Author Topic: b150 gaming m3  (Read 708 times)
kuya_gembelTopic starter
b150 gaming m3
« on: 07-September-17, 05:30:13 »
hi .
im using motherboards b150 gaming m3
windows 10 pro 64bit + i7 6700
already upgrade bios b.10
i want upgrade from samsung ssd 850 pro to nvme m2 950 pro for booting
is that compatible??
thanks .
shalala
  • FIRST LIEUTENANT
« Reply #1 on: 08-September-17, 06:12:22 »
Hello :-))
https://www.msi.com/Motherboard/B150-GAMING-M3/Specification
According to the specification of this motherboard, it only supports SATA interface M.2!
« Reply #2 on: 13-September-17, 07:32:20 »
thanks before :hypocrite: .
but if i change to z170a tomahawk . can compatible??
shalala
  • FIRST LIEUTENANT
« Reply #3 on: 14-September-17, 01:01:31 »
There should be no problem!
And it's on the support list woohoo~~~
https://www.msi.com/Motherboard/support/Z170A-TOMAHAWK#support-hdd
« Reply #4 on: 14-September-17, 07:23:50 »
alright .
it will be great
thanks a lot for the support :party:
shalala
  • FIRST LIEUTENANT
« Reply #5 on: 14-September-17, 08:01:16 »
You are very welcome :beerchug:
