2070 Super - One fan is always on and is loud.
How to turn off this fan or configure it to turn on when it hits a certain temperature? Been messing around in msi afterburner and nothing seems to work.
Active member
Administrator
Which GPU model exactly is this?
Active member
Administrator
Got it, which fan is stuck?
and what others 2 fans did when the other one stuck?
The other two fans are just idle until I play some games and the temperature increases but the middle one seems to always be off. The right fan is always on, its only when i restart my computer its off but after like 5 minutes its on again.
Try to reseat the card so it is not bening or sagging. If already using the support bracket make sure it does not block the fan. If all doesn´t help rma the card.
