Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 20:51:41 *
News: How do you flash your BIOS, please take part in our poll, thank you! >>How do you flash?<<
Pages: 1 [2]  All   Go Down
  Print
Author Topic: Burnt Mobos Prevention Guide  (Read 17402 times)
NovJoe
Offline Offline
~DeSTinY~ Destined 2 Be HeRe ^^
« Reply #40 on: 23 July 05, 12:29:26 »
Oh yah... I missed that out too wall ...
For me, I always have a habit of discharging the pulse by touching the chassis. Qiuck and easy.
Thanx Bass biggthumbsup .
HTPC - DVI to HDMI for Panasonic 42" Plasma
512MB x 2 Kingston 333MHz, 250GB Seagate
MSI Wind with Love U100 Netbook
Intel Atom 1.6GHz, 2GB RAMs, 80GB HDD, 6 cells battery, WinXP SP3
HP Compaq V3136 Laptop - VGA to Sharp 32" LCD
Intel C2D 1.66GHz, 2GB RAMs, 80GB HDD, 3 cells battery, WinXP Media Centre SP3
Speakers:
Gigaworks S750, 7.1 Theater Surrond
Altec Lansing XA3501, 5.1 Gaming
MSI HQ Forum USB flasher
meditek
Full Member
Offline Offline
« Reply #41 on: 22 August 05, 11:47:08 »
Monitor your CPU temperature. Mine (P4 2.8gz) hit 78 degrees and my comp started crashing! The cooling fan and cooler were almost totally blocked with dust! A lot of filth was adhering to the fan and vanes and required a good soak and shake in Isopropyl alcohol to unstick it.
AMD Athlon 64 3700 San Diego
MSI K8N NEO4 F1
Enermax Coolergiant EG485AX-VHB 480w psu
2 x 512MB PC3200 400ram
1 Lightscribe DVD r/rw
1 Asus Quietrack CDR
Netgear DG834G V2 Router via Ethernet
1 PCI Card USR5416 Wireless Network Card - disabled
Radeon X800 XT PCIE
2 WD Raptor 74GB drives
XP Pro SP2
Vcore = 1.39v; +12v = 12.24@16A; 3.3v = 3.23v@34A; 5v = 5.02v@40A;  5VsB = 5.02v@2.5A; Battery = 2.89v
jtdoom
Offline Offline
« Reply #42 on: 21 November 05, 18:49:37 »
interesting topic...
bent pins?
A simple 0.5mm mechanical pencil is all you need to fix a bent CPU pin, the tip is a perfect fit for the pin, just slip it over the bent pin and push ever so lighty into place. full read in 7/05 issue maxmumpc. BTW: remove lead from pencil first.
Do not try memory you saw getting hot/smoke in another box.
it could have developed an internal short, and this can fry yuor CPU.
Likewise, a blown CPU should not be tried in another box...
do not use a DELL powersupply you salvaged, for a standard non-Dell system.
Chances are (high) it has other voltage in its ATX connector rails than what standard systems have...
That can blow it up fast...
something on building...
when you are about to put that motherboard with the CPU, its heatsink, and the memory nicely installed on it into the case, why don't you first put that DVD burner in that 5 inch bay. Then try wether the motherboard will still go in.
Huh
There are many variations in sizes of cases, and one danger with them is that one sees a full length burner or CDROM drive come in contact with components on the motherboard when you GENTLY shove them in.
If you do that unawares of the dangers, and PUSH, you could seriously damage that mobo.
« Last Edit: 21 November 05, 18:55:45 by jtdoom » Logged
Kind regards, Jaak.
mrbigtime
Newbie
Offline Offline
« Reply #43 on: 17 March 06, 19:10:29 »
hi .iam new around here. ijust get a beep from my 651M-L/650GM-L.
According to this post.its a DRAM error yes. ibecause i changed it from normal to ultra.how can i fix it Sad
NovJoe
Offline Offline
« Reply #44 on: 11 April 06, 08:02:22 »
Please start a new thread as this sticky is for reference.
Speakers:
danielt
Newbie
Offline Offline
« Reply #45 on: 28 June 06, 23:29:55 »
I managed to burn 2 pins of a RAM socket and 2 pins of the RAM module.
It was DDR RAM,  I must've somehow put it in backwards or perhaps not properly. could've sworn it was clipped in.
so nowadays, I always use a torch  l ,  line the RAM up on top of the module, make sure that the cut (in the module) and the key (in the socket) are aligned. The RAM module isn't symmetrical there are more pins on one side of the cut than on the other side. So I put it on the module and shine a torch to ensure I got it right. Then I push it down.
