeules one by one, and i'm gonna buy a more powerfull, 400-500 W Powersupply soon i at least has got the darn vard to install propery without blackscreens.
The more powerfull powersupply is to make shure that i have enough power when playing games mounting case-fans etc.
