A few questions
passive trip points. enabled or disabled. which is better?
ENABLED, this is imperative to have this enabled, since your laptop might then go to CRITICAL and no one wants that, so this is why we lower the voltage to the CPU,
reduce power inputs on PL1/PL2, to postpone or avoid Passive trip point from throttling the CPU, but must remain as a safeguard, just in case.
Keep in mind this is a GUIDE not a written in stone MANUAL feel free to modify this if your laptop performs better with slight changes to these values.
So as you can see the 1st picture is the monitor for MULTI PLAYER FPS & TPS Shooters and CPU intensive games.
GAMES: CSGO, MS Flight Simulator, Far Cry 5, ARMA 3, Warhammer, Watch Dog Legion, Multi Player games.
Keep in mind you only want to use these settings to be performing the best frame rates possible for your games and still be able to game without worries.
So for your i9 go for High Performance : CORE 0,1 49/49, CORE 2/3 46/46, CORE 4/5 45/45, CORE 6/7 44/44, the first 2 cores are the most important.
You want to set PL1/PL2 to 65/75 same as in the BIOS I send to you previously as maximum possible, since you have an i9.
Of course you only want to set this for multi player online games, nothing other than this, if you want that edge performance.,
You want to make sure High Performance is checked, so that W11 and TS will make sure CPU is a priority.
EDIT: Forgot to mention, your AC Loadline should be 140 for an i9 (i7 130)
So for i7 13620H go for High Performance : CORE 0,1 49/49, CORE 2/3 46/46, CORE 4/5 45/45, CORE 6/7 44/44.
You want to set PL1/PL2 to 65/72 same as in the BIOS.
So for i7 12700H go for High Performance : CORE 0,1 47/47, CORE 2/3 45/45, CORE 4/5 44/44, CORE 6/7 43/43.
You want to set PL1/PL2 to 58/68 same as in the BIOS.
So for i7 10750H go for High Performance : CORE 0,1 49/49, CORE 2/3 46/46, CORE 4/5 45/45, CORE 6/7 44/44.
You want to set PL1/PL2 to 50/60 same as in the BIOS.
So for i7 9750H go for High Performance : CORE 0,1 45/45, CORE 2/3 43/43, CORE 4/5 42/42, CORE 6/7 41/41.
You want to set PL1/PL2 to 45/55 same as in the BIOS.
If you want settings for i7 8565U, i7 7700HQ, i7 6700HQ send me a message or reply to this post.
Hi could you send the settings for a 13980HX please ?
Thank you.
@drek4 How many years you've sent PM to this community forum, I wonder what is this PM you've got? I appreciate if u send it and check if undervolt is real or not for 12th gen mobile.​
The only way I figure out is I tried to reduce this i7-12700h on bios by "VR current limit" from 0 (default 1.6v) to 1050 (1.05v) that reduce a lot of temperature like 40°C instead ~70°C idle as well as PL1/PL2 (default 200w) turns to be limited by itself around ~35w without tuning it. In exchange for that efficency, the performance goes from 4.6 Ghz P core to 3.5-3.7 Ghz as well as E cores too.​
Interesting enough I found another way to gain slightly performance by tweaking AC/DC loadline from default 230 to 140 on both sides AC & DC ( ) for more details.​
I sent you a PM for your i7 12700H, to show you what worked for mine, if it can be of help!
Remember to only use one option, either Undervolt, Voltage restricion or AC Loadline, if not your system will not be stable,
thus chances of crashes, freezes or blue screens, will increase dramatically.
I did everything according to your instructions. Thank you. BIOS is the latest installed. Version E17T2IMS.110
@drek4 thx, so basically it a same thing I suggested, except u didn't suggest me "VR current limit" like this guy "narva.196153c02d7" did tweaking on 1120 (probably that goes around ~4.3Ghz P core). in fact it's crazy by default reach around 1.4v or even more for 4.6ghz peak instead of limited 1.12v to reach ~4.3ghz which why CPU throttling occurs...​
However "VR current limit" with AC/DC loadline both doesn't crash out or bluescreen or anything, since I change it to lowest temperature peak 1.05v per core with good stability for 2 years without issue.​
If that works for you great, but you said you had AC Loadline @ 140, but I see you have it @ 110, so enjoy your laptop!
I didn't even need to change the VR current limit for satisfactory results, as they say, KISS, Keep It Stupid Simple!
EDIT: But it's good that you mentioned it, maybe someone with a more recent CPU, could use this information.
"VR current limit" 1120 . This is my default value. I haven't changed anything. What value do you suggest I set?​
Hey all!
