Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 20:18:09 *
News: How do you flash your BIOS, please take part in our poll, thank you! >>How do you flash?<<
  Print
Author Topic: Raid Setup Guide 865/875 LSR/FIS2R Rev 1.04  (Read 19030 times)
vango44
King
Offline Offline
WWW
« on: 18 January 04, 23:57:25 »
On-Board Raid Setup MSI 865PE/875P
Revision History
Revision 1.0 (January 2004)
-   Original Raid Article
Revision 1.01 (February 2004)
-   Reformatted text and fixed spelling/grammar
Revision 1.02 (October 2004)
-   Added warnings to temporarily disconnect ALL drives including Zip drives during formatting Raid drives for WinXP.
Revision 1.03 (October 2005)
-   Reformatted text and added links to download Promise/Intel Raid floppies if user is missing them.
Revision1.04 (February 2006)
-   Minor BB reformatting
    • Intro
    • Equipment List For Tests
    • Description of Tests
    • Pre-Raid Setup Bios Tweaks
    • Raid Setup On Promise Controller
    • Raid Setup On Intel Controller
    • --->Intel- Migrating from single SATA to Full Raid Array
    Intro
    This guide is intended to help people configure their Bios and setup Windows for Raid using the Intel ICH5R controller  and the Promise FastTrak 378 controller. Although all the tests were done using Raid-0 the methods described should be virtually identical to setting up Raid-1 provided the user is aware of the fundamental differences between the two. It should be useful for anyone with an MSI 865PE/875P chipset on motherboards with LSR and FIS2R suffixes. Before continuing, please read the FAQ thread posted by Maesus and the Raid manual(s) that came with your motherboard. There's also some good info regarding Raid Here and Here and Here
    Keep in mind this guide is intended as a reference to help you. It is not a manual. I do not work for MSI and my equipment and time are limited. You will have different equipment and different versions of software.
    All the data below is based on tests that I ran and I tried to avoid using any theory that I did not test. If you feel I’ve missed something obvious or if you have something you feel should be added to make this guide clearer or simpler, please PM me with your thoughts. If you have a specific problem that this guide does not help you with, post a detailed thread in the forum on the main page.
      • MSI 875P FIS2R Motherboard
      • Bios 1.8
      • Enermax EG365P-VE (350w)  PSU
      • P4 2.6c CPU
      • Kingston KHX-3200A2 2x512MB Memory
      • Radeon 9800Pro AIW Video Card
      • WD 400JB 40GB/8MB cache IDE Hdd
      • 2-Seagate 80GB 7200.7 SATA Hdd's
      • Liteon 52x32x52 CDRW
      • Floppy Drive
      Tests
      Generally, tests were as follows:
      • Configure 2 SATA on Promise controller(serial3&4) as Raid0 and install WindowsXP Home SP1a on Raid
      • Configure 2 SATA on Promise controller(serial3&4) as Raid0 and add Raid to an existing WindowsXP installation on IDE drive(IDE1)
      • Configure 2 SATA on Intel Raid controller(serial1&2) as Raid0 and install WindowsXP Home SP1a on Raid
      • Configure 2 SATA on Intel Raid controller(serial1&2) as Raid0 and add Raid to an existing WindowsXP installation on IDE drive(IDE1)
      • Configure 1 SATA on Intel Raid controller(serial1) and install WindowsXP Home SP1a on it. Then add 2nd SATA on Intel Raid controller(serial2) and migrate to Raid0 using Intel Application Accelerator-Raid edition.
      IDE drive used in these tests was pre-installed with a fresh copy of WinXP Home SP1a using default settings and the following drivers all from MSI setup CD and Raid Floppy Disks that came with motherboard:
      • Intel INF files - version 1002
      • Gigabit Lan drivers - 7.0.37.0
      • SoundMax drivers - 5.12.1.3538
      • Catalyst 3.7 & Multimedia Center drivers from standard ATI CD came with video card.
      Pre-Raid BIOS Tweaks
      Before I continue, I'd like to point out a few changes from the defaults that I alway make to Bios before I attempt a WinXP install or hardware change. I can't guarantee that they all apply to you but none should make things worse. If anything differs from a setting that you feel is fixing another problem you're having, by all means leave at your prefferred setting. Anything related to performance and overclocking can be raised again AFTER the Raid is all setup and everything is running smoothly.
      Standard Cmos Features
      The only thing I change here is to enable "32bit transfer mode" whenever I connect new devices to the Intel IDE controller.
      Note: Devices attached to the Promise controller and the Intel Raid(when it is enabled) will NOT appear in the standard Cmos page
      Advanced Bios Features
      Everything on defaults is usually fine except I always change the following for WinXP:
      APIC ACPI SCI IRQ - Enabled
      Boot Device select is also on this page and you'll be changing it after all the hardware is setup; more later.
      Advanced Cipset Features
      Confirm that the memory timing "by SPD" is enabled
      PNP/PCI Configurations
      Clear NVRam option I always set to "YES" before the first boot after making hardware changes. I'm not sure how important this is but I understand that's what you're supposed to do. I believe it forces the motherboard to detect hardware changes. It reverts to "NO" after the reboot.
      PCI/IDE Busmaster set to "enabled" to speed things up outside of Windows.
      Integrated Peripherals (Before Raid for most flexibilty)
      Onboard Promise IDE - Disabled if you have nothing attached to IDE3 and Serial 3&4
      ON-Chip IDE Configuration:
      Native Mode (Supported by WinXP- Allows all devices connected to IDE 1&2 and Serial 1&2 to be detected)
      SATA Only or PATA Only (select the one that you boot XP with)
      Keep SATA Active - Yes (if option available)
      Keep PATA Active - Yes (if option available)
      PATA Channel selection - Both (if option available)
      Configure SATA as Raid - No (if option available)
      Leave other settings here at default
      Note: Some older Bios versions may appear different than above
      Frequency/Voltage Control
      Dynamic Overclocking - Disabled
      Performance Mode - Slow
      Dram Frequency - Auto
      Adjust CPU Bus - 201 (for "c" type cpu's)
      DDR Voltage - 2.65 (minimum for Dual-Channel Mem stability)
      AGP Voltage - 1.55
      Note: some features above may not appear with your Bios
      Note: performance & overclocking features can be increased again AFTER the Raid array has been setup and is stable with Windows.
      Raid On Promise Controller
         This procedure should work for anyone adding a Raid array to a system already having XP installed on another drive on the Intel controller or intending to install Windows XP on the new Raid array.
      Note: IDE 3 and Serial 3&4 connectors are controlled by the Promise controller.
      Note: It is possible to setup Raid arrays using 2 IDE drives on IDE3 or even 2 SATA & 2 IDE drives. I only tested 2 SATA drives on Serial 3&4 connectors.
      Note: It is possible to setup Raid 0+1 using 2 IDE drives on IDE3 and 2 SATA drives on Serial 3&4. See HERE for a related thread.
      Note: It is possible to setup SATA or IDE drives on the Promise controller as separate drives NOT using Raid but I did not test this. See your manual.
      - Attach the SATA drives to Serial 3&4 connectors and ensure that both power and data cables are securely connected. Most SATA drives do NOT need any changes to default jumper positions if any(check Hdd installation instructions).
      - Boot into Bios
      Integrated Peripherals:
      Set Onboard Promise IDE  - As Raid
      - Save and reboot computer
      - Use control-F keys during the boot(when prompted-goes by quickly) to enter the Promise Raid Bios.
      Note: You will only be able to enter the promise Bios if you have set the Promise controller to "As Raid" AND there are devices connected and detected by the Promise Bios.
      - Use the menus to configure the Raid for your preferences.
      Note: I can't say which settings you should use for creating the Raid. It depends on many things. Do some research.
      - After saving the Raid array, reboot to Bios.(you should see the configured array for a second or two during the post and it should be "functional")
      - In Advanced bios Features>>Boot Device Select:
      Set the order you prefer to boot from
      - If you already have XP installed on another drive and are just adding the Raid for an extra drive, Ensure that the list is still appropriate and includes your XP drive.
      - If you will be installing XP on the new Raid, make sure the new Raid array is in the boot list and any other hard drives are NOT.
      Note: Typically, I put the disk with XP first and use F11 key during post to boot from another device. This is not required though.
      - Save bios
      Important!: If you are installing XP on the new Raid array, you should now shutdown and either disconnect or disable any other drives connected until AFTER XP is installed. This includes USB/Zip drives.(See "Bugs" below).
