Del UK
« on: 16 March 04, 22:45:32 » |
Hi, I hope this of help, as I have done alot of testing and finally.... Please check that the 20 or 24 pin atx connection, is properly LOCKED and in place.  I did a test of NOT locking it, (As I have tried to acheive a no Boot.....). After 30 mins of use, the system crashed. Rebooted and fine for another 10mins...  After trying to restart, all 4 d-bracket lights were GREEN..... power off and power up nothing just no:2led very bright green and no:4 led dim green. I was lucky, I was testing.....  cost me a modem but could have cost me everything. Del
« Last Edit: 04 April 04, 00:01:27 by Del UK »
Main system MSI P45 FR3 V1, E8400 with Arctic Cooling Alpine 7, Corsair VX 550, ATI 5770, 8Gb DDR2 Corsair XMS2, onboard NIC/Audio, WD 160 & 500 RE drives, Opti DVD, Enermax batwing 120's. Win 7 64bit 2nd System Duo2 E6600 @ 3.2, Thermalright SI-128 with Enermax Batwing 120mm Fan MSI P965 Plat 1.6bios,XMS2 PC5300 4x1GB, Corsiar VX 650, Nvidia 9800GT, XP Pro SP3 / Suse 10.3 64bit 3rd System E6750 @ 2.8 Arctic Cooling Alphine 7 MSI P35 Neo2 FR 1.9bios, XMS2 PC6400 4x2Gb, Corsair VX550, Nvidia MSI 9800GT, Sata ONLY. Suse 10.3 64Bit / XP pro 32Bit
NovJoe
« Reply #1 on: 17 March 04, 02:02:07 » |
Well... even a bent CPU golden pin can burn the whole system down already, so the PSU direct power is even more dangerous  .
HTPC - DVI to HDMI for Panasonic 42" Plasma Pentium 4 - 2.4GHz (B) on MSI 865PE Neo2 512MB x 2 Kingston 333MHz, 250GB Seagate MSI NX6800Ultra, AcBel 560w PSU, WinXP Pro SP3
MSI Wind with Love U100 Netbook Intel Atom 1.6GHz, 2GB RAMs, 80GB HDD, 6 cells battery, WinXP SP3
HP Compaq V3136 Laptop - VGA to Sharp 32" LCD Intel C2D 1.66GHz, 2GB RAMs, 80GB HDD, 3 cells battery, WinXP Media Centre SP3
Speakers: Gigaworks S750, 7.1 Theater Surrond Altec Lansing XA3501, 5.1 Gaming
MSI HQ Forum USB flasher
Del UK
« Reply #2 on: 17 March 04, 14:45:33 » |
Hi Joe, No extremely dangerous.......  But I had tried lower PSU's and not fitting card properly.....etc etc..... I would just advise users to CHECK that the atx connections are properly LOCKED onto the motherboard.....  Del
Maesus
« Reply #3 on: 17 March 04, 14:52:21 » |
A good PSU should be able to detect and protect from overcurrent. But a good motherboard should also be able to detect the loss of power rails. It's not OK to accept a motherboard that can burn itself if the ATX cable is not plugged in properly.
Please read the ==> MOAN Guide<== Maesus My PC:Now using : IBM Thinkpad T60pCore 2 Duo recipe E6600 2.66Ghz with GB Rocket Cooler Pro : MSI 975X Platinum PUE BIOS 7.6 : DDR2-667 2x1GB + DDR2-800 2x1GB : MSI 8800 Ultra : 80GB WD Caviar SE : Maxtor 250GB SATA : LiteOn LH-20A1S DVD writer + Samsung SH-W162C DVD writer : MSI Theater 550 Pro : LOGITECH Z-680 : DELL E228WFP 22" LCD : PowerLogic 500W PSU with +12V1&+12V2 @ 32A total
Danny
Guest
« Reply #4 on: 17 March 04, 21:26:12 » |
Unfortunately, arcing can cause quite a bit of damage at low current levels.
