Author Topic: [915 Series] MSI 915G COMBO  (Read 1277 times)
muzafar
« on: 16-August-05, 15:46:28 »
MSI 915G COMBO
P4 505J 2.66 GHZ
PC2100 ( 2x256 MBytes) (266 MHZ)
Video Build onto the Motherboard
Maxtor 6.4GB
LG 4120B DVD Multi-Format RAM Drive/Burner
PS 450W Generic with 24 PIN.
:sad:
No beep, and nothing is displaying on the screen. What should i do, thanks.?  Please help!!!!!!!!!!
:smiley:
Thanks to all.  I changed my Ram to DDR2 (500 MHZ), and i can see the display signal now.  I will continue to rebuild my computer, and i will let you know, if i stuck again.  Thanks again!!!!!!!!
« Last Edit: 18-August-05, 15:54:29 by muzafar »
Heath-N-PC
  • Platinum
  • Tier II - DS
Re: [915 Series] MSI 915G COMBO
« Reply #1 on: 16-August-05, 17:18:12 »
Your memory is not compatible with your mobo.
buy some memory that is either DDR333 or DDR400 (PC2700 or PC3200)
You should also upgrade you HDD, CPU, Video.
I've got a lot of PC stuff cheep if you’re interested.
Heath-N-PC
Presler Box
Clocked it up to @ 4.272GHz 1067fsb
fsb clock @ 267MHz, +12.5mV
system
MSI 955X Platinum (MS-7158-010)
Intel Pentum D 940 (Daul Core + 4megs Cash)
ZALMAN CNPS9500 LED - CPU @ 27C idle, 36C under load w/ OC
2X1gig GEIL Ultra DDR2 PC2-5400 1.8V-2.4V 3-4-4-8 @ 2.1V 667MHz 1:1.66
MSI nVIDIA 7900GT (MS-V801-045)
2 X Maxtor 40Gig SATA RAID 0
Enermax Liberty 500W (ELT500AWT)
12Va 22A, 12Vb 22A, 5V 30A, 3.3V 28A
Main Box
P4EE 3.2GHz w/2meg cash @ 800Mhz FSB
MSI 865PE Neo2 W/4X512Mb Kingston PC3200
BFG Ti4600 Asylum w/128Mb
P-SATA>WD 160GB 7200rpm SATA
P-IDE>Maxtor 80GB 7200rpm PATA
CM Jet4 HS&F: CPU Core Under load=39*C
Lite-On 16X DL DVD+-RW
NovJoe
  • Hawk
« Reply #2 on: 17-August-05, 08:59:33 »
PSU specs amps please.
MSI HQ Forum USB flasher
ayilliathroshan
« Reply #3 on: 17-August-05, 10:14:27 »
Nice to know a fellow 915G Combo user :biggthumbsup: . Pls tell psu specs so that we can see if it suitable for ur system
Din
« Reply #4 on: 17-August-05, 15:05:16 »
i think it's ram, or power supply problem.