      If Installing XP On The New Raid Array(others skip to below):
      - Boot from the Windows XP Setup CD and use F6 key when prompted(at the beginning).
      - Follow prompts to load the WinXP Promise FastTrack 376/378 Controller from the floppy that came with motherboard(If Required Download Floppy Here). There are a number of different choices on the floppy. PICK THE RIGHT ONE.
      Note: if using Win2K with the floppy, you can scroll down to get more driver options on this screen. It's not readily apparent on the screen.
      - Continue setup and Windows should now show you the new Raid array as a single drive available to install to. If it shows other drives that you have connected, re-read the "important" note above and the related section on "Bugs" below.
      - When XP setup makes its first re-boot, make sure the floppy has been removed or depending on your settings it may give you a scary moment. Yes I did this(tries to boot from floppy).
      - After XP is up and running, you can re-connect/re-enable any drives you disconnected earlier. If they have been formatted, they should show up immediately and be assigned letters after your CD/DVD drives.
      - You can also install the Promise Array Manager software(from MSI CD utilities tab or download) which adds some array management settings.
      If XP Already Installed On Another Drive(and you're just adding the Raid as an extra storage disk):
      - Boot into WindowsXP.
      - As Windows starts, it should detect a new Raid device and offer to install drivers.
      - Select Cancel. It will tell you that it was unable to install new device. If you want you can confirm the new device is present by checking Windows device Manager. It should show the new device with a yellow exclamation mark beside it since the drivers aren't installed yet.
      - Download the appropriate drivers or use the MSI CD that came with motherboard.
      Note: The MSI CD detects devices connected and shows available drivers/utilities depending on what it sees. You might not have seen the Promise drivers when using the CD before but now that you have a Raid array connected to it, the drivers will be availble from the MSI setup CD.
      - Install the drivers and re-boot
      - Device Manager should now show the Raid properly identified by XP.
      - If the Raid array was not previously formatted, you can now use Windows Disk Manager (Start > Run and type diskmgmt.msc) to Initialize and then format the Raid array.
      - The Raid array should now show in Windows Explorer with it's own drive letter.
      Bugs/Surprises
      - Trying to install WinXP on the Promise Raid while my IDE drive was connected to the Intel IDE connector resulted in Windows installing boot files to the IDE drive and the rest on the Raid drives. This was especially bad since I had another installation of XP on the IDE drive which was overwritten. The work-around was to disable the IDE drive until AFTER XP was setup on the Raid array.
      Update: There have been a few posts on the forum since I wrote this guide where people installing XP have had problems similar to the one above with USB/Zip drives connected so i am adding them to the list of drives to disconnect while installing XP.
      - When setting "Boot Device Select", if I selected "NO" for "boot from other devices", the motherboard would ignore my selection and still boot from other devices if the ones in the list were unusable.
      - Be gentle with SATA connectors on the motherboard. They can stand firm downward pressure but not a lot of side-to-side pressure.
      Raid On Intel Controller
      This procedure should work for anyone adding 2 SATA hard drives for a Raid array on a system already having XP installed on another drive or intending to install XP on the new Raid array.
      Note: IDE 1&2 and Serial 1&2 connectors are controlled by the Intel ICH5R controller. Only Serial 1&2 can be configured for Raid arrays.
      You can also install a single SATA drive and configure the system for Raid BEFORE installing XP on this drive if you intend to add another SATA drive later to form a Raid array. This method was also tested. I will refer to this for the rest of the thread as the Raid-Ready Method.
      Note: If you install WinXP on a single SATA drive without enabling Raid and loading Raid drivers, you will NOT be able to migrate the XP disk to a Raid array at a later date. Reinstalling XP would be required.
      Note: There is no performance advantage to having a single drive with Raid enabled. But doing so makes the disk Raid-ready and XP reinstall unnecessary.
      - Attach the SATA drive(s) to Serial 1&2 connectors and ensure that both power and data cables are securely connected. Most SATA drives do NOT need any changes to default jumper positions if any(check Hdd installation instructions).
      - Boot into Bios
      - In "Integrated Peripherals>>On-Chip IDE Configuration" set:
      SATA Only (Even if you will be booting XP from a PATA drive)
      Configure SATA as Raid - Yes
      Note: Some older Bios versions may appear different than above.
      - Save Bios and reboot computer
      - Use control-I keys during post(when prompted-goes by quickly) to enter the Intel Raid Bios Utility.
