Hi everyone,
System:
MSI 970 Gaming on Stock-BIOS (22.0)
AMD FX-8320 CPU
AMD Radeon HD 7850 GPU
Enermax Pro 82+ 525 Watts PSU
running on Windows 8.1 Pro x64
system stability double-checked with same-time-running prime95 with lucas-lehmer iterations and furmark...
first problem:
After having about 30-60 Minutes of sound (very randomly), the keyboard, the mouse, and a connected XBOX 360 wireless gaming controller is disabled and mouse-cursor stopped while picture (animated smileys, playing videos aso) are still working. Sound is either disabled or with a fuzzy noise when the input-freeze is coming.
So everything seems like a driver-issue.
BUT - I uninstalled all Realtek Sound drivers from the system and the problem still exists. Wenn sound is playing the input is disabled randomly in 30-60 minutes.
So now it seems like a Southbridge issue...
Therefore - I contacted MSI support who told me to do a BIOS/UEFI-update.
Which leads us to....
second problem:
Entering UEFI, checking "Windows 8 Mode" is off (MSI-support told me in a roundabout way they hid "secure boot" in it) - but it was disabled by default.
Then I enter M-Flash in UEFI and fistly backup my BIOS/UEFI on a FAT-formatted stick. That worked, BIOS is saved on the stick, but only if I change the default filename.
According to Youtube-Videos like watch?v=1Z76WuN8eTg (can't post external links) the progress bar that appeared while doing a backup of my current BIOS should appear after selecting the Update-file on the FAT-formatted USB-Stick. - But that progress bar never appears. Instead of that the UEFI is frozen until I force-reboot. Then the system still has the old BIOS/UEFI-version.
Contacted MSI-support again, they told me to do it the old fashioned way through a DOS-System. They lead me to that howto forum-de .msi. com /index.php?page=Thread&threadID=54314 (can't post external links) - Problem: I can't register an account in the german MSI-forum to download all the files.
Coming back to this forum a MSI HQ tool is found https://forum-en.msi.com/index.php?topic=116721.0
Following their HowTo leads me to an USB-stick which seems to have the firmware and a DOS-system on it, memtest is somehow skipped, so I checked RAM for myself - RAM is working fine. I can boot from this stick - and I can select to update the BIOS.
But that's all - The screen messages stop at "Preparing to backup current BIOS..."
Therefore - I can't even do a BIOS-Update to follow the instructions given by the MSI E-Mail-support for germany to get a little bit nearer to my sound/input/southbridge/audio-driver issue.
The system runs stable except the sound/southbridge-issue. I tested it while running Furmark and prime95 at the same time. The system ran stable for about 2 hours, so I guess it's not a PSU or CPU/GPU-problem...
Any help for my two problems?
I don't know what I can do further to get into that issue because the sound/input issue also appears when running stock windows audio drivers...
System:
AMD FX-8320 CPU
first problem:
second problem:
