MSI Global
United Kingdom
Australia
U.S.A
Taiwan
China
Hong Kong
Arabia
Belgium
Croatia
Finland
Czech
Denmark
France
German
Hungary
Iceland
Italy
Japan
Korea
Latin America-Miami
Latin America-Miami
Netherlands
Norway
Poland
Russia
SICG
Slovenia
Spain
Sweden
Turkey
MSI HQ User to User Forum
09 February 10, 20:21:50
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
News
How do you flash your BIOS, please take part in our poll, thank you!
>>How do you flash?<<
Home
Help
Search
Login
Register
Mainboards
Intel P4/Celeron boards
(Moderators:
NovJoe
Mike
) > Topic:
WD SATA II Drive Solution to Via / SIS Comaptibility Problem
Pages: [
Go Down
« previous
next »
Print
Author
Topic: WD SATA II Drive Solution to Via / SIS Comaptibility Problem (Read 5137 times)
Danny
Guest
on:
03 September 05, 20:13:14 »
ckhelp55 in this
thread
has found a solution to WD SATA II hard drive incompatibilities with Via and SIS chipsets.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1337&p_created=1112379341&p_sid=JIANoCOh&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzkmcF9wcm9kcz05NSZwX2NhdHM9MCZwX3B2PTEuOTUmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1qdW1wZXIgc2V0dGluZ3M
*&p_li=&p_topview=1
kipi25
Newbie
Offline
Re: WD SATA II Drive Solution to Via / SIS Comaptibility Problem
Reply #1 on:
23 September 05, 15:52:09 »
And what should I do if this solution doesn't work?
Wonkanoby
Rankanoby!
Offline
Reply #2 on:
23 September 05, 15:54:08 »
If the OPT1 jumper setting does not resolve the issue, please contact Western Digital Support for further troubleshooting
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
rbarn00347
Newbie
Offline
Reply #3 on:
21 January 08, 22:26:04 »
Hopefully this is my problem, but cannot be sure just yet...I'm putting together a cobbled-together system from previous PC projects to replace a dying Dell, and I found a "bargain" refurb motherboard from Mwave, so I bit on their bait. After installing everything, my first boot revealed notes like "the system has changed" then "updating ESCD" was displayed, after which it hangs...no changes in setup has made any difference to this outcome, so I'll try the jumper setting change and see if that helps. Any suggestions from the forum would be welcome as this is my first MSI product, (and first time I've been foolish or cheap enough to try a refurb mobo) so it maybe MSI, but I'll defineately not try refurb mobos in the future!
MB:MSI 661FM3; ms 7082 ver 1; SIS 964 Chipset (refurb)
CPU: Intel P4 3.0Ghz, 800 FSB
2GB Generic 400 MHz value RAM
Sapphire ATI X1650 Pro AGP Video card
Sound Blaster Audigy Platinum 7.1 Audio card
Hercules 450 watt switching power supply
WD 250GB SATA Hard Drive
18X Lightscribe DVD drive
Generic Floppy Drive
resputant
Junior Member
Offline
Salman Maqsood - AKA Resputant
Reply #4 on:
10 March 08, 08:25:35 »
hi ppl
i have MSI K8T Neo2F-FIR mother board and 1.8 AMD athlon installd on it.
nao the problem is that i have two hard drives. one is 120GB Seagate which is IDE
and the other one is Western Digital Caviar SE 250 GB.
i have windows installed on both drives
when i boot with the WD SATA hard, the windows worrk perfectly fine and the second hard is compatible with it
but when i boot with the Seagate IDE hard, firstly the boot process gets very slow, and then the windows in seagate corrupts the file system in the SATA drive and the drive goes dead. all the partitions go corrupt.
after that the SATA individually dont work. i have to repartition the drive.
can anyone suggest me the solution to this problem?
is it the manufacturing problem in the board?
cauz i had the older version of the same motherboard Neo2 series MSI and the same problem wos present ther as well
plz plz help me out ppl. da data is important and ive lost it once but i cant keep on loosing it again and again.
plz help
waiting for replies
K8T Neo2 FIR
Athlon 64 3000+ (1.8 G)
Win XP SP2 + Windows Vista
1GB hynix dual channel DDR 400 @ 3-3-3-8 + 512Mb Samsung single channel
Quadro FX 1000 Graphic Card
120 GB seagate PATA + 200 GB WD + 80 GB Seagate
LG 4210 Super Drive + LG DVD Rom
Super Cool Fans
400W PSU
MSI TV Card
TP Link wireless network Adapter
3R system K100 casing
dworf13
Newbie
Offline
Reply #5 on:
20 July 08, 23:59:09 »
I recently had problems with my machine where it kept freezing during windows start up. I changed hard drives, managed a new XP instalation. But then it started freezing again. The last couple of tiems I turned it on, it wouldn't do anything except report a disc error.
I have removed every device in the machine, everything 1 by 1. Plugging only one thing in, but I get the same light on the d bracket every time. The error lights means 'Assign Resources to all ISA'. I have tried clearing the CMOS with and without devices in.
I also get a series of bleeps, which I think is 2 very quick bleeps, followed by 8 short bleeps
Wonkanoby
Rankanoby!
Offline
Reply #6 on:
21 July 08, 00:35:38 »
http://bioscentral.com/beepcodes/awardbeep.htm
your vga card i think
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
dworf13
Newbie
Offline
Reply #7 on:
21 July 08, 00:44:00 »
Even if I still get the same thing wihout the vga card plugged in?
T9246ED,大會編碼器
Online
Bas (Boss) killed Bosskiller! It's Svet now!
Reply #8 on:
21 July 08, 01:55:32 »
@dworf13
Read
Posting Guide
then open new own topic if you have some issue.
* MSI K8N D-Plus
i7 AMD Pentium 7 9200+
http://valid.x86-secret.com/show_oc.php?id=553583
* Corsair XMS 2GB Kit
* Corsair TX750W 3.3V/30A 5V/28A 12V/60A
* MSI 2xN260GTX-OC
Pages: [
Go Up
Print
Mainboards
(Moderators:
NovJoe
Mike
) > Topic:
« previous
next »
Jump to:
Please select a destination:
Forum News & Fun
=> Forum Info & News corner
=> MSI Red Rockets
=> Anything Under The Sun
Mainboards
=> AMD64 ATI/SiS/VIA boards
=> AMD64 nVidia boards
=> Intel Core I5 & I7 boards
=> Intel Core 2 Duo/Quad boards
=> Intel P4/Celeron boards
=> Server/workstation boards
=> Retired motherboards
Video
=> VGA products
=> TV Tuner products
BIOS
=> BIOS
Small Form Factor, Optical Drives and Other MSI Products
=> MSI Notebook
=> MSI PC series
=> Other MSI products
Technical Assistance
=> Good Articles Forum
=> Overclockers & Modding Corner
=> Off-Topic Technical
=> Windows 32bit
=> Windows 64bit
=> Linux/Unix