      Note: If you are using the single SATA Raid-Ready Method, you can skip the steps involving the Intel Raid utility. Go to the step for setting Boot device select in main Bios.
      Note: You will only be able to enter the Intel Raid Bios if you have set the "Configure SATA as Raid" option to "YES"  AND there are devices connected and detected by the Intel Raid Bios.
      Note: I can't say which settings you should use for creating the Raid. It depends on many things. The Intel utility does describe the different options well though.
      Set the order you prefer to boot from;
      If you will be installing XP on the new Raid or using Raid-Ready Method, make sure the new Raid array or raid-ready drive is in the boot list and any other hard drives are NOT.
      - Save bios
      Important!: If you are installing XP on the new Raid array or using the Raid-Ready Method, you should now shutdown and either disconnect or disable any other hard drives connected until AFTER XP is installed. This includes Zip/USB drives. (See "Bugs" below).
      If Installing XP On The New Raid Array Or Using Raid-Ready Method(others skip to below):
      - Follow prompts to load the IAA Raid Driver for ICH5R (If Required Download Floppy Here) from the floppy that came with motherboard.  I only had 1 driver to choose from on my floppy but if you have more, CHOOSE THE RIGHT ONE!
      - Continue and Windows Setup should now show you the new Raid array or Raid Ready drive as a single drive available to install to. If it shows other drives that you have connected, re-read the "important" note above and the related section on "Bugs" below.
      - After XP is up and running and INF files and other important drivers installed, you can re-connect/re-enable any hard drives you disconnected earlier. If they have been formatted, they should show up immediately and be assigned letters after your CD/DVD drives.
      - You can also install the Intel IAA-Raid Program(from MSI CD utilities tab or download) which gives some info and adds the array management settings(Not many. Just the enable/disable cache setting and the migrate to raid option).
      - As Windows starts, it should detect a new Raid device and offer to install drivers. Select Cancel. It will tell you that it was unable to install new device. If you want you can confirm the new device is present by checking Windows device Manager. It should show the new device with a yellow exclamation mark beside it since the drivers aren't installed yet.
      Note: The MSI CD detects devices connected and shows available drivers/utilities depending on what it sees. You might not have seen the IAA Raid drivers when using the CD before but now that you have a Raid array connected to it, the drivers will be availble from the MSI setup CD.
      Note: If the IAA Raid program detects that the Raid controller is not enabled or no device is present, it will NOT allow you to install the drivers/utility.
      - Using Windows Device Manager should now show the Raid device properly with no problems.
      - If the Raid array has not been formatted, you can now use Windows Disk Manager (Start > Run and type diskmgmt.msc) to Initialize and then format the Raid array.
      - The new drive should now appear in Windows Explorer with it's own drive letter.
      Bugs/Surprises
      - Trying to install WinXP on the Promise Raid while my IDE drive was connected to the Intel IDE connector resulted in Windows installing boot files to the IDE drive and the rest on the Raid drives. This was especially bad since I had another installation of XP on the IDE drive which was overwritten. The work-around was to disable the IDE drive until AFTER XP was setup on the Raid array. It is safe to assume this can occur with the Intel controller as well since I believe the problem occurs because of how WinXP setup addresses the hard drives.
      Migrating XP System Disk To Raid On Raid-Ready System
      This part describes how to use the Intel Application Accelerator-Raid edition to migrate an existing WinXP system disk (1-SATA) to a 2-SATA Raid array.
      This procedure is actually very well documented in the last part of the Intel SATA Raid manual that ships with the motherboard but I thought I’d add it to make this thread more complete.
      Please note that to use this feature of the Intel raid software the disk you are migrating FROM must have been made Raid-Ready as described above. Basically, this means that Raid should have been enabled in the Bios and the drivers installed from floppy during the WinXP install.
      Note: I tested this by migrating to a Raid0 array but Raid1 should work also if the latest Bios and version of Intel-Raid application used.
      - Open the Intel Application Accelerator Raid utility.
      - With the “Raid” tab window open, right-click on “Raid volume” and select “Create from Existing Disk” as seen below.
      - Follow the next several steps to choose the type of Raid array and the strip size.
      Note: 64kb strip size is good for general purpose and 128kb best for most desktops and work stations according to Intel. Anything smaller is for specialized purposes. You should research this a little because you can’t change it after easily.
