Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 21:13:52 *
News: Do NOT use M-FLash for BIOS flashing! It kills boards!
>>USE THE FORUM FLASHER INSTEAD!! It's 100% safe!! Click me to get there!!<<
  Print
Author Topic: Cmedia CMI9880 Azalia driver problem solution  (Read 25871 times)
Voodooghost
Newbie
Offline Offline
« on: 21 January 05, 08:57:09 »
Hi everyone
I decided to post this thread because when i browse the forum i see a lot of trouble with installing the sound drivers for the cmedia CMI9880 driver and nowhere is a clear or straight anwser.  This soundchip is installed on a lot of mobo's. Intel 915P neo2 platinum, 915P combo, 915P FR and the 915G series. Even Asus (ssssh, wash my mouth) has installed this soundchip.
The issue occurs when you run the setup.exe of the drivers that you downloaded.  When  start the .exe, you get the message that the device could not be found or that you manually removed it.  It seems that the gentlemen from Cmedia forgot a little part in their driver setup.  redface
When you examen your system closely you'll see a pci device that dissapears when you disable the soundchip in the bios.  So it's a device driver that you need and luckily everyone who downloaded the sounddrivers has the driver.  All you have to do is browse to the directory that was unzipped.  Correct directory is CMI9880Ch71\BusDriver.  There you will see a lot of directory's with language codes.  Pick the one that your OS uses. for example english = US.  You must pick the correct language or it won't install. In the directory you'll see an .exe ( kb835221.exe) . Just run it and it will install the driver for the pci device that was unknown.
When this is done you can run the setup.exe again and this time you won't be prompted because it will find the device. Problem solved.   idea
Have fun with it.
« Last Edit: 21 January 05, 08:57:52 by Voodooghost » Logged
Maesus
Error55: Rank engine broke!
Offline Offline
in Penang, Malaysia
« Reply #1 on: 21 January 05, 09:21:09 »
This deserves a sticky. I knew this problem but I never able to put into words. You have done it.  biggthumbsup Thanks!
Please read the ==>MOAN Guide<==
Maesus
My PC:
Now using : IBM Thinkpad T60p
Core 2 Duo recipe
E6600 2.66Ghz with GB Rocket Cooler Pro : MSI 975X Platinum PUE BIOS 7.6 : DDR2-667 2x1GB + DDR2-800 2x1GB : MSI 8800 Ultra : 80GB WD Caviar SE : Maxtor 250GB SATA : LiteOn LH-20A1S DVD writer + Samsung SH-W162C DVD writer : MSI Theater 550 Pro : LOGITECH Z-680 : DELL E228WFP 22" LCD : PowerLogic 500W PSU with +12V1&+12V2 @ 32A total
yasar
Newbie
Offline Offline
« Reply #2 on: 03 February 05, 12:37:49 »
hi,
I have a motherboard called msi 7028 that chipset i915g. I enjoy it but i have a problem it's onboard soundcard. once problem no sound from rear hoparlor and second problem (I use 4+1 jazz speaker) when i click  that file is fifa2005.exe it seems blue screen and cmudax.sys error then pc restart. i do you said solve . But problem is still go on.
help and thansk.
seba
Newbie
Offline Offline
« Reply #3 on: 11 March 05, 18:59:50 »
i did what you sad and i could insal the driver but my computer still cant find the device
fmp
Newbie
Offline Offline
« Reply #4 on: 17 March 05, 16:35:57 »
I have other msi 915 P combo, with Win XP Home edition SP2. All run ok but I bought an avermedia tv-card and I canīt listen the audio.  In Avermedia support (http://www.avermedia.es/cgi-bin/faq_avertv.asp) say that the motherboard with chip intel 915 y 925, his sound car don't detect correctly the avermedia appllication and they suggest to actualize the drivers.
I have try all but I don't get nothing, there is no audio.
IN CONTROL PANEL, AUDIO FEAUTURES, REPRODUCTOR,  DONT'T APPEAR LINE IN, ONLY WAVE, SYNTH AND CD AUDIO. Although It appears in record properties.
If i connect directly the speakers in the audio out of the tv car It sounds. But when I connect the audio out to the line in of the motherboard I only listen the windows sound, games music, multimedia reproductor but not tv sound.
I think the problem is that the line in doesn't appear in reproductor properties.
Please help me. thanks.
