RABAH1991
RabahRambo
- Aug 9, 2017
I have an MSI gaming x trio 3090, and i was trying to overclock it using MSI afterburner. I did the OC scanner, and got stable values about 76Mhz CC and 200Mhz MC . The thing is, these values always reset to 'Zero' after some time, 30min/20min, not a fixed time. What can be the problem ? and how can i fix this ?
P.S. I used to have an AORUS Master X570 and didnt have this problem. The reason i changed the mobo is because of the headache of dealing with multiple apps.
Overclock values:
Overclock values:
CC: 75Mhz
MC: 200Mhz
Power limit: 102% (Also did the test on 100%)
Fan speed: 80%
CV: +50%
- PC spec:
- CPU: AMD Ryzen 5800X3D
- Mobo: MSI x570S Carbon Max WiFi
- Memory: 16x2 3600Mhz cl14
- GPU: MSI GAMING X TRIO 3090