      - After configuring the array for your preferences, you will face a couple of warnings telling you that “All data will be deleted from the Raid-controlled drive(s) and is unrecoverable” and ask if you want to continue. Obviously all data(if any) on the new drive you’re adding will be lost but the OS and other data on the disk you’re migrating FROM will be striped to the new array and will remain intact.
      Note: Any complex disk procedure such as this carries the risk of losing data. A backup of the disk is important BEFORE beginning the migration process. Don't say I didn't warn you.
      - The migration process can take a long time. You should see the window below during the operation.
      Note: With just a default WinXP installation, migrating to 2-80Gb drives took about an hour for me.
      - After the migration is complete, you will be prompted to re-boot to complete the process.
      - During the reboot, as the Intel Bios comes up for a couple of seconds(don’t blink) you will see the 2 drives configured as an array and they will be listed as “functional”.
      - After the reboot, you should have a fully functional Raid array with 2 SATA drives and all data from the single drive will have been striped or mirrored into the second one. Check Windows Disk manager(Start > Run and type diskmgmt.msc) to see the status of the new drive. See bugs/surprises below.
      Bugs/Surprises
      The only problem I had with this test came in the form of a small surprise after everything was completed and the computer had rebooted. Although the Intel Application Accelerator showed everything functioning normally, Windows explorer showed my Raid drive as 74Gb in size instead of the 150Gb or so that I expected. After checking Windows disk Manager (Start > Run and type diskmgmt.msc), I found that the missing GB’s were in fact there but were unformatted. Unfortunately, Disk Manager does not seem to allow merging or extending partitions so I ended up using Partition Magic 8 to format the empty space and merge it with the rest of the partition. This seemed to work fine and I ended up with a single 150Gb drive showing up in Windows Explorer. I also briefly tested the performance to confirm that it was operating as a Raid array.
      I know there is a utility for Win2K called DiskPart.exe that is run from command console to extend NTFS partitions but if anyone knows of an easier way or a FREE utility that will format/merge NTFS partitions that they have confirmed works, please PM me so that I can include a reference to it here.
      All the data above is based on tests that I ran and I tried to avoid using any theory that I did not test. If you feel I’ve missed something obvious or if you have something you feel should be added to make this guide clearer or simpler, please PM me with your thoughts. If you have a specific problem that this guide does not help you with, post a detailed thread in the forum on the main page.
      Vango44
      « Last Edit: 21 November 06, 17:59:10 by vango44 » Logged
      MSI Neo FIS2R 875P Bios 1.8
      Enermax 350W
      P4 2.6c HT-Enabled
      Kingston 2x512MB KHX3200AK2
      ATI Radeon 9800Pro AIW
      WD 36GB Raptor  Cool (WinXP Home)
      Liteon 52x32x52
      2x Seagate 7200.7 80GB/8MB SATA
      Promise Raid0 (Win2K SP4)
      Standard Settings -  FSB 218l/Fast Mem 2.5-3-2-6@2.65v
      Max OC:
      FSB/Mem 1:1 235Mhz Ram 2.5-3-3-6@2.85v UltraTurbo
      Sandra Mem Bandwidth- 5425 avg
      .......P4 Board FAQ.......Raid Setup Guide
      REILLY875
      Forum God
      Offline Offline
      WWW
      « Reply #1 on: 19 January 04, 00:00:29 »
      Great POST!..Maybe they will Put this Up Top..............Sean REILLY875
      PRIMARY SYSTEM
      ALIENWARE- AREA-51-ALX
       EVGA-680i (ALIENWARE-REV.-D)
       INTEL ENTREME-9650-45NM QUAD CORE (12MB L2) 3.0GHZ @4.0GH
          (Requires The "P32" BIOS In Order To Run ANY PENRYN CPU)
       OEM THEMOCOOL-PANAFLOW HIGH PERFORMANCE LIQUID COOLING
       2 X 1GB PATRIOT LL6400
       2 X EVGA 8800(BLACK-PEARL) LIQUID COOLED-ULTRAS 650MHZ/1100MHZ MEM.
       1 X AGEIA PCI-X 100 PHYS-X 128MB CARD
       2 X WD 160GB RAPTORS IN RAID-0
       2 X WD 1 TB 7200-RPM IN RAID-1
        CREATIVE X-FI-HENDRIXS
       1 LG 4 X WRITE BLU-RAY (Reads HDVD)
       1 LG DVD BURNER W/LITESCRIBE
       1 PCPAC 1KW POWESUPPLY
        "CRAPPY" WINDOWS VISTA> "VISTAKE"!!!!