NovJoe
« Reply #5 on: 18 March 04, 02:26:27 » |
At least now we are providing a thread to warn users on the hazards within their systems if they are not careful on certain things  . P4 Mods, I intend to stick this up but since too many stickies up there so... Do you guys agree? Forum Members, Please feel free to point out what could be a hazard to burn or fried a system up in smoke if not being careful with and post them up. Only sourceful and accurate ones will stay  so don't try to bluff up the facts like "Faulty Keyboard/Mouse could burn the system up..." and the "bluffs" will be removed  unless proven in-order not to confuse the rest of the members  .
REILLY875
« Reply #6 on: 18 March 04, 04:05:21 » |
I'm not a MOD. so fell Free to tell me To Shut Up Joe  , But I happen to think It's a great Idea to Start a sticky with Good "Do NOT do's" and the "Make sure this is Like Such".....Great Idea in Fact, as anything to Prevent a Problem Thread is Customers $ and Time, And Stress, Saved  ........Sean
PRIMARY SYSTEM
ALIENWARE- AREA-51-ALX EVGA-680i (ALIENWARE-REV.-D) INTEL ENTREME-9650-45NM QUAD CORE (12MB L2) 3.0GHZ @4.0GH (Requires The "P32" BIOS In Order To Run ANY PENRYN CPU) OEM THEMOCOOL-PANAFLOW HIGH PERFORMANCE LIQUID COOLING 2 X 1GB PATRIOT LL6400 2 X EVGA 8800(BLACK-PEARL) LIQUID COOLED-ULTRAS 650MHZ/1100MHZ MEM. 1 X AGEIA PCI-X 100 PHYS-X 128MB CARD 2 X WD 160GB RAPTORS IN RAID-0 2 X WD 1 TB 7200-RPM IN RAID-1 CREATIVE X-FI-HENDRIXS 1 LG 4 X WRITE BLU-RAY (Reads HDVD) 1 LG DVD BURNER W/LITESCRIBE 1 PCPAC 1KW POWESUPPLY "CRAPPY" WINDOWS VISTA> "VISTAKE"!!!! 3DMARK-2006=18,640
NovJoe
« Reply #7 on: 18 March 04, 11:48:29 » |
[STRIKEOUT]Shut Up[/STRIKEOUT]... Nah... Everyone is free to post their point of view here... just no bluffs allowed only...  1 more advice: Heat problems especially overheating which is one of the easiest ways to get a system up in smoke, so take note of the airflow, fans and temps within a system.
Del UK
« Reply #8 on: 18 March 04, 21:03:51 » |
Not a Bluff.......  Lost a good hardware modem, but expanded my knowledge....  It's another "MAKE SURE.....for DEF" Del
cnotemd
Double Ace
Offline
« Reply #9 on: 18 March 04, 21:35:15 » |
Shorted out a 386 with a screw driver when I was trying to replace a sound card with the computer on and running...... so uhhmm..... don't do that.  Couldn't resist - lesson here - do not modify computer while it is on or while it is plugged in. I was only 11 at the time - but Pops was ticked sure 'nuf.
NEO 865PE Neo2 FIS2R 2.4 GHz no overclock BIOS 2.5 2 x 256MB Kingston 3200 Value Ram and 2 x 256MB Apacer 3200 RAM; settings at @ 2.5,4,4,8 GeForce 4200Ti 128MB IDE 2 Pioneer DVR 111 x 2 IDE 1 120GB / 100GB IDE 3 1 drive RAID 0 120GB MadDog 550W: I'll put the volts up as soon as I look again
NovJoe
« Reply #10 on: 19 March 04, 03:30:24 » |
Hi Guys, I've got positive agreement from P4 Mods and users on sticking this topic up and now it's "stick/stuck" on top  . I and the P4 Mods will be monitoring this thread to ensure the clarity of info provided, which I have to stress on again... "bluffs" contents will be removed in order not to confused new/ other members  Btw, the Topic will be changed from "Motherboards NOT booting!" to "Burnt Mobos Prevention Guide". Please note that I'll not make any changes to the info and posts as I want it to remain original, which is to say that "The contributors/members earns the respects from the accurate source provide as it's an knowledge assets of the original contributors/members"  . Note: All are welcome to post if you have come across or having sourceful findings with grounds on ways to Prevent Mobos from Burning or fried.
NovJoe
« Reply #11 on: 20 March 04, 03:09:01 » |
Update:
Make sure that the CPU is fully in contact with the CPU's heatsink thermal paste and make sure that the bracket holding the heatsink is fully locked in else you'll see smokes within your system within 5 mins after booting up because of overheating due to bad contact.
Del UK
« Reply #12 on: 25 March 04, 23:58:42 » |
USE CORRECT POWER CABLE WITH 5AMP FUSE I lent a friend an Enermax 365 PSU, as his PSU wasn't working......I supplied with power cable.........he then said, nope your PSU doesn't work either, it started too and then system went blank........... which cable did he use? The old cable, which was a 13AMP rated...... So there you go......FUSE rating is just as important.......  Del  PS Maybe this would be useful to AMD based MSI mainboards?
daffy the red
« Reply #13 on: 26 April 04, 15:22:47 » |
avoid hand contact on cpu gold pins and be careful where you smear the grease. or pop goes the cpu.
P4,3GIG :HT-ENABLED L2 Cache 512 MegCorsair 3700's twinX 1 gig thermaltake Xaser 3 tower case(cramped!) temp 29 c idle875P-NEOFIS2R Bios 2.4 RADEON 9600 XT GLOBALWIN SAF520 WATTE PSU 22DB sound level.. 2xseagate barracuda 120Gig Raid 0 Striped WINDOWS XP PRO, SP2+ALL AVAILABLE UPDATES(TO DATE) LG Dual layerDVD-R/RWLiteon CD rwsandra 2005 PR=3300
Del UK
« Reply #14 on: 26 April 04, 23:48:10 » |
Originally posted by daffy the red avoid hand contact on cpu gold pins and be careful where you smear the grease. or pop goes the cpu. Hi, Errrrrr....... Touching pins and grease?  ?  Never come across, this problem........  Which grease though? I use Titan Silver Grease which is conductive, so I know that would BLOW CPU, mainboard and PSU.....  Just asking, because: 1) I repair bent pins 2) Clean CPU's (AMD &INTEL) of excessive thermal cooler I really am interested...... Del
daffy the red
« Reply #15 on: 27 April 04, 09:58:58 » |
this mainly leans towards the intel HTT processors. i lost two cpu's due to shoddy installation. the pc would run quite happily without HTT enabled, but as soon as i enabled HTT i would get inundated with 0x7e errors and the likes of. thank's to intel and many months of scratching my head we got to the bottom of it. bent pins due to handling by the pc's creator.(first time not me.. 2nd time me). as this section was only aimed at what to be wary of i kept it simple. grease on the pins will dampen conductivety and create a load imbalance, unless you use arctic silver. arctic silver will not be a good thing to get in the wrong place due to the fact that 1, it is conductive and 2. it sets rock hard. as for grease on a cpu pin. try straining tea through a rubber glove.
sharmane
MSIHQ Red Rockets Team Member
Emperor
Offline
« Reply #16 on: 26 June 04, 09:32:54 » |
Once I as usual I replaced a RAM and checked if the two clips were secure. To my surprise the RAM got fried.
The cause was that the clip had partially come out and as a result the ram was only partially inserted into the slot. That cost me a fortune as I had to replace the RAM at my expense.
So now I always check if the RAM is clipped correctly and if the clips are in place before I poweron the machine.
