Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 19:40:26 *
News: Do NOT use M-FLash for BIOS flashing! It kills boards!
>>USE THE FORUM FLASHER INSTEAD!! It's 100% safe!! Click me to get there!!<<
  Print
Author Topic: BIOS beep codes.  (Read 16230 times)
0 Members and 3 Guests are viewing this topic.
Din
Triple Ace
Offline Offline
-Dina-
« on: 12 September 05, 10:14:43 »
I see many users to confused on BIOS beep codes, so ill create a new topic with them (i search the forum for a topic like this but i didn't find anything, but if this topic exists just delete mine.)
AMI BIOS:
1 beep - System boot successfull
*1beep - Refresh failure - (NO VIDEO) memory refresh failure (bad memory)
2 beeps - Parity error - bad memory
3 beeps - Base 64K memory failure - bad memory
4 beeps - Timer not operational - bad motherboard
5 beeps - Processor error - bad processor
6 beeps - 8042 gate A20 failure - bad cpu or mainboard
7 beeps - Processor exception interput error - bad processor
8 beeps - Display memory read/write failure - bad video card or memory
9 beeps - ROM checksum error - bad BIOS
10 beeps - CMOS shutdown register read/write error - bad motherboard
11 beeps - Cache memory bad - bad CPU or motherboard
12 beeps - BIOS rom file incorrect size - The BIOS ROM file found does not match the size of the flash device
13 beeps - BIOS rom image mismatch - The BIOS ROM file layout configuration does not match image present in the flash device
5 short + 1 long beeps - Memory error - No memory detected in the memory slots.
6 short + 1 long beeps - Memory error - EDO memory detected in system
7 short + 1 long beeps - SMBUS error
AWARD BIOS:
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
*repeated beeps - DRAM error
*repeated short beeps - Power error
*Repeated high & low beeps - Processor is damaged/Overheated
PHOENIX BIOS:
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
« Last Edit: 12 September 05, 11:17:28 by Din » Logged
Celeron 2,4GHz Northwood - MSI 865Neo2-PFISR 3.A - Kingston KVR400 512MB Elpida - Abit ATi 9200SE-DT 128MB - SoundBlaster AudigyES - WD Caviar 40GB 7200rpm 8mb - Samsung CD-RW 52.32.52 - LG DVD-rom 52.16 - SuperFlower 400W 30A@3.3V 38A@5V 25A@12V - HEC 6A19 White Locked
Celeron D 325 - Gigabyte 8IPE1000-G F6 - Kingston KVR400 4x 256MB 1GBtotal - POV GeForceFX5200 128MB - WD Caviar 2x 20GB 7200+5400rpm - Samsung CD-RW 52.32.52 - LG DVD-rom 52.16 - Levicom 350XB-P R1.0 28A@3.3V 30A@5V 15A@12V - HEC 6A19 White Locked
Din
Triple Ace
Offline Offline
-Dina-
« Reply #1 on: 12 September 05, 11:05:23 »
NEC:
0200 - failure fixed disk
0210 - stuck key - reconnect keyboard
0211 - keyboard error              - reconnect keyboard
0212 - keyboard controller failed - reconnect & restart.
0213 - Keyboard locked
0220 - Monitor type does not match - Start the setup
0230 - System RAM failed at offset
0231 - >>         >>                  >>
0232 - Extended memory failed in address line
0233 - Memory mixing detected
0234 - Single bit ECC error
0235 - Multiple bit ECC error occured
0250 - System battery dead.
0251 - bad CMOS checksum
0260 - System timer error
0270 - Real time clock error.
0271 - check date and time setting
02B0 - A:\ error.
02B2 - A:\ incorrect
02D0 - system cache error cache disabled.
0B1B - PCI System error on bus/device/function
0B1C -  >>                >>                    >>
0B30 - FAN1 error
0B31 - FAN2 error
0B22 - Expasion ROM not initialize
0B50 - CPU #1 with error taken off line.
0B51 - CPU #2 with error taken off line.
0B5F - Forced to use cpu with error.
0B60 - DIMM group #1 disabled.
0B61 - DIMM group #2 disabled.
0B62 - DIMM group #3 disabled.
0B63 - DIMM group #4 disabled.
0B6F - DIMM group with error is enabled.
0B70 - The error occured during temp sensor reading.
0B75 - System voltage out of the range
0B7C - The error occured during fan sensor reading.
0BB0 - SMBIOS - SROM data read error.