Have a little question well, maybe two, which has been bothering me for sometime.
I have a Raider GE76 Core i9 @2.9MHz.
I also know that it has thermal metal pad.
My first question is:
IF my notebook is on a 20 degree inclination from the back, can this affect the efficacy of the metal paste once it has tuned to liquid metal.
In other words, will the inclination of the notebook harm the metal liquid's ability to transfer heat and/or, make it slid to one side?
My second question is:
This Raider (full name) MSI Raider GE76 033CA, has a 2.9Mhz CPU and a 3070Ti GPU.
I can't find it or reviews for it anywhere.
Has anyone seen this on reviews anywhere and could you please let me know where.
Thanks for your time.
Mike.
A 20-degree tilt toward the rear shouldn’t have any noticeable impact on the effectiveness of the liquid metal. As long as it was applied properly and has had time to settle, it's not going to just run off or pool in one direction. Liquid metal does have low viscosity, but it's not that fluid once it's in place and under pressure between the heatsink and the die.
That said, I wouldn't recommend operating the laptop upside-down or in extreme orientations for extended periods — just to be on the safe side. But a moderate tilt like what you're describing is totally fine. Most high-end laptops with factory-applied liquid metal are designed to handle typical usage scenarios like this without issue.
Anyone with an Intel Core Ultra 9 275HX who can guide me on the settings to change? I received some guidance on priv, but in my Vector A2XWJG - the sections are a bit differently "named", so I don't want to mess it up..
Hi, @drek4 I just found out this tread while searching info about throttlestop for a 6700hq (GT72VR 6RE) as well as BIOS (CPU C States, Intel SpeedStep etc). I just read you were ready to share some config for such processor. Is still possible to get it?
Hello @drek4 , please, can you send me your recommended settings for intel core ultra 9 185h ? For Throttlestop and bios. Star Citizen player here on
Notebook MSI STEALTH 16 AI STUDIO A1VHG-002UK 16" / Intel Core Ultra 9 185H / 2TB / 32GB / NVIDIA GeForce RTX 4080 /W11P​
:) Thank you.
hello guys. i have thin gf63 12ve (i5 12450H with RTX4050). And i have thermal problem for my cpu. when i play a game i see my cpu max 95 degres, It doesn't drop below 85.
What settings should I adjust for this processor? I want to undervolt it.
Also, I recently replaced the thermal paste (Thermal Grizzly Kryonaut).
I wanted to ask you because I'm new to these things.
Hey everyone! I'm looking for advice regarding severe overheating on my MSI GF63 Thin 11UCX (Intel Core i5-11260H, RTX 2050, 16 GB RAM).
The laptop has recently been cleaned of dust and repasted with Arctic MX-4, but this is the second time I've had the same issue, at two different repair shops. With Turbo mode and Cooler Boost enabled, the CPU reaches 100°C. Even with Windows set to Balanced, Best Performance selected, and MSI Center configured to User > High Performance > Advanced Cooler, it still reaches around 95°C. Surprisingly, I've also seen temperatures of around 95°C while installing a game, with no power limits applied.
In GTA V Enhanced, I'm using a 144 Hz display, a 60 FPS cap, V-Sync enabled, and medium settings. I've also tried limiting the game's CPU affinity through Task Manager, leaving only the first four logical processors enabled, but the overheating remains a concern.
Disabling Turbo Boost through ThrottleStop and setting the maximum processor state to 100% on battery and 97% when plugged in helps keep temperatures around 82°C for the CPU and 86°C for the GPU. Without these adjustments, they can reach 100°C and 95°C, respectively. I'd like to find a solution that reduces temperatures without causing stuttering or significantly affecting gaming performance.
I also installed the Micro-Star International Co., Ltd. – Firmware – 1.0.0.11 update through Windows Update on the same day I manually updated the BIOS using instructions from MSI's website. I didn't install it by accident exactly; I thought it was necessary because it appeared in Windows Updates. Could installing this firmware update after the BIOS update have contributed to my overheating issues? The laptop had some temperature problems before its first repaste, but they were nowhere near this severe.
I've already submitted a support ticket to MSI and am waiting for their response. Since the laptop is about three and a half years old and has been opened twice for servicing, could the thermal pads have been shifted during either repair? They don't appear particularly worn, but reaching such high temperatures after just a few minutes of gaming makes me wonder whether the heatsink, thermal contact, or another hardware component could be faulty.
I've run HWiNFO and Cinebench tests, but I'm not very experienced at interpreting the results. Any suggestions on what might be causing this, or what I should ask the repair shop to check, would be greatly appreciated. Thanks! :))