KT4V Sempron 2400+ 400W PSU Generic 512MB DDR 400Mhz - Kingston 17" Samsung Flat 80GB 7200RPM Maxtor ATA-133 16x DVD Writer (Dual) - Sony Creative 5.1 Live Microlab x4/5.1 Speakers (185W RMS) 128MB FX5200-T128 33.6K External Modem Moded Casing. O/S --> Windows 2000 We fold harderMSI HQ Red Rockets Folding Member
NovJoe
« Reply #17 on: 29 June 04, 13:02:10 » |
Dasbooter
« Reply #18 on: 09 July 04, 00:00:24 » |
After finishing a long school year I stayed up late building a system from spare parts I had kicking around.I had just lucked into a new (snicker,snicker) blazing fast 1GHZ Slot 1 processor for a p3v4x MoBo that my friend who is vendor had in the back in the dust, I guess some idiot had ordered it with a custom fan and than stiffed him on it.I built the system and started her up at 0400 hours or so and she posted fine etc.Started to install the OS and she completely shuts down. Sigh, I had forgotten to plug in the Cpu fan One toasted CPU = One stupid stupid mistake = waste of money. Dont work,fiddle, or mess with your sytems to the early morning hours you will do something stupid and caffeine makes it worse.  I know you guys will still do this but hopefully you will remember this post.
« Last Edit: 09 July 04, 00:02:56 by Dasbooter »
[size=15]-865pe Neo LS(DOT sticker on the box) -2.0 GHz celeron 400mhz sys bus northwood core 128kb L2(I am just a poor student)Retail package cooler/fan -2 sticks Infineon c2 256, 333 mhz ram,running dual channel [/SIZE] [size=15]-Asus v7700 pro AGP 64meg vs(blast from the past) -mod HD cooling fan on AGP card,twin ball bearing fan from old slot 1 processor blows ducted air from front on to mem and processor. -mod so that D bracket in front (what good is in the back anyway?) [/SIZE]
nsarpolis
« Reply #19 on: 10 July 04, 21:52:59 » |
well, one day i was fiddling around in my computer, and i had unplugged the cpu fan, and (you can tell where this is going) never plugged it back again. Thank god i have a copper based alluminum cooler master hs/f and good case airflow, and that i had my cpu warning temp at 65ºC, lol. i had been in windows on AIM only for about an hour, and i started multitasking a bit...... and there we go, BEEP  beep BEEP beep BEEP, scared the crap out of me, so i turned my comp off and went to investigate, touched my cpu heatsink and almost burned my hand off. saying to myself as im looking around in my case, OMG  ....and i noticed my fan was un plugged. Plugged it in and fired up my pc, and all was good, but the cpu temp was still 54ºc and lowering. scared the crap outta myself. Remember peoples!! PLUG IN THE FAN!  :hypecrite:  [Minor Edit by Moderator for language used.]
« Last Edit: 10 July 04, 21:54:25 by nsarpolis »
-Nick
kt6user
Emperor
Offline
« Reply #20 on: 15 July 04, 15:35:37 » |
well I managed to run an Athlon XP 1700+ once with nothing but the heatsink which I was pretty proud of. It was only 45 degrees idle in Windows. Heatsink was just a CoolMaster aluminium and about a year old.
« Last Edit: 15 July 04, 15:35:45 by kt6user »
SCOOTER_2004
Double Ace
Offline
« Reply #21 on: 26 July 04, 03:27:39 » |
kinda off topic, but when i switched mobo's i bent four of the cpu pins and spent 2 hours bending them back with a steak knife and needlenose pliers....
