Author Topic: k8n msi motherboard will not enter bios  (Read 1210 times)
coasterd
« on: 04-January-06, 02:11:41 »
Ok here is the hardware in the case at the moment
K8n mobo (neo plat)
3000 64 CPU
ati rage 128b (test only tried a700)
1GB Crucual Ram
Antec True Power 380W
All I get is five short beeps, I have reset cmos and still nothing
Please help me :(
If you need more info I'll post it
nmea2020
  • Easy OC
Re: k8n msi motherboard will not enter bios
« Reply #1 on: 04-January-06, 02:19:33 »
Double check your video card. Is it seated completly?
Take it out . Of course diconnect power first then reseat the Video
Try booting with only 1 stick of ram
Let us know how this turns out
coasterd
« Reply #2 on: 04-January-06, 02:21:43 »
Thanks for getting back
Only one stick of ram (1GB)
Tried 3 different graphic cards
All I get is 5 short beeps, what does this mean? :bonk:
nmea2020
  • Easy OC
« Reply #3 on: 04-January-06, 02:35:35 »
On second thought go to your local pc guy and DEMAND an INTEL based system. MSI puts out some really nice P4 and P5 stuff
I really think you can't go wrong.  You can't say i didn't try.
coasterd
« Reply #4 on: 04-January-06, 02:37:40 »
Might have been an idea.  Since I am stuck with what I have, and money is an issue, any ideas of what is wrong with the setup I do have?
Cheers
workknot
  • Platinum
« Reply #5 on: 04-January-06, 04:08:29 »
It would be a good idea to post a signature with all of your equipment listed. It could be you are a little short on power, what is the voltage on the 12 volt rails of your power supply?
Pop's
MSI K8N Neo4 Platinum Ultra 7125-010 Bios 1.6
AMD 64 4000+ San Diego
MSI NX6600GT TD128E
Aspire X-Plorer Case
OCZ Modstream 520 W, 3.3@28a, +5@52a, +12@28a
OCZ 2GB Kit DDR400 @ 2-3-2-5  1T
LiteOn DVD-RW LiteOn CD-RW
Sony FDD
WD 36.7 Sata Raptor No RAID
XP Pro SlipStreamed SP2
Samsung 17" LCD
Rig 2
Raidmax Tower
Corsair PSU 550 Watt
MSI K9A2 Neo-F
AMD 5400 @ 2.8 GHZ
Corsair Memory 2GB DDR2 800
MSI N9600GSO T2D384 OC
WD Raptor 36.7 GB
LiteOn DVDRW SHW-160P6S04C
Sony FDD
Win XP SP3
Acer 22" Widescreen
syar2003
  • HydroGen
« Reply #6 on: 04-January-06, 04:22:19 »
Try with only a old style ps2 keyboard directly connected to the purple ps2 port (no fancy stuff with f-lock keys and such) , no mouse .
No usb connected , power off completely and on again (switch off and disconnect AC , and connect back , switch on )
MainPC:
Opteron 170 @ 2.7ghz
Zalman CNPS9500
DFI LP NF4 SLI-DR
OCZ EL DDR PC-4000 XTC Platinum 2GB @ DDR500 3-3-3-8 1T
ATI X800XL
LiteOn 811S (DVD RW)
2xSeagate sata II 7200.10 320G
1xSeagate sata I 7200.7 120G
Enermax 465 Single +12v 33A
Win Vista Ultimate 32bits
SecondaryPC:
Athlon64 3200+
MSI K8N Neo Platinum
Crucial 6464Z40B 2*512MB
Swiftech MCX64
Gainward nv-5900
Maxtor 80/120 GB DM9+ sata
OCZ Modsteam 520
Third PC (HTPC):
Thermaltake Bach VB8001BNS
Abit NF7-S v.20 , Nforce2 Ultra 400
Athlon XP 2400 M (AXMD2400FJQ4C) @ 12x200 2.4ghz
Patriot 2*512MB XBLK running 2-2-2-5 in dual chl
Ati Sapphire Radeon9600XT -256MB
Maxtor DM9 SATA 120GB/8MB
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
coasterd
« Reply #7 on: 04-January-06, 04:57:46 »
Pop's
The Psu is an antec 380W
These are the readings
for the 12v rail its 24A  if thats what you needed
The beeps may well have been down to the fancy case, a bog standard case gives me NO BEEPS
If I keep in the memory, video card and cpu with HSF the system shuts down after around 15 secs
If I take out the memory and remove CPU the system stays on but no beeps, no boot
« Last Edit: 04-January-06, 05:00:57 by coasterd »
coasterd
« Reply #8 on: 04-January-06, 04:59:36 »
nada :(
syar2003
  • HydroGen
« Reply #9 on: 04-January-06, 05:17:03 »
Have you connected all the extra power connectors to the motherboard .
MSI Reminds You...
• All power connectors, ATX1 (24 Pin) & JPW1 (4 Pin, for CPU Power) & PCIE_PW1 (4 pin, for PCI-E VGA) must be attached to this model to ensure operation of the Mainboard.
• A Power Supply of 450 watts, or above, is highly recommended for system stability.
• ATX 12V power connection should be 20A or greater.
This is the recommendation for the "newer" K8N boards , not sure which model you have as there are 12 different boards now starting with K8N in their name .
In your spec it's best to use the MS-XXXX product version number in future posts .
