I recently RMA'd a Gaming 5 motherboard and after receiving the replacement I'm still having the same problem that I had initially. As with the last board, the standby LED does not light up once the power supply is switched on prior to trying to power up with the case button. When I do try to power up, the system will briefly light up for a second and then power off immediately. I am able to see a '00' code on the mother board but I'm wondering if the short power up is not enough time for it generate a correct code.
I've tried a large number of methods to trouble shoot listed below:
Plugged the PSU into another mobo and confirmed that it could power up the system
Removed and tested each memory module individually
Reseated the CPU multiple times
checked the case connectors for the power switch to ensure they were put on correctly
removed the GPU and attempted to start up
shorted out the CMOS battery to try and reset the BIOS
Any suggestions at this stage would be helpful. I'm starting to believe it's either the processor or RAM but the lack of a standby LED has me wondering if I've gotten a second dud in a row.
