Author Topic: Socket 939 BIOS updates  (Read 586 times)
Gixer
« on: 12-October-04, 22:09:53 »
I think I must be going blind.  I cant seem to find a tab in the BIOS updates bit for Socket 939.  I have a K8N Neo2 Platinum and wondered if there was a BIOS update yet?
I seem to have quite high temps and was wondering if they were true or not as well?
Anyone know where I can go to check if there are BIOS updates for this Socket 939 mobo yet?
Thanks
rhansme
  • Military Class
    • http://www.west-tech.com
(No subject)
« Reply #1 on: 12-October-04, 22:52:11 »
Ver. 1.3 is the latest Neo 2 bios.
Main Rig - GA-X38-DQ6 - Intel Core 2 Duo E8400 -  Raid 0 w/2 ea WD 35G Raptors - Thermaltake 700W PSU - 8GB G Skill PC8000 -  Koolance Case - XFi Platinum Audio - Logitec Z680 5.1 Speakers - XFX 8800GTS 320 MB -  24" KDS Monitor LCD - SATA Blu-ray DVD-ROM Drive Model DH-4O1S-11  -  Asus Sata DVD Burner SATA  -  XP Pro SP2 -  Bios ver F8 -- 2nd Rig. K8N Neo-2 Plat. - FX53 - Enermax 565 p/s - Raid 0 - 2 x 1G Ballistix - Gainward 7600. Koolance Water cooled cpu and chipset. XPPro SP2 - 191T LCD.
xgman
(No subject)
« Reply #2 on: 12-October-04, 23:21:25 »
there is a beta 1.36 link somewhere.
sauza
(No subject)
« Reply #3 on: 12-October-04, 23:24:12 »
If you want to search for the latest, go to the BIOS search page and enter the appropriate information for your board.
rgreen83
  • Easy OC
(No subject)
« Reply #4 on: 13-October-04, 02:33:34 »
I was under the impression that 1.36 was actually 1.3beta6 making it older than 1.3 final, the compile date is newer on the official also.
Athlon64 3200+ 939
K8N Neo2 Platinum, bios 1.3
1 gig Corsair Value ram
Ultra X-Connect 500w, 34a 12+
2 WD800JBs raid 0 sata 3 and 4
WD1600JB sata 1
Liteon SOHW-812s
Pioneer 106s
9800XT
CPU, NB, and VPU watercooled