MainPC:
Zalman CNPS9500
DFI LP NF4 SLI-DR
ATI X800XL
SecondaryPC:
Athlon64 3200+
Swiftech MCX64
Gainward nv-5900
OCZ Modsteam 520
Third PC (HTPC):
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
coasterd
« Reply #10 on: 04-January-06, 05:29:00 »
sorry about that, yes you are right
Its slightly older its the MS7030-V1
Tried running barebones with
AGP/mem/cpu
PCI video
And connected the 4 pin and 20 pin power cables
Thank you for getting back :)
syar2003
  • HydroGen
« Reply #11 on: 04-January-06, 05:54:24 »
Okay then .
From what I remember from a year back or so , there was several having problems with the boad not detecting certain ATI cards .
Involved olies like rage , 7000, and perhaps also 8500 .
Some could solve it by booting with other gfx card and bump up the agp voltage to 1.60v in bios , then change back.
If the board don't detect/get the AGP card activated post will halt .
Reason I think is the stupid MSI bios automaticly overclock gfx cards (hidden nv/ati speedup setting in bios)  , so with a mainstreem , low end card you might just
end up with a non posting system like you do.
Thats also perhaps why upping agp voltage to 1.60v was a workaround.
Try with a old pci gfx card if you can preferably not from ati , or even a nvidia MX2/geforce2/GForce3 AGP4x and  I'll bet it will post .
MainPC:
Zalman CNPS9500
DFI LP NF4 SLI-DR
ATI X800XL
SecondaryPC:
Athlon64 3200+
Swiftech MCX64
Gainward nv-5900
OCZ Modsteam 520
Third PC (HTPC):
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
coasterd
« Reply #12 on: 04-January-06, 06:31:17 »
Still nothing..
My last shot is a new cmos battery - is this a known fault with this earlier board?  I have seen some problems with the Neo4 posted
syar2003
  • HydroGen
« Reply #13 on: 04-January-06, 06:46:29 »
What version is your 3000+ cpu ?
You might need a more resent bios loaded on your board if its the Rev.E 90nm based 754 3000+. The one called ADA3000BXBOX for socket 754 is 90nm revision E .
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_cpu_support_detail.php?UID=572&kind=1
Cpu support from version 7030 bios 2.1.
I guess it's hard for you to know what version the board is loaded with.
But if you bought both cpu & mobo from the same retailer you could demand that they set it straight for you .
MainPC:
Zalman CNPS9500
DFI LP NF4 SLI-DR
ATI X800XL
SecondaryPC:
Athlon64 3200+
Swiftech MCX64
Gainward nv-5900
OCZ Modsteam 520
Third PC (HTPC):
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
JayBee
  • Big Bang
  • Space
« Reply #14 on: 04-January-06, 07:16:23 »
CPU-Z program (under CPU tab) should tell you what revision you have for your processor.
K8N Neo2 Plat. (MSI-7025) - WinXP Pro SP2
Athlon 64 Manchester X2 3800+
2x OCZ4001024ELDCPE-K
PNY NVIDIA GeForce 6600 GT
CoolerMaster Hyper 6+ CPU Cooler - Antec P160 case - Belkin KVM switch
Plextor DVDR PX-716A
PATA Maxtor 6L100P0 & SATA Western Digital 1600JD-40HBC0
AWARD BIOS V1.CB3 EasyBIOS3 (R.2) BY SYAR
OCZ 420ADJ - 28A(3.3v); 30A(5v); 30A(12v)
(Machine #2)
coasterd
« Reply #15 on: 04-January-06, 07:41:27 »
honestly everyone I think you are all great.  The amount of help I have got with this has been great, espicially in such a short time.  You were with me throughout the night so i was not alone with the problem.
Things are starting to happen now.  I now get long beeps which loop, they just keep going (single long beep)
I have a single crucual 3200 DDR 400 - 1GB memory stick and have tried all slots.
I'll get you that CPU make when I strip off the HSF
Any suggestions now with the strange beeps - from what I have read its memory related, but could it be something else.
Thanks again
syar2003
  • HydroGen
« Reply #16 on: 04-January-06, 07:49:32 »
MainPC:
Zalman CNPS9500
DFI LP NF4 SLI-DR
ATI X800XL
SecondaryPC:
Athlon64 3200+
Swiftech MCX64
Gainward nv-5900
OCZ Modsteam 520
Third PC (HTPC):
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
coasterd
« Reply #17 on: 04-January-06, 07:54:43 »
The pheonix bios has nothing stated for continuous long beeps, the award one does.
The bios chip on my mobo clearly states its a pheonix, so thats confusing :(
syar2003
  • HydroGen
« Reply #18 on: 04-January-06, 08:12:29 »
Try with some generic cheap pc2100/pc2700 ram 256/512MB if you have something to try with .
Theese things has also caused non post situations:
Disconnect all "case" fans that might be on the mobos additional fan headers , leave just cpu fan running from mobo.
Disconnect from mobos FPIO header all but the power switch and reset , disconnect pwr-led and  hd-led connectors etc.
Disconnect pc-case front usb ports going to mobo header JUSB1/JUSB2 (and firewire if you have that).
MainPC:
Zalman CNPS9500
DFI LP NF4 SLI-DR
ATI X800XL
SecondaryPC:
Athlon64 3200+
Swiftech MCX64
Gainward nv-5900
OCZ Modsteam 520
Third PC (HTPC):
X-FI Music ed.
NEC 3550
Hauppauge 500 MCE
Tagan480 U001
MCE2005
ViewSonic LCD TV
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #19 on: 04-January-06, 20:19:28 »
did you barebones everything *outside* the case?
do you have a D-Bracket? if so, what does it indicate?
D-Bracket LED explained