SCOOT
(runnin'ike a crackhead chasing a rock theif since 1987)
865PE FIS2R NEO2 MAINBOARD: BIOS VERSION 3.8 2 X 256MB RAM PC2100 1 X 128MB RAM PC2100 80GB WESTERN DIGITAL 430W ANTEC TRUEPOWER PSU +3.3V - 28a +5V - 36a +12V - 26a BFG Tech - Nvidia GeForce 6800OC 128MB GDDR: Core - 350MhZ; Memory - 700MhZ Pentium 4 2.66c (NORTHWOOD) 533 FSB AOpen 52X CD-RW Drive Floppy Drive Windows XP SERVICE PACK 1 MSI HQ RED ROCKETS TEAM MEMBER
NovJoe
« Reply #22 on: 26 July 04, 10:54:15 » |
Hey SCOOTER_2004, No. You are right in the topic  . It's true that bent pins can lead to CPU overheating and burning everything to hell with it. This is what actually happens to one of clients when he insists on fixing up the system himself just because he wants to give it a try, being a newb, he didn't placed the CPU into the socket properly and the worst thing was the HSF wasn't locked down. Combo that and the bent pins, the whole system fried within 5 mins of usage  . Guess what... He burnt not only his CPU & mobo but everything, I really mean everything which includes two 73GB Raptors, 1 DVD Dual, 1 DVD drive, 1 MSI FX5950Ultra, 2 x 512MB Corsair XMS PC4000 HSR, 1 Highpoint RAID 5 Compatiable card, 1 x Hauppauge Win TV DV card & 2 x Hot swaps which in total costs him around USD 3K...  What's worst is Intel refused to R.M.A both his mobo and CPU due to personal damage... The rest are still able to be refund... which is pretty lucky for him... Now he leaves everything for me to handle  .
SCOOTER_2004
Double Ace
Offline
« Reply #23 on: 29 July 04, 00:10:15 » |
I'm just glad I caught the bent pins before i tried start up the pc, would have been a real bummer. Learn from the mistakes you make and let others learn also, everyone wins in the end unless u think you know everything and want to be a jackass and not listen to anyone. I'm now much wiser on hadware so no worries. It all works out in the end, just don't want to see bent cpu pins again.....or hear of them from anyone else because i know how much of a pain in the rear it can be.
SCOOT
thefreeone
Newbie
Offline
« Reply #24 on: 28 August 04, 02:31:44 » |
When you are playing with mobo's and cards dust can be your worsed enemy..
i once fried a mobo cos there was dust in ram slots ... i put in all the things i wanted and was moving a ram to a new bank it was an old computer with a bit of dust inside .. i turned it on and there was afunny sound in my cpu fan so i bent down to check and one of the little chips right next to my ram slot was on fire ...it was like somebody had a lighter in there .. i turned of the system and it never came back to life ....
i have had boards smoking a bit but still working fine but this one was burning open fire ...
so be carfull dust can kill your puter ...
nsarpolis
« Reply #25 on: 28 August 04, 19:34:48 » |
Whoa that would be scarry lol. Turn on your pc (*muffled poof sound*) as your ram goes up in flames! I would have like thrown my pc out the window, first removing the HDD's, lol (antec removable bays *click* and they come right out!) and lunge the thing out the window (41lbs total, steel antec soho file server case  , 27lbs empty  ) lol, it would survive the fall from the second floor window, i think....
-Nick
NovJoe
« Reply #26 on: 29 August 04, 21:49:40 » |
Luckily I just vaccumed my system chassis and pheriperals 4 hours ago  . Actually after thinking for some time, the burnt may be due to something else as it was the chip somewhere near the RAMs that's burning and not the RAMs but worth an effort to find out the actual caused  .
Zeni
Junior Member
Offline
« Reply #27 on: 03 November 04, 23:19:57 » |
Hi! Do not!!! place your computer at a location where the are no or little air flow...i did that, and a hot day this summer the PSU blow up  luckly for me no other parts were damaged.  Make sure you have fans, and lots and lost of air around your case!!
balewolf
« Reply #28 on: 12 December 04, 09:50:23 » |
i just blew my msi 865pe -pfs 2 days ago from a power supply surgeing i thk kept dropin power like the electric was goin out. then it would only power for like 2 secs unless i take cpu out then it powers but no use tested another cpu in the board same thing and tested mine in a friends board its good. burnt out the cpu voltage regulaters im guessing when ps was surgeing.