0BB1 - SMBIOS - SROM bad checksum
0BD0 - 1st SMBUS device address not acknowledged
0BD1 - 1st SMBUS error detected
0BD2 - 1st SMBUS time out
0CC0 - ROMPilot reportserror number xx
          Expansion rom not initialized
          Invalid system configuration data
          System configuration data read error
          Resource confict
          System configuration data write error
          Warning: irq not configured
ant3202
Lord
Offline Offline
« Reply #2 on: 12 September 05, 11:37:52 »
any way thanks .. =) even thought it exist.. it would be a waste to delete this good article topic. I can refer here too for futere technical reference =). thanks .. well done .. goood job  biggthumbsup
MSI 865PE Neo 2 - S Mainboard
Intel Pentium 4 3.00Ghz
Kingston DDR 512MB - 400Mhz
MSI nVidia GeForce FX5500 256MB DDR AGP 8X
Maxtor 80GB HDD 7200RPM SATA
Power Supply ~  Antec Earthwatts 430
Samsung SyncMaster 152S
NovJoe
Offline Offline
~DeSTinY~ Destined 2 Be HeRe ^^
« Reply #3 on: 12 September 05, 17:21:21 »
Good Thread and a Sticky for you guys  biggthumbsup !
HTPC - DVI to HDMI for Panasonic 42" Plasma
512MB x 2 Kingston 333MHz, 250GB Seagate
MSI Wind with Love U100 Netbook
Intel Atom 1.6GHz, 2GB RAMs, 80GB HDD, 6 cells battery, WinXP SP3
HP Compaq V3136 Laptop - VGA to Sharp 32" LCD
Intel C2D 1.66GHz, 2GB RAMs, 80GB HDD, 3 cells battery, WinXP Media Centre SP3
Speakers:
Gigaworks S750, 7.1 Theater Surrond
Altec Lansing XA3501, 5.1 Gaming
MSI HQ Forum USB flasher
vronks
Junior Member
Offline Offline
« Reply #4 on: 02 November 05, 19:48:37 »
And When no beep happens? My mainboard it doesn beep anymore? Anyone here has a clue what problem could be happening?
Msi 875P Neo Series| P4 2.8 Prescott 1mb 800mhz | 1 Giga OCZ Gold 2-2-2-5(2x512mb)|Hd seagate 120G serial ata| Ati 9800 pro 128mb BBA | power suply 500w(Generic)
NovJoe
Offline Offline
« Reply #5 on: 05 November 05, 18:00:52 »
Could be motheboard problematic or PSU not able to supply power properly.
Btw, please open a new thread for your question instead of posting in the stickies.
Speakers:
nwheeler
Offline Offline
« Reply #6 on: 21 November 05, 14:03:26 »
I have a P4N Diamond (AMI BIOS) that is beeping as follows...1 beep, pause, 2 beeps, pause, 1 beep.
This sticky doesn't cover all motherboards, so would it be possible for some experts to post updates so that all of the newer boards are also covered?
Diamond Games Machine:
- MSI P4N Diamond
- Bios AMI rev 1.3
- P4 670 3.8GHz 2MB
- 2x Pairs Corsair TWIN2X1024A-5400UL
- XFX 7800GTX Extreme Edition 256MB
- Enermax EG701-AX 600W (SLi ready)
- 2x Hitachi T7K250 SATA-II drives
- 2x NEC ND-4550GNB DVD-RAM drives
- Windows XP Pro SP2
Also have Dell 8100 1.4GHz, Dell 8300 3.2GHz and Custom Athlon XP 3000+
mball
Newbie
Offline Offline
« Reply #7 on: 22 November 05, 20:08:58 »
I too have a beep code not listed with the P4N Diamond, I get 2 beeps then a pause the another two beeps. If I dont have the monitor switched on I get 3 beeps then a pause then another two beeps
P4N Diamond
Intel 840D 3.2GHz processor
2GB Crucial Balistix Memory
XFX nVidia GeForce 7800 Graphics GFX
4 x WD 150GB Drives in 2 nVidia RAID
Seasonic 600W PSU
AOpen DVD Writer
Sony DVD ROM
nelsinho2
Newbie
Offline Offline
« Reply #8 on: 23 November 05, 17:17:31 »
very, very good job man this is useful thanks
Din
Triple Ace
Offline Offline
-Dina-
« Reply #9 on: 26 November 05, 17:26:37 »
Im not a man, however don't post in this thread, except if you have more beep codes to place in this thread Smiley
NovJoe
Offline Offline
« Reply #10 on: 28 November 05, 14:55:52 »
Dear Friends and Fellow Members,
In order to keep this thread clean and clear, I'm going to lock this sticky thread for good. Wink
If anyone has ay updates, please kindly PM me or drop me a mail with your Forum Nick and I'll help you to add the info in. biggthumbsup
Regards,
Joe Chow.
Speakers:
NovJoe
Offline Offline
« Reply #11 on: 15 March 08, 04:00:21 »
A new piece of useful info by djcs on hardware diagnostic testers:
Something that could be added to the beep codes forum
http://search.ebay.com.au/search/search.dll?from=R40&_trksid=m37&satitle=motherboard+tester&category0=
i have found them very helpful....
if you do a search on ebay for just motherboards, you can find isa and usb based testers too....
djcs
Speakers:
  Print
Jump to:
Page created in 0.354 seconds with 19 queries.