Sorry for my english but I live in spain and is difficult for me explain this problem in english. Thanks for all. I wait your answer.
gRRuby
Junior Member
Offline Offline
« Reply #5 on: 02 April 05, 02:13:20 »
I'm new owner of 925XE Platinum G54 (MS-7053 REV. 1.0).
It's a lot of trouble with CMI9880L on the board.
First was a problem with driver. After
BusDriver (kb835221.exe) instalation Azalia started.
But now I have another problem: sound quality is horrible,
with noise and buzzz in background (it's not depend on "mute"
enable or disabele). When system staret is quiet. During
loading Windows noise start.
PSU repalced but nothnig changes.
Please help me
It is any chance to test onboard CMI9880 under Linux
or old good DOS ?
P4 3.2
1 Gb DDR2 (4x256)
MSI RADEON RX660 XT
Seagate SATA 160Gb
DVD-ROM Pioneer
CDRW PLEXTOR
DVD-RAM LG
MSI 925XE NEO PLATINUM LGA775, Prescott MS-7053 rev1.0,
intel i925X rev.E, Southbridge Intel 82801FB(ICH6), Sensor Winbond:     W83627THF
Phoenix v6.00PG, Date: 02/21/2005
ver 1.5
Gigabyte, PCI-E GV-RX700P128D-SP, 128MB-DDR 3,ATI RADEON X700 Pro
Directx: 9.0C(4.09.0000.0904)
Intel P4, 540, 3.20, LGA775, L2-CACHE 1MB, 800MHzFSB
KingStone DDR2-SDRAM, 4PCS X 256MB=1024MB, Dual Channels,       Bandwith:PC4300 (266MHz)
Seagate ST3160827AS 160GB 8MS SATA-150
DVD-ROM:  Pioneer
CDRW:       Plextor PX-W4012A
DVD-RAM:  LG GSA-4163B
PSU:          Enlight 350W(400W peak), Model:83519C4B1
KeyBoard:  Microsoft Internet Keyb
Mice/Tablet Wacom Graphire 2
optional:
SCSI 2940
AverMedia TVStudio
MSI WiFi Lan adapter
ghanem
Newbie
Offline Offline
« Reply #6 on: 04 April 05, 00:17:02 »
This cmedia is very annoying..
I have done the steps, but I installed the kb835221.exe from the drivers CD, folder Drive:\Sound\C-Media\CMI9880L\Channel\BusDriver
After that I installed the c-media audio drivers from the menu..
Its all installed, but I sill don't have sound..
It shows under sound and audio devices in the control panel that there are no audio devices avilable
What is missing, please help  wall
gRRuby
Junior Member
Offline Offline
« Reply #7 on: 04 April 05, 13:54:54 »
Check your bios. 'Onboard sound' should be enabled (Azalia)
Remove any audio devices under' SefeMode' or try remove it from 'NormalMode' but in 'View' select 'Show hidden devices'. Install manually kb835221 (from your language dir) and try to Install Cmedia driver.
Check your driver it should be 5.12.01.0008.56 (62) (cmudax.sys). It is latest.
Its all installed, but I sill don't have sound...  you must have Cmedia aplet in ContolPanel.
Check mixer and front-rear settings.
Good luck.
But who help me ?
(one post before)
« Last Edit: 11 April 05, 02:49:18 by gRRuby » Logged
ver 1.5
DVD-ROM:  Pioneer
optional:
SCSI 2940
AverMedia TVStudio
ratkid132
Full Member
Offline Offline
Don't responsibalize me!
« Reply #8 on: 06 April 05, 14:16:23 »
cmedia gives me no end of trouble, right now i have no sound on my computer because it crashes about an hour after i listen to music, its so annoying.
as if that weren't enough i can't play games because my msi graphics card crashes the computer as soon as i start a game.
dare i say it... i have an ofice PC! redface
z9623
Newbie
Offline Offline
« Reply #9 on: 06 April 05, 23:40:40 »
Need some help with cmedia azalia driver. After updating the bios, i lost all the definitions of the board. After installing everything again the only thing that does not work is the sound board. It has the driver version 5.12.1.00007.36. I've already ran digicell and it says sound speaker not supported. Need some with this
gusurketen
Newbie
Offline Offline
« Reply #10 on: 10 April 05, 14:24:02 »
hi z9623,
My problem is same your's problem. When i update bios, its error message is "no soundcard device". What are we doing now?Sad
--HOOLIE--
Newbie
Offline Offline
« Reply #11 on: 10 April 05, 19:39:45 »
Chech your bios. 'Onboard sound' should be enabled (Azalia)
Good luck.