CPU=Prescott 3.0E @3.82 Ghz 1.51 RAM=2x256MB 2x 512 elixir ram ddr 400 5:4 RATIO CASE TEMP=25-30C CPU TEMP=35-55C Thermaltake Polo 735 MOTHERBOARD=MSI 865PE NEO2-PS BIOS 3A VIDEO CARD=EVGA GEFORCE 6800 128MB SOFTMODDED TO GT AQUAMARK3=72241 3DMARK05=4798 3DMARK03=12811 3DMARK01=20794 PCMARK04=5740
NovJoe
« Reply #29 on: 12 December 04, 14:11:18 » |
Having a PSU that's running bad is always dangerous especially when there's some PSU which takes some of your hardwares with it when it freaks out.
Have a regular check on your PSU's rails fluctation to make sure that the powers are clean and healthy.
PhoenixGTR
« Reply #30 on: 03 January 05, 04:57:12 » |
How do you do that, Joe? Check your PSU's rails?
NovJoe
« Reply #31 on: 03 January 05, 12:13:35 » |
You can use a Multimeter and either jump start the PSU or start the system normally and test the free molex connectors to make sure that the load is at what it is meant to be, for example red + black wire(next to each other) is for +5v and yellow + black wire(next to each other) is for +12v, place the Muiltmeter pins in and see if the flactuation is within +/- 3 to 5% of the regulation.
It is best to jump start the PSU so that you can test every molex from the PSU.
danj
Newbie
Offline
« Reply #32 on: 18 March 05, 18:15:06 » |
Years ago I had a desktop computer (as opposed to a tower), One day I came home and nothing on it worked so i poped open the case and lo and behold there was about $2.00 in coins scattered all over the MB. Seems my 2 year old daughter thought that the little slot between the empty bay cover and the case was the perfect place to store loose change.Burnt everything in sight. Another time my cd drive would not eject so I pulled out my trusty paper clip and opened it manualy and found about 6 magcards that I use at work stuffed in there --trashed drive.. So the point to the story is if you have children buy a case they cant fiddle with or lock it up in a cabinet.
Bob the Fish
« Reply #33 on: 17 May 05, 10:07:28 » |
I let the smoke out of a old Msi p1 board by hitting a random set of jumpers with a flashlight well i was looking at the fans to see if they were spinning. I just bumped the jumbers and there was a spark and well lost the board, and everything on it. I also ones shorted a antec psu on my old neo2-ls when i put a 3.3 volt agp card in the 8x slot. this time i only lost a psu, scared the  out of me. True story running 6 volts dc into a 486dx2 is both funny and very smokey.
CPU: Core2Duo e6600 at 3.0ghz Finally water cooled! MainBoard: MSI 975X Platinum PowerUp Edition Memory: TWIN2X2048-5400C4 at 675mhz 4-4-4-12 at 1.9v Video Card: Made By ATI x1950pro 256m Case: Thermaltake Armor VA800BWS Cooling: Thermaltake BigWater CL-W0005 Online! HDD: 1x 160g SATA2, 2x 250g SATA2 CD/DVD Drive: LG GSA-H10N 16X SUPER MULTI DVD/CD REWRITER Sound Card: Sound Blaster Audigy 2 ZS Got it back from Creatives RMA! LCD Monitor: Dell 2005FPW 20.1 Wide Screen at 1680 x 1050 Power Supply: PurePower 680w W0049
NovJoe
« Reply #34 on: 19 May 05, 16:04:46 » |
Lately, one of my clients accidentally adjusted his PSU Voltage transformer steppings from 230v to 110v which is to high watting for the PSU to handle and when he switched on the system... Kabboooom!!! The whole circuit tripped in his house... and ending up with a dead mobo, PSU and wall socket... all up in smoke and sparks... Best to know what voltage your region is using before trying to play around with the transformer...
