322UR X24 Presence sensor - System Mode no longer working Win11
dogodile
Either after a windows update, or the latest AI sensor firmware updates, the presence sensing no longer works in system mode (at least for me) The PC will not lock when walking away.
Just a heads up if you use this mode switch to Monitor mode, or your screen will stay on for extended periods of time.
Interestingly enough after playing with the setting and toggling it back and forth I can't even see and presence settings in the windows settings anymore. I can still access the monitor using MSI Gaming intelligence.
Win 11 10.0.26200 Build 26200
...also when are we getting anti-flicker pro?
-Dogo
Fauc,
While it is mentioned in the manual, it is not implemented in the firmware, or there is some dependency not mentioned.
It does not show in the menu in firmware .012 .