But who help me ?
(one post before)
Where did you get that driver version??
All that i can find is 5.12.1.00007.36
gRRuby
Junior Member
Offline Offline
« Reply #12 on: 11 April 05, 02:46:44 »
it is so simple ...  yes
http://www.cmedia.com.tw/download/e_azalia.htm
file name: UDAX008(Logo56.62).zip
version: UDAX008.56.62
cmudax.sys version: 5.12.01.0008.56 (62)
Before you install this driver, you need Microsoft High Definition Audio bus driver.
You can install MS HDA separatly from older version of Cmedia driver.
ver 1.5
DVD-ROM:  Pioneer
optional:
SCSI 2940
AverMedia TVStudio
--HOOLIE--
Newbie
Offline Offline
« Reply #13 on: 11 April 05, 09:11:21 »
OK..i found that one but i didnt saw the version number....
thx anyway..
This new driver didnt solve my problems as well...
When is use the MS HDA my front panel (including my Headset) are working fine , but my 5.1 speakerset isnt.
When i install the new C-media drivers , my surroundset is working fine but my frontpanel isnt working anymore....
I need a mix of both....
Anyone some ideas??
« Last Edit: 11 April 05, 09:34:43 by --HOOLIE-- » Logged
gRRuby
Junior Member
Offline Offline
« Reply #14 on: 11 April 05, 13:32:24 »
Try C-Media Audio Conf. Smatr Jack - maybe you have disabled/unusable front jack.
I'm confused too.
What does it mean (last line):
• Azalia link controller integrated in IntelŪ ICH6R chipset.
• 8-channel audio codec CMI9880L.
- Compliant with Azalia 1.0 Spec.
- Supports Multi-Streaming function.
- Supports Universal Audio Jack (only Front Audio Jack).
Sometimes "hammer" button are visable, sometimes not ... strange
loading Windows noise start. But when I press the left mouse button
on Acrobat Reader everything is ok ...
« Last Edit: 11 April 05, 17:03:38 by gRRuby » Logged
ver 1.5
DVD-ROM:  Pioneer
optional:
SCSI 2940
AverMedia TVStudio
--HOOLIE--
Newbie
Offline Offline
« Reply #15 on: 11 April 05, 14:43:33 »
Try C-Media Audio Conf. Smatr Jack - mayby you have disablet/unusable fron jack.
I'm confused too.
on Acrobat Reader everthing is ok ...
I tried that already....didnt solve it...
I think the last line means that it can handle al kinds of Jack's ( Mono ,Stereo,Mini,Large).
But thats just what i think...
gRRuby
Junior Member
Offline Offline
« Reply #16 on: 11 April 05, 17:17:58 »
From my point of view your problem is exaly in UAJ function... it is something like PnP for Jack - terrible
some words about:
High quality 6-channel audio with UAJ function
(...) With new Universal Audio Jack (UAJ) feature users won't have the worries about how to install speakers correctly.
Impedance sensing and jack detect techniques allow device loads on inputs and outputs to be auto-detected. Headphone amplifiers are integrated at each analog output. All analog IOs can be re-tasked according to user's definitions, or automatically switched depending on the connected device type (Universal Audio JackŪ).
BTW
Why US-version of MSI 925XE Platinum has Realtek ALC861 ? It is more/less expensive ? It is better ? Why ?
All Intels reference mobo are eupiped with ALC880/ALC861 ...
« Last Edit: 11 April 05, 17:24:58 by gRRuby » Logged
ver 1.5
DVD-ROM:  Pioneer
optional:
SCSI 2940
AverMedia TVStudio
pav1
Newbie
Offline Offline
« Reply #17 on: 15 April 05, 02:16:24 »
Have the same problem... updated the BIOS and then the sound device vanished.
Also when I try to click on the 3D Audio Control Panel applet, nothing happens!
Have tried installing the Knowledge Base (835221) fix manually - but of no avail. The KB fix is simply windows support for Hi definition motherboard based sound.
How do I uninstall the BIOS update. wall
Am about to try removing the device in Safe Mode, if that doesnt work, as a last resort I'm back to my creative PCI board - at least that obselete crap worked.