NovJoe
« Reply #35 on: 12 June 05, 04:17:03 » |
Update: Exposed molex cables with wires sticking can sparked off and cause short-circuiting and fried anything within the system if your PSU don't have a breaker system. Therefore, be verey careful with old and worn off cables! Joe Chow.
ant3202
« Reply #36 on: 15 June 05, 18:13:19 » |
My Friend try this before and here gone the motherboard, When assembling the PC the Stuts for screwing the motherboard is IMPORTANT, Failure to do so, will short the whole motherboard as it was a metal casing.... alot of cybercafe did that, without casing and be careful of metal pieces that can lead to short circuit.
MSI 865PE Neo 2 - S Mainboard Intel Pentium 4 3.00Ghz Kingston DDR 512MB - 400Mhz MSI nVidia GeForce FX5500 256MB DDR AGP 8X Maxtor 80GB HDD 7200RPM SATA Power Supply ~ Antec Earthwatts 430 Samsung SyncMaster 152S
Taran
Offline
« Reply #37 on: 20 July 05, 14:17:52 » |
Sorry to all if this does not belong in this post. Just restently up graded from 2.66 P4, 4 x 256 DDR 333 to 3.2 P4 prescott, 2 x 512 DDR 400. Started rip DVD, had control centre on to moniter load, temps and fan speeds all was good, sent them to spaned monitor the fired up dig tv all was good CPU aprox 60 to 61 deg C, 100% load, MB controled fans just running. The with no warning or hot smell flash out back of case, little bang, dead box. Open up check MB and connectors OK. Pulled 400 watt PSU and trigged, no go. Opened PSU, ruptured fuse, change fuse, trigger, burning resistors,both primary side transistors short base to collector. Pulled old 300 watt psu off peltier cooler, powered up MB still alive Replace trans and resistors still no go.PSU in BIN. Sprung for 550 Watt Codgen (hope is good) So far so good So take care with up grades and max loads not just Vid cards.
Regards to all Taran
Intel P4 3.2 Prescott 1mb L2, 800 FSB M.B.Intel Intel D865PERL Config 3.CODGEN 550 watt PSU 2 x 512 mb DDR 400 Running Dual Channel Dynamic Pageing MSI NX 6600 GT VTD 128 DOT O.C Commander SoundMax 5.1 on Board Sound. AverMedia Digital Tuner 40 Gig ATA Segate 120 Gig Sata 2 Partitions LG Super Multi DVD Burner & LG 52x24x52 CD Burner MS Explorer Track Ball. Logiteck Z 640 Sound System Zalman 5.1 Head Set. Zalman 6 ch Amp Win XP Pro Sp2 Installed as Standard PC. Home made 33w Peltier system cooler.
NovJoe
« Reply #38 on: 23 July 05, 11:57:02 » |
bassmadrigal
Forum Legend
Offline
Giggidy, Giggidy, Gig-gi-dy
« Reply #39 on: 23 July 05, 12:21:58 » |
Surprised no one has mentioned static discharge. Although I have not personally had this issue I ran into the problem a couple of times while I was doing work for a small computer repair shop. Always make sure you are grounded. Best way I have found is keep the PSU plugged in but switched off. This way the chassis is fully grounded and you just need to hold onto the chassis. But at least touch the chassis to remove any static. Some like an Anti-static bracelet (there is an actual name for it but it eludes me today), but I just opt for keeping a hand on the case. Make sure you don't work on the computer in a carpeted area in your socks. Always handle computer components carefully. Use anti-static bags. Good Luck and Don't Fry Jeremy
If you drop your keys in molten lava, forget them; because, man, there gone!
MSI K9A2 Platinum AMD Athlon 64 X2 6400+ 4GB Corsair XMS2 DDR2 800 Diamond ATI HD3870 SoundBlaster X-Fi Xtremegamer 2x1TB, 1x500GB, 1x320GB, 1x250GB, 1x150GB Western Digital SATA Coolermaster 1200W PSU +3.3V@30A,+5V@30A,+12V1@20A,+12V2@20A,+12V3@25A,+12V4@25A ThermalTake Armor 8000 Full Tower Samsung SyncMaster 940BX 19" LCD 1280x1024 Hanns-G HG281D 28" Widescreen LCD 1920X1200
