4.4 firmware for Me Prime 8 Tablet
AllanA
Hello guys,i have a Me Prime 8 Tablet which is exactly same looks and specs as the MSI Primo 81 tablet. I tried flashing the 4.4 update firmware of the MSI Primo 81 tablet on my Me Prime 8 tablet and it worked! Only proble is that the screen orientation and the gsensor is not working.Is there a fix on it?and also is there any other firmware which is suitable for my tablet?hoping you guys can help me.thanks in advance.
Nichrome
Active member
Bump removed. Please read forum rules.
Try to flash back to the original that was designed for your tablet, not for the only one. There had been a reason of making 8 and 8.1 different.
AllanA
ok sir,thanks.luckily i have a stock rom.just wanna try the 4.4 update.i guess i'll have to google for other similar 4.4 firmware that might work on my tablet.
KurtC27
SECOND LIEUTENANT
Me Prime 8 Tablet is not MSI brand product through it's a OEM/ODM product by MSI.
You should contact ME Mobile instead not asking a new FW update here.
monster6536
Hello Allan!
Can you please share the stock firmware of your tablet. I wasn't able to backup mine. And there is no firmware available for this online.
I hope you will read this message.
