ADATTATORE PER SUPPORTO VESA PER MSI 75MMX75MM DIETRO/SOPRA SMART MONITOR 100MMX100MM
Chi può indicarmi un supporto idoneo per montare il mini pc msi 75mmx75mm su uno smart monitor 100mmx100mm. Indicando anche un tutorial specifico e non generico per il montaggio. Grazie.
Thanks Alan J T for your answer, however it is necessary to have a metal stand capable of supporting the MSI mini pc above / behind the monitor, and I don't think the double sided tape stand can support the weight of the MSI. I also thank you for the tutorial, but it doesn't explain how to place the 75mm x 75mm mini pc behind the 100mm x 100mm monitor. However, if you can find with your experience (which is not mine!) a solution for me, with the criteria I have highlighted, I will be grateful to you.
Alan J T
You want to search for Mount a Intel Nuc with VESA is pretty much the same thing
Alan thanks for the further suggestion, and I believe that it is the right one and that it can really solve my problem. Later I will let you know if everything went well.
Thank you and greetings.