RaymanBR
Newbie
Offline Offline
« Reply #18 on: 15 April 05, 13:31:35 »
I have a Neo925 Platinum that comes with CMI9880 Azalia. At my BIOS / Integrated Peripherics has the option AC97 or Azalia. I used to leave in AC97.
First I tried to install the Cmedia driver directly, it didn't work Error status 10 device not found. Then I read the Forum instructions, unistalled the driver and first install the Busdriver and after the cmedia driver. it didn't work either.
I am frustated, because my XP Pro is without sound, I tried to change at BIOS to Azalia, and tried to install the driver manually with add a new driver but the system shows the same error.
Somebody has a advice?
Thanks bonk
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #19 on: 16 April 05, 00:14:10 »
Hi to all............
Why did you upgrade bios if you had sound OK? Did the bios upgrade cure another problem you had?
Which sound option in bios do you choose when you install OS?
Del
Main system
MSI P45 FR3 V1, E8400 with Arctic Cooling Alpine 7, Corsair VX 550, ATI 5770, 8Gb DDR2 Corsair XMS2, onboard NIC/Audio, WD 160 & 500 RE drives, Opti DVD, Enermax batwing 120's. Win 7 64bit
2nd System
Duo2 E6600 @ 3.2, Thermalright SI-128 with Enermax Batwing 120mm Fan
MSI P965 Plat 1.6bios,XMS2 PC5300 4x1GB, Corsiar VX 650, Nvidia 9800GT, XP Pro SP3 / Suse 10.3 64bit
3rd System
E6750 @ 2.8 Arctic Cooling Alphine 7
MSI P35 Neo2 FR 1.9bios, XMS2 PC6400 4x2Gb, Corsair VX550, Nvidia MSI 9800GT, Sata ONLY. Suse 10.3 64Bit / XP pro 32Bit
Fred_Teg
Junior Member
Offline Offline
« Reply #20 on: 18 April 05, 10:13:52 »
Why Azalia new ver 5.12.01.0008.50 for WinXP is not able to live-update or to install?
I visited URL: http://www.msi.com.tw/program/suppo...?UID=635&kind=1
also you can refer to another threads at:
http://forums.hardwarezone.com/showthread.php?t=992011
Answer: Azalia old ver 5.12.01.0007.36 is Win2k in the packed CD; with MSI Live Update 3 it does not show Azalia new ver 5.12.01.0008.50 for WinXP. This is what happened before when I was at Corbell Singapore to show to the Technical Support Team and he could not install the CD old Azalia into WinXP SP2 directly. But can install into WinXP SP1. So you can only install old Azalia into WinXP SP1 and upgrade to WinXP SP2.
That's not all, if you repair your windows again with WinXP SP2; you will lost your old Azalia. Only solution is repair with CD WinXP SP1 then you will not lose your old Azalia.
If you have slipstreamed with bootable WinXP Sp2, then you need new Azalia.
This is the correct and new latest driver from MSI at
UDAX008 (Logo56.62).zip is the correct driver for WinXP SP2
[Attention Please:]
[Before you install CMI9880 audio function driver, you need Microsoft High Definition Audio bus driver.]
[To knowing more information about Microsoft bus driver with universal audio architecture (UAA) High Definition Audio class driver, please reference website: http://support.microsoft.com/default.aspx?scid=kb;en-us;888111 Thanks.]
Further information you must know: (UAA v1.0 and v1.0a)
http://support.microsoft.com/kb/835221/
and,
I have submitted my email to these URLS without reply yet.
I have asked Microsoft where to get UAA V1.0a for WinXP SP2 then I can install Azalia UDAX008 (Logo56.62).zip
Also at
http://www.microsoft.com/whdc/device/audio/UAA.mspx
Then download UAA_Overview.doc (size 76kb, 80,896bytes),
and on Page 1, this is for next coming "Windows Longhorn".
Both articles do not have the download drivers or to be found or from anywhere.
Why the Live Update 3 and CD did not have ver. 5.12.01.00080.50 to install for WinXP SP1 and SP2?
