A320M PRO-E Problems with CPU boot
maxjulll159502df
Heres my problem, i just bought a ryzen 5 5600G to upgrade my pc so i had to update my bios for compatibility.
The problem is that if i try to put the bios file on my USB (formated FAT32) it doesn't appear on my m-flash (i tried all versions of bios update) and i didnt found someone with the same version of his motherboard than mine.
Maybe someone could help me.
I just sucessfuly flash my bios but now when i put my 5600G inside the white led on CPU EZ Debug is on and i tried all i found (remove a ram slot, clean the cpu, reset bios setting)
I have the right version of bios of this cpu so idk what to do.
Yep try the latest BIOS
It should work with the Bios you are using
But sometimes the 300 series boards will not work with a 5000 series CPU. This is why AMD did not want to include them in the Compatibility list and why there is only a Beta BIOS