NovJoe
Offline Offline
« Reply #46 on: 29 June 06, 05:10:28 »
Torches always come in handy for us Cheesy. Nowadays, I always bring along my mini Ultra Bright LED Torch with me Wink.
Speakers:
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #47 on: 19 November 06, 23:39:19 »
UPDATE:-
On 478 based socket mainboards, the retention bracket that hold the Heat Sink & Fan (HSF) to cpu.........
Make sure that this is firmly in place, as it held in with 4 plastic pins.
These can become loose and cause unseen heat issues, especially with non INTEL HSF..... yes
Mainboard warping is common and in some cases failure of mainboard........ yes
Main system
MSI P45 FR3 V1, E8400 with Arctic Cooling Alpine 7, Corsair VX 550, ATI 5770, 8Gb DDR2 Corsair XMS2, onboard NIC/Audio, WD 160 & 500 RE drives, Opti DVD, Enermax batwing 120's. Win 7 64bit
2nd System
Duo2 E6600 @ 3.2, Thermalright SI-128 with Enermax Batwing 120mm Fan
MSI P965 Plat 1.6bios,XMS2 PC5300 4x1GB, Corsiar VX 650, Nvidia 9800GT, XP Pro SP3 / Suse 10.3 64bit
3rd System
E6750 @ 2.8 Arctic Cooling Alphine 7
MSI P35 Neo2 FR 1.9bios, XMS2 PC6400 4x2Gb, Corsair VX550, Nvidia MSI 9800GT, Sata ONLY. Suse 10.3 64Bit / XP pro 32Bit
pcfool
Junior Member
Offline Offline
« Reply #48 on: 21 December 06, 05:42:42 »
this happen on a friend of my, his friend help him build a new system p4 2.66 socket 775, after assembly, power on, everything work fine, then install windows,
he sucessful setup everything,  the next day, when he on the pc again,, few min after loading windows, system restart , and keep restarting every few min. my friend is a newb. after few time restart he aware something wrong, call his friend who assembly this system, the guy think just system conflict.
luckly i was there at the moment, hypocrite i open the casing , found out the cpu fan was dead. shocking sent for RMA and problem solve. lucky cpu doesn't fried. lol_anim
when troubleshooting, try think from different way, dont u ever say " this must be xxxxx  cos the problem, " . when u have problem cannot solve, bring it to other ppl, they migh have different thought. and never approch to a system and say: "this is easy" nooo
Ralphdb
Lord
Offline Offline
WWW
« Reply #49 on: 25 July 07, 01:07:16 »
I moved my puter to another Room hooked it all up and hit the start button . booted fine , within 5 minutes I notice the temp alarm yelped at me .. I shut down opened the case and said O+MY+Gosh.. My North Bridge fan and heat sink was lying on my Video Card.. I could not believe this .. I used super glue by Locktite to glue it on after cleaning and adding more Silver paste. I was so lucky I thought could have burned all componets.. then 5 days late after maybe 20 hours of operation I hit the start button and POW!  and shutdown to silence.  I got a new PS but nothing is stirring.. I will buy a new MB and hope for the best..
BIOS V1.7 OC NO
CoolerMaster Case
MSI 7350 P6N Platinum SLI:
2-80Gig Diamond Max 9 SATA. RAID 0,150, 8MB[(Both Disabled)
SATA II 500 Gig Seagate 3 Gb/ps
Intel core2Duo E6420 1066MHZ,4 mb cashe
  4 Gig Corsair XMS twin2x2048-6400 G X 2=4096
Dual NX8600GT oc SLI
S.B. Audigy ZS (Removed)
Sony DVDRW
LG DVDRW, Light scribe
SAMSUNG 24" Monitor Cool
Turbo-Cool 510 Deluxe Cool
+5v=40A, +12v=34A, +3.3v = 30A
 Vista SP-2 Beta on C:
6-80 MM fans
NovJoe
Offline Offline
« Reply #50 on: 26 August 07, 08:11:45 »
Overheating is always a killer.
Speakers:
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #51 on: 18 October 07, 23:51:12 »
Using super glue is a bad short cut........ as this does leave a gap and does not allow thermal paste to fully bond between main component and cooler unit.
Yes, it worked in past, I know. Today's components do not have the heat tolerance.  rolleyes_anim
I will keep posting here, as long as I find new problems.... I am sure I will LOL
ATB
Del
Main system
2nd System
3rd System
Pages: 1 [2]  All   Go Up
  Print
Jump to:
Page created in 0.155 seconds with 19 queries.