I have requested and demanded many times from Corbell and MSI regarding to the above matters and there is no reply?
 angryfire  angryfire  angryfire  angryfire  angryfire  angryfire  angryfire
« Last Edit: 18 April 05, 10:48:00 by Fred_Teg » Logged
Sig. of my PC HW
Mobo: MSI 925XE NEO PLATINUM LGA775, Prescott MS-7053 rev1.0, intel i925X rev.E, Southbridge Intel 82801FB(ICH6), Sensor Winbond: W83627THF Manufacturer : MicroStar Int'l Co Ltd
BIOS: Phoenix v6.00PG, Date: 02/21/2005
Graphic Card:  Leadtek WinFAst SLi, PCI-E PX6600 GT TDH, Extreme Edit, 128MB-DDR 3,nvidia Geforce 6600GT
CPU:    Intel P4, 550, 3.40, LGA775, L2-CACHE 1MB, 800MHzFSB
Memory: TwinMos DDR2-SDRAM, 2PCS X 512MB=1024MB, Dual Channels, Bandwith:PC4300 (266MHz)
Hard Disk: Samsung SpinPoint SP1614C 160GB 8MS SATA-150 (Qty 2)
PSU:    SkyHawk power One 570W,Model:GM-570PC
Cooler (Not yet Mounted!) : Thermaltake Silent Tower Heatpipe
KeyBoard & Mice PS/2 wired (and unplug wireless Atech KeyBoard /Mouse KBS-2680RP
O/S: Win XP SP2
Fred_Teg
Junior Member
Offline Offline
« Reply #21 on: 19 April 05, 08:12:49 »
Hi everyone
Have fun with it.
Pls see my Thread no#20 at http://forum-en.msi.com/index.php?topic=71994.0
and,
http://forum-en.msi.com/index.php?topic=78370.0
« Last Edit: 19 April 05, 08:17:40 by Fred_Teg » Logged
Sig. of my PC HW
O/S: Win XP SP2
Fred_Teg
Junior Member
Offline Offline
« Reply #22 on: 19 April 05, 08:19:33 »
Please help me
or old good DOS ?
P4 3.2
1 Gb DDR2 (4x256)
MSI RADEON RX660 XT
Seagate SATA 160Gb
DVD-ROM Pioneer
CDRW PLEXTOR
DVD-RAM LG
Your answer is at http://forum-en.msi.com/index.php?topic=78370.0
« Last Edit: 19 April 05, 08:28:59 by Fred_Teg » Logged
Sig. of my PC HW
O/S: Win XP SP2
Fred_Teg
Junior Member
Offline Offline
« Reply #23 on: 19 April 05, 08:27:27 »
To :ghanem
Your answers are here at:
http://forum-en.msi.com/index.php?topic=78370.0 and http://forum-en.msi.com/index.php?topic=71994.0
Sig. of my PC HW
O/S: Win XP SP2
TastyNapalm
Newbie
Offline Offline
« Reply #24 on: 01 May 05, 02:47:13 »
Does the Cmedia CMI9880 chipset support mic boost. I can't seem to get advanced under audio properties in windows XP.
Help.
speedeamon915p
Newbie
Offline Offline
First attempt at creation!
« Reply #25 on: 03 May 05, 08:51:24 »
I too have had some dissappointments with azalia, i have a kenwood vr7070a with both pcm optical and coax digital. unfortunatly, when i try to run dvd software Intervideo, it does not support 7.1 output (but you throw some money at them they'll get you the proper decode)  What I want to know, being the kenwood has NEO and SRS decode capability, why cant I decode multiple channels?  Anyone have any clue of software that's best for what I'm trying to accomplish?
When in the xear utility, and I try to access the individual speaker (for sound check and level) I get front left and front right, but no center, surround left, right or even the sbl & sbr.  Thats using the optical cable.  havent tried using my 6.1 input for dvd yet (7070 will decode sbl and sbr from 6.1 and also digital pcm) but instead of letting me choose (something about the 7070 b/c of pwm signal) surround decoding, it defaults to stereo only.
also seems interesting xear allows 48/96 KHz in audio, but under Windows sound settings from control panel, the option is grey-ed out.
When all else fails, RTFM!