        3DMARK-2006=18,640
      Danny
      Guest
      « Reply #2 on: 19 January 04, 00:06:54 »
      Excellent job  biggthumbsup
      damon69
      Double Ace
      Offline Offline
      WWW
      « Reply #3 on: 19 January 04, 05:38:15 »
      Thank you vango44, your guide is clear, and complete. It makes me wonder why the people who do the manuals for this kind of thing cannot do the same? I am looking forward to the next part of the guide, I could really use your expertise. Anyway, great job man!
                            damon69
      MSI875 WinXP Pro SP1
      P4 3.0@3.7 253 FSB @5:4 UT 1.6v
      XMS 3500C2 2-2-2-5 3.0v
      SP-94 w/ 92mm Tornado (28c/40c)
      Thermaltake Xaser3 17c-26c
      7x80mm X-Blasters
      Truecontrol 550, APC 500ES UPS
      BFG FX5900 Ultra 1.6v 520/930
      2xWD36GB ICH5R RAID0, 2xWD200GB
      DRU-510A, Santa Cruz, MX700 Duo
      ABIT IC7MAX3 WinXP Pro SP1
      P4 3.0@3.7 247 FSB @1:1 T 1.6v
      XMS 3500C2 2-2-2-5 3.2v
      TC 550, APC 500ES UPS
      BFG FX5099 Ultra 1.6v 520/930
      2x36GB RAPTORS ICH5R RAID0
      2xWD200GB, 510A, Santa Cruz, MX700 Duo
      aggie02
      Triple Ace
      Offline Offline
      « Reply #4 on: 19 January 04, 08:06:28 »
      Wow, I don't even have a RAID board and after reading this post I want one. Great Job vango44!   biggthumbsup
      MSI 865PE Neo2LS bios 1.3
      Pentium 4 2.4C
      FSB=200 and AGP/PCI=66/33 via ClockGen
      Antec TRUE480 PSU (+5V=38A, +3.3V=30A, +12V=22A)
      512 MB (2x256) Kingston HyperX PC3200 KHX3200K2/512 @ 2-2-2-5 ULTRA TURBO/AUTO!! @ 2.7V!
      80GB Western Digital 7200rpm 8mb cache
      ASUS Radeon 9600XT 128mb biggrin
      HITACHI 17" Flat Panel
      PC Chips EZ-TV tuner (pci)
      Sadra Mem Bench: 5017/4998
      Maesus
      Error55: Rank engine broke!
      Offline Offline
      in Penang, Malaysia
      « Reply #5 on: 19 January 04, 17:30:07 »
      GREAT THREAD!!!
      Will make a link to here from the FAQ!
      Please read the ==>MOAN Guide<==
      Maesus
      My PC:
      Now using : IBM Thinkpad T60p
      Core 2 Duo recipe
      E6600 2.66Ghz with GB Rocket Cooler Pro : MSI 975X Platinum PUE BIOS 7.6 : DDR2-667 2x1GB + DDR2-800 2x1GB : MSI 8800 Ultra : 80GB WD Caviar SE : Maxtor 250GB SATA : LiteOn LH-20A1S DVD writer + Samsung SH-W162C DVD writer : MSI Theater 550 Pro : LOGITECH Z-680 : DELL E228WFP 22" LCD : PowerLogic 500W PSU with +12V1&+12V2 @ 32A total
      mcochris
      Forum Ace
      Offline Offline
      « Reply #6 on: 20 January 04, 01:03:56 »
      Great work vango44!
      Here are some RAID performance statistics I gathered while testing RAID on my system.  The testing software was Winbench 99.  The hard drives tested were new Seagate ST380013AS drives, formatted NTFS.  Winbench was running on a third drive that is not included in the tests and should not affect the results.
      The drives were reformatted between tests and chkdsk'ed to try and keep things "apples to apples".
      No hardware or software changes other than the RAID setup/connections were made between tests.
      Higher numbers mean better performance.
      I also ran the same tests on the newish WD Raptor 10K drives:
      I couldn't stand all the noise  redface the Raptors made, so I returned them.
