Author Topic: MS 7005 USB Drivers  (Read 3014 times)
rtg
MS 7005 USB Drivers
« on: 07-September-04, 20:28:50 »
Hi
I hope there is someone here that can help me with a little problem I have.
I have the MSI MS-7005 VER 1 motherboard and I use a Creative USB Modem blaster to connect to the net ... the problem is that the modem is disconnecting after 5 - 10 minutes all the time and I cant get it to stay online.
I talked to Creative Support and they say it's the USB drivers  that is the problem but I cant find USB drivers anywhere... atleast not for the ms-7005 ???
Anyone know where to get the drivers ? or is there anyone who has had a simmilar problem and found out what the problem was ????
WinXP has the drivers in it but I just cant get the Sh** to work with these(more than 5-10 min that is).
Thanks
RTG
Kingfisher
(No subject)
« Reply #1 on: 08-September-04, 12:50:33 »
go to:
http://www.intel.com/support/chipsets/inf/
and get IntelĀ® Chipset Software Installation Utility
also install service pack 2 of WinXP