MSI 915P COMBO FR V1.0
P4 540J 3.2GHz 1Mb L2
AMI BIOS V1.6
SPECTECK 256Mb X2 DDR2 533 4,4,4,12
ROSEWILL 500W : 3.3V/28A 5V/30 12V/34
SAMSUNG 40X/40X DUAL LAYER DVD WRITER
LITE-ON 52X CD-ROM
DESKSTAR 80Gb S-ATA
QUANTUM FIREBALL 80Gb
(LAUGH) S3 VIRAGE DX PCI (THATS RIGHT WHOPPING 4Mb!)
myname70
Forum Ace
Offline Offline
« Reply #26 on: 07 May 05, 12:05:06 »
Hi, I have 925X Neo Platinum MB and I could manage to start my Azalia sound. But after MSI Live Update found new version of C-Media Azalia audio and I replaced my old version 5.12.01.0007 with the newest one 5.12.01.0008.60, the sound disappeared. After Rollback the driver to previous version, the sound works again. Please advise what to do? How can I check if the UAA Microsoft High Definition Audio is still installed?
MSI 975X PE, Ver.2.1
CPU E6600 (9x300=2,7GHz), ATI X1600/256/ HDMI
Supertalent T800UX2GC4 DDR2-800, Kit 2x1GB, 4-4-3-8 (at 750Hz)
OS MS Vista RTM 6000
rsd4_u
Newbie
Offline Offline
« Reply #27 on: 25 May 05, 13:41:40 »
I noticed  one thing while installing Azila driver and it really works atleast in my case ,just stick to the driver which come with ur mobo cd dont update ur audio driver until they fix bug ,Driver which come with mobo cd really works ..
subzero1266
Newbie
Offline Offline
« Reply #28 on: 02 June 05, 03:31:51 »
 Even I observed this problem. You have to run azalia setup using MSI Autorun to install it successfully. When I install it manually from the folder by executing setup, I dont get the Xear3D C-Media Control Panel (cmicnfg.cpl) at the tray but the sound works despite getting the message that the device is not found.
mitodna
Junior Member
Offline Offline
« Reply #29 on: 06 July 05, 14:03:52 »
hi, get the latest driver from MSI website if No Audio Hardware found after BIOS update
Clear CMOS first is recommended
mitodna
A64 3200+, MSI K8T Neo DEATH 2 times, MSI FX5200
myname70
Forum Ace
Offline Offline
« Reply #30 on: 10 July 05, 23:10:35 »
mitodna
I have Neo 925X mobo. How to clear CMOS? My BIOS version is the last - 1.50
Danny
Guest
« Reply #31 on: 10 July 05, 23:20:45 »
Page 2-22 in your manual.
SMeaGoLLuM
Newbie
Offline Offline
« Reply #32 on: 24 August 05, 13:49:40 »
Hi everybody;
I have same problem.  wall I bought Msi 7028 Neo2 Platinum (include Cmedia 9880 audio codec) mainboard. I use Win XP Sp2. Everything OK but I can't listen Tv audio. Line-in and microphone don't appear to mixer control.
I tried to setup Windows and different drivers, but it didn't work. I think, this problem is result from Cmedia audio codec or microsoft Hd audio bus driver.
I wait your help.
myname70
Forum Ace
Offline Offline
« Reply #33 on: 24 August 05, 17:34:04 »
Azalia driver works very well under Windows XP 64-bit version!
darkan9el
Junior Member
Offline Offline
« Reply #34 on: 14 October 05, 00:23:23 »
Thanks voodooghost, worked a treat on the 915P/G Neo2 Platinum. Though I didn't need the microsoft drivers and to be honest, finding them, is like looking for scotch mist.
lucianbara
Offline Offline
« Reply #35 on: 15 October 05, 09:06:56 »
I have the MSI 7058 Mainboard, the latest C-media drivers. My problem? I can't listen to music using the frontpanel. I've set the Sound to the frontpanel, plugged in the headphones, but nothing happens. I can hear a sound when its at maximum (like a silent Buzz), but no music. The Bios version is 1.8.
AMD 64 3000+ Winchester (no more Venice)
2*512MB DDR 400 Geil: 2.5-3-3-6
HDD 80GB WD Sata 2
Leadtek PX6600LE (8 pixel pipelines enabled)
LG DVD-RAM
Antec Smartpower 2.0 450W
omran
Newbie
Offline Offline
« Reply #36 on: 20 December 05, 13:07:54 »
I have the same problem as you do.... please, can anyone help us and support us with this problem?Huh? is something wrong with our Mainboard>Huh?? wall  wall  wall
My Driver Version is 5.12.0.0007.32
EtherealFist
Newbie
Offline Offline
« Reply #37 on: 13 September 08, 18:11:18 »
Thx god i found this !!!! thx alot
  Print
Jump to:
Page created in 0.303 seconds with 18 queries.
