5700xt msi evoke ramping up to 3000rpm fans + 113c while playing control?
getbornagain
PRIVATE FIRST CLASS
is this what you would normally expect from it? It was during a cutscene of people sat around a desk. I have it undervolted/underclocked to 1850/920 already. The fan curve is set to max at 40% but it just flies up to 3000rpm anyway.
Administrator
Nope, looks like somethings is wrong with it.
RMA it to get it fixed
What temps can be expected approx. you can see here:
getbornagain
PRIVATE FIRST CLASS
Is there an easy way to record a brief section of gameplay/with the temps on screen? I'd like better evidence of it before I raise any ticket with the manufactuer or retailer.
Alan J T
GRUMPY OLD FART
Software is built in to the AMD software look for Metrics in the performance tab. I also think it will record for you as well not tried it so not sure how it works.
Administrator
You can do simple with GPU-Z to log the temp.
Or to check the max(highest) GPU temp after the gameplay.
