3090 Ventus. Problem with a second monitor
gorinic155f02e2
Hi all,
Using a double-monitor setup. Primary is a BENQ connected via DP and a secondary is a Samsung TV attached with a HDMI. Sometimes Samsung turns off and on and can't catch a signal from GPU right after that. DDUing drivers and NVIDIA drivers clean install helps, but after some time the issues returns. BTW this never happens during gaming or GPU stress-tests, mostly while watching YT or video files on a Samsung screen.
What are your thoughts?
Administrator
Try different GPU drivers,
try reverse the display and retest or test the Samsung alone to isolate the issue.
Administrator
reverse their places make samsung primary and other monitor sencodary
