Achieving best gaming experience with 300Hz display
Nowadays, we can find gaming laptops equipped with 300Hz display. You might wonder, do we really need 300Hz display?
How does it improve your gaming experience?
Let’s find out!
300Hz display - no more dilemma between input lag and screen tearing
There are two common issues that can affect your gaming experience: screen tearing and input lag.
To eliminate the screen tearing, you will have to enable display and GPU sync technologies, however, you get input lags.
In the old days, there has no perfect solution, you have to choose either to reduce input lag, or screen tearing, but with the new 300Hz refresh rate display,
you can enjoy the minimum input lag experience without suffering from screen tearing.
1. Screen Tearing
Every gamer experiences screen tearing while GPU renders much higher frames per second than display can handle.
For instance, you are playing CS:GO on a 60Hz display while your GPU renders about 100 frames per second(fps), the screen will tear while you move fast in the game.
*What screen tearing looks like in game
*Simulation of how screen tearing looks like in Fortnite
This is caused by the inconsistency between GPU frame output timing and display refresh timing.
How about the traditional solution? Make them consistent, that’s how V-Sync, G-Sync, FreeSync works, or manually cap the game fps limit to 60.
However, the sync technologies are not the perfect aid. You will feel the input lag when you turn them on, especially V-Sync. Moreover, they limit your powerful GPU performance output to sync display refresh timing. As a result, it does not render more frames than your display refresh rate, if you are playing CS:GO on a 60Hz display, you will get 60 fps only, it is a waste of your GPU performance potential!
2. Input lag
As previously mentioned, you need sync technologies to avoid screen tearing, but when you turn sync on, you will experience input lag as the new frames will have to wait for the next display refresh timing. Here is an example, when you click the mouse to shoot your enemy, there will be a short period till the gun is really fired in the game. G-sync and FreeSync have lower input lag compared to V-sync, but still, the input lag exists.
*Simulation of how input lag looks like when V-Sync is on in Fortnite
If you turn V-Sync off, input lag becomes shorter but the screen tearing comes back.
*Simulation of how screen tearing with low input lag looks like in Fortnite
Solution: 300 Hz display
Is there any other better solution? Here comes the 300Hz display that will solve the problem of both screen tearing and the input lag. The best thing is, it unleashes the full potential of your GPU performance.
The 300Hz refresh rate means every cycle of display refresh only takes only 3.3ms, the frames rendered from GPU can match with the display refresh cycle mostly and shows barely noticeable screen tearing, which brings you a gaming experience that combines both advantages of Sync-on and Sync-off - you won’t feel the screen tearing while enjoying the game with lowest input lag.
*Simulation of how 300Hz refresh rate with low input lag looks like in Fortnite
Since sync technologies is not used on 300Hz display to eliminate screen tearing, you will have the least input lag possible and GPU performing at its maximum state, squeezing every drop of juice out from it.
Choose the specification that able to fully utilize 300Hz display
If you are considering to own a laptop that has a 300Hz display, make sure the laptop has the best CPU and GPU in order to render highest frame per second with graphic setting as high as possible. You wouldn’t want to have a 300Hz display with mid or low-end CPU and GPU since they might only be able to render low fps at certain 3A games and wasting the advantage of the high refresh rate.
Here’s MSI laptops with 300Hz display equipped with the most powerful CPU and GPU
GS66 Stealth
https://www.msi.com/Laptop/GS66-Stealth-10SX
CPU: Up to 10th Gen. Intel® Core™ i9 Processor
GPU: Up to NVIDIA® GeForce® RTX 2080 SUPER™ With Max-Q Design, 8GB GDDR6
GE66 Raider
https://www.msi.com/Laptop/GE66-Raider-10SX
alex.cliff
STAFF SERGEANT
I found an instant difference moving from 120 Hz to 300 Hz in Overwatch. Sure you have to work to take advantage of higher refresh rates, but being able to see the enemy change directions sooner makes aiming easier.
Sweet! Never thought one could get rid of both input lag and screen tearing, thanks for sharing!
That makes the purchase of 300Hz display more reasonable.
MarieHoooi
300Hz might be expensive, but it's worth as I'm currently using it and the latency is much less than before!
desunyargu155002d5
I’m on GP66 and it’s pretty much reaching 240fps on some games Like DOOM Eternal (No DLSS)
I am curious about response time, though. The performance bar showed 8ms, wonder if that’s acceptable…
cpsoho
FIRST LIEUTENANT
You would better adjust the quality to increase the FPS performance to match the refresh rate of the monitor to have the most smooth experience. (y)
