DrySaucisse
- Mar 31, 2017
Hello all!
I have concerns about my 13700K frequencies and Cinebench score.
First of all, here is my build:
I recently noticed high temperatures on my 13700K (they may have been there for a while honestly, I did not run any Cinebench R23 before with this build).
When I start the benchmark, temperatures go to 100°C almost instantly.
So I stumbled upon many threads about undervolting. This is what I changed in the BIOS:
My temperatures dropped to about ~85°C while running the benchmark, and my CB R23 Score is around 29k+, which I find a bit low compared to the ~30-31k I see online.
Also, while running at full load, my frequencies are lower than they should be according to Intel specs:
I've ordered TG Kryonaut thermal paste and a Thermalright contact frame to see if it can help with the temperatures... I should get them by tomorrow.
Here is my HWiNFO while running Cinebench R23:
Do you think I have a hardware issue here?
Thanks in advance!
- CPU: Intel Core i7 13700K
- Motherboard: MSI z790 Tomahawk WiFi DDR5
- RAM: G.Skill 32 Go DDR5-6000
- CPU Cooler: Noctua NH-D15
- Thermal Paste: Arctic MX-4
- Case: Fractal Torrent
- PL1, PL2 to 253W
- ICCMax to 307A
- Turbo Enhance Disabled
- IA CEP Disabled*
- CPU Lite Load Mode 6
- CPU VR Voltage Limit 1.400
- P-Core: 5.087 Ghz (all of them, but they should go to 5.4Ghz); sometimes while out of the benchmark I have two cores at 5.387 Ghz.
- E-Core: 3.990 Ghz (should be at 4.190 Ghz, they are at 4.090 out of benchmark).
Thanks in advance!
