Author Topic: Want to buy MSI X370 GAMING PRO Ram questions  (Read 502 times)
nicklastoftegaard1337Topic starter
« on: 13-September-17, 11:38:53 »
Hello guys I have looked on the QVL site, but when I find the ram i want or the brand. then they're kinda over my budget, so I'd like to know if these:  F4-3200C14D-16GFX will be okay to use, or I only should use some from the Supported memory list. Thanks in advance :)
plutomate
  • LIEUTENANT COLONEL
« Reply #1 on: 14-September-17, 06:43:11 »
the memory in QVL simply means MSI has the RAM in hand to test, it doesn't mean MSI board only supports RAM on the QVL.
The RAM you list is AMD compatible so it should most likely work, but overclocking to 3200MHz is really up to your CPU IMC....hitting 2933 Mhz should be without any problem tho :)
