Author Topic: CPU fan speed control  (Read 960 times)
ahdofu
  • Military Class
« on: 20-January-04, 21:02:32 »
I have a question about Core center & fan speed. I don't know whether its the motherboard or Core center that monitors the cpu fan speed but according to Core Center whenever I boot my machine up. the CPU fan speed runs at about 3000 RPM. Now if I run an application that gets the CPU temp up, the CPU fan speeds up to something like 3700 RPM. What I don't understand is after the CPU temp drops to where it was, the CPU fan speed stays at its high speed level. Now if I stop Core center and launch it again, the CPU fan gets to run at its lower speed. Any comments from the experienced users?
Thanks in advance.
P4 3.2C (HT enabled, 800Mhz)
865PE Neo2-FIS2R (MS 6728, version 100, BIOS 1.9)
(2x 1GB) OCZ PC3200 (MAT Turbo, by SPD @ 2.8V)
ATI Radeon 9800pro
Turtle Beach Santa Cruz SC
2 X WD 80GB SATA drives on ICH5R, Raid 1 (Boot drive)
Samsung SD-816B DVD ROM
NEC DVD-RW ND-3520A
Acer AL2216W LCD
Windows XP + SP3 + Latest Drivers
Enermax 460W PS (EG465AX-VE, +3.3/35A, +5/35A, +12/33A, max +5/+3.3 @ 200W)
Djfuzz
(No subject)
« Reply #1 on: 20-January-04, 21:31:09 »
Well if i were you i would search the forum first before posting questions which have already been answered  :-D) tip: Try to search for speedfan (by Danny :biggthumbsup:) 8-))
Good Luck :biggthumbsup:
Danny
(No subject)
« Reply #2 on: 20-January-04, 23:30:57 »
See signature.
