11x USB 3.2 outputs on motherboard header how to use connect all of the USB outputs?
Status
Not open for further replies.
unrealone15c802e1
Is there a product to out put all of the USB headers on the Motherboard to the case?
MSI MPG X570S CARBON MAX WIFI Motherboard 8x SATA3, 8x USB 3.1/
Well just a heads-up, not all of them are USB 3.1, they are 4x USB 3.2 Gen1 and 4x USB 2.0.
16 usb in total, Unable to find a product to install in the front of case to out put the header usb's?
technically its 19 USB Ports as there are 10 on the rear and headers on the inside for another 9 ports that vary.
AMD X570 Chipset
1x USB 3.2 Gen 2 10Gbps Type-C internal connector <-- thats the single USB-C metal surrounded connector below the 24pin power Connector
4x USB 3.2 Gen 1 5Gbps ports are available through internal USB connectors <--- there the 2 USB 3.0 style 20-Pin Headers on the board
2x USB 2.0 ports on the back panel <-- thats the 2 Black Ports on the Rear I/O
Asmedia® 1074 Chipset
4x USB 3.2 Gen 1 5Gbps Type-A ports on the back panel <--- thats the 4 Blue Ports on the Rear I/O
GL850G Hub
4x USB 2.0 ports are available through the internal USB connectors <--- there the 2 lower USB 2.0 9-Pin Headers on the board
AMD Processor
4x USB 3.2 Gen 2 10Gbps ports (3 Type-A ports and 1 Type-C port on the back panel <-- thats the single USB-C on the Rear I/O and the 3 RED Ports on the Rear
thats a Total of 19 Ports
1+4+2+4+4+4=19
made up of
6 x 2.0 ports
8 x USB 3.2 gen 1 5GB/s Ports
3 x USB 3.2 Gen 2 ports
2 x USB C Ports
you can buy USB header to either PCI-E or 3.5 inch bay adapters to get the Headers connected to the board if you want that as there are 5 internal Headers to populate
if you use that from the looks of it you will get 8 ports on the front but each one of each half (4 ports) is sharing the bandwidth of 5Gb/s so if you connected all full 3.0 type 5Gb/s devices to it they would if you hit all at once only have 1.25 Gb/s each but should work
MSi does not have an official front panel for the mother board headers? Using maximum outputs?
the Internal Headers Relies on the PC Case to have the Connections for the ports. you would have to find a Case with 4 USB 2.0 Ports and 4 USB 3.0 ports and a USB-C port on the front of the Case.
Why be restricted to the "one" case when all we need is an MSi header cable to the front panel?
Because the Headers are for Multiple Layouts depending on what people want to use them for.
the USB Headers some people will use them for other Devices like SD Card Readers, Audio Outputs, extra Network Connections, readouts for device temps to external Screens and so on.
you then decide what you want and then you get a case or PCI-E Brackets or bay adapters that have the outputs you want not everyone want all the USB outputs and some may only use one header and the rest will be unused.
what you want is a very low use case (like less then 1/50,000 people would want that) so no way would and manufacturer of a board make or supply that as its overly Niche thing. go out there and see if you can prove me Wrong i will be waiting for your answer when you find any manufacturer that supply's one (will expect that maybe 35,000 years after i have ended my existence).
All I am asking is for is a_ _
" MSi does not have an official front panel for the mother board headers? Using maximum outputs? "
MSi have Zero product sold "separately" to utilize motherboard output options?
Why put the header options on the motherboard if I cannot find a separate product to output to the front panel ?
I did not ask for a manufacture to supply ALL possible cables in the BOX.
After market sold separately front panel usb to motherboard output connector
WHY do people BUY 10 output USB hubs? How many are sold?
What your asking about is no MSI don't make any thing like that but others aftermarket manufacturers supply them items.
Search for
ICY BOX USB Front Panel HUB
The Elephant in the room is why do people buy unnecessary 10 USB external hubs when the motherboard has 19 USB slots?
This product comes close to using all the motherboard headers
8 Ports USB 3.0 19-Pin Hub Optical Drive Extension Front Panel For Computer
https://www.ebay.com.au/itm/234179363915
Kingwin Front Panel USB 3.0 Hub 7 Port & One Fast Charging USB 2.1A Charging Port
https://www.amazon.com/Kingwin-Include-Charging-Transfer-Computer/dp/B01AJTOLRY/
like i said with that one it splits out one Pair of USB 3.0 style connections (2x5Gb/s) to 8 ports so each side of 4 share a single 5Gb/s Link. the one dvair listed uses 1 pair of USB 3.1 gen ones (Same as USB 3.0) connection Pair or 2x5Gb/s a USB-C connector and a Pair of USB 2.0 Connections. the one you listed is just a Internal Dual USB Hub (2 4port USB 3.0 ports split of a single ports bandwidth per 4)
Thanks you are correct its just a splitter but that is the only one I can find.
This is exactly why i was hoping MSi would have a recommend quality verified Header front panel USB connector,
This card is amazing so much power full circuitry.
MZHOU 7 Port PCI Express Expansion Card, USB 3.0 7 Port Front Expansion Card, Connect 7 Devices Expanded
https://www.amazon.com/dp/B09WYHRPTT/There is no front panel header 8 output that uses all the header outputs running to the front panel?
That MSi can recommend?
what Case do you have as it will be more easy to recommend stuff if we know what your case will take up? so what case you have?
The case is irrelevant if a header cable that supports all the motherboard outputs to the front panel does not exist?
Can MSi recommend a quality verified Header front panel USB connector, 8 ports?
without Knowing the Case its IMPOSSIBLE TO RECOMMEND ANYTHING its Due to what type of thing will fit in the Case does the case its in have any 5 1/4 bays does it have any 3.5 inch Bays, does the case have its own USB 2.0 front Panel Connector, Does it have its own USB 3.0 Front Panel Connector, Does it have its own USB-C Front Panel Connector its not Irrelevant its Needed to know what the hell to recommend as what does your case Need.
We are not Mind Readers we do not have a Crystal Ball all we have is what you tell us and everything you have said is Vague as hell and I'm trying to work out even what to Recommend as you have only told us what Board you have and Nothing else how can we recommend anything like that please give us something for us to go off so we know what will even work here as just i want a front panel with the ports i want is not helpful as we have no clue what will fit in the PC Case you have as there have been Millions of them and they Vary alot on what they support?
Standard ATX case front panel, what don't you understand about that?
I would like to run "ALL" the motherboard output headers to the "standard" ATX case front panel.
Most MSi boards for AMD have 11 USB outputs.
Status