      On my motherboard:
      SATA 1 & 2 = Intel RAID controller
      SATA 3 & 4 = Promise RAID controller
      If the test title does not include "RAID", then it was a single drive test.
      Unfortunately, I don't have a spreadsheet version of the above stats.  Otherwise I'd create nice bar charts for us and it's would be easier to deduce performance.
      Perhaps some kind reader will OCR the pictures, put them into Excel, and make some nice bar charts for us?
      Hope the info helps.
      « Last Edit: 20 January 04, 01:29:23 by mcochris » Logged
      • Gigacase YY-5601 chassis, AcoustiPack
      • 865 Neo2-FIS2R v1, BIOS 1.9
      • P4c 2.4, DOT=Colonel, PAT=Fast
      • Zalman CNPS7000-Cu sink, CoolingAfter, SpeedFan
      • MSI FX5600-VTDR128 VGA, fan/sink replaced with Zalman ZM80A-HP
      • NB heatsink replaced with Swiftech MCX159-P
      • 1G Corsair TwinX DDR 500 @ 2.7V, SPD=3-4-4-8
      • Seasonic Super Tornado 400W (3.3@28A, 5@30A, 12V@22A, 3.3&5@46A)
      • 2 120mm fans on Zalman fan controllers
      • 2 Seagate 80G SATA on Promise RAID 0
      • Sony DW-U12A CD/DVD R/W
      • Viewsonic 19" LCD
      • Windows XP Home
      [/COLOR]
      Danny
      Guest
      « Reply #7 on: 21 January 04, 02:12:45 »
      READ BEFORE POSTING A REPLY
      [/SIZE]
      If you have a question on raid, please don't post it in this thread - start a new topic.
      If you have something to contribute, as mcochris did, that is great.
      If you see any errors, PM vango44, and I am sure he will fix them.
      I would like to see this thread stay as clean as possible so people looking for information on raid can find it without wading through a long thread.
      Thanks
      vango44
      King
      Offline Offline
      WWW
      « Reply #8 on: 31 October 05, 22:02:11 »
      Incorporated in main article above.
      Mods, delete this post.
      « Last Edit: 04 February 06, 18:22:11 by vango44 » Logged
      Enermax 350W
      P4 2.6c HT-Enabled
      Liteon 52x32x52
      Max OC:
      Giannis
      Newbie
      Offline Offline
      « Reply #9 on: 17 December 05, 22:42:12 »
      This is my first post in this forum and it is just a reply but
      at once i want to say a big thanks to DANNY because of this topic information i solved a problem what i had with raid format in a 865PE Neo 2 mother "Intel raid controler" and
      in the second i want to inform all of you that what he said Danny  i did it with windows 2000 and everything goes perfect. That means with windows 2000 you can follow everything what you did with windows xp.
      Once more Thanks
      db_
      Offline Offline
      « Reply #10 on: 07 January 06, 20:59:51 »
      i got a hitachi 250gb to add as my primary raid drive and use my 160gb as my secondary.  question though.  when i add the second drive (i plan to do the single sata raid method then use the intel util), can i copy all of my data from my older drive to my new one before it formats the old one and all is lost?
      P4 2.8c w/ Zalman CNPS7000-Cu cooler
      Enermax Liberty 500W 12V@22a
      865PE Neo2 PFISR
      Mushkin DDR433 2-3-3-6 in dual channel mode (memtest them frequently and they're rock solid)
      eVGA 6800GT@stock core and memory w/ Zalman VF700-Cu cooler
      4 80mm Antec Red LED system fans (12v molex)
      Creative Audigy 2
      2 250GB SATA drives
      1 Plextor 708a DVD writer
      superkev6969
      Forum Ace
      Offline Offline
      « Reply #11 on: 09 May 06, 17:42:39 »
      Hi
      Interesting artical
      Are all raid contollers non-interchangable.
      Am I right in saying that if your motherboard expires with a raid O (striped) sstem that unless yur replace it with an identical MB you lose all your data.
      Kev
      Xplorer4x4
      Newbie
      Offline Offline
      « Reply #12 on: 04 December 09, 05:55:28 »
      Thanks for this guide. I have a P55-GD65 so obviously this wasnt precise but it got the job done.
        Print
      Jump to:
      Page created in 0.354 seconds with 18 queries.
