- Jul 16, 2020
Looks like some boards are getting Agesa 1.2.0.0 already. B550m Mortar for instance has had the 1.1.9.0 removed form the support site and now lists 1.2.0.0
Humm may have a look soon perhaps OC will be working correctly againLooks like some boards are getting Agesa 1.2.0.0 already. B550m Mortar for instance has had the 1.1.9.0 removed form the support site and now lists 1.2.0.0
Humm may be good More SAM support and no CPU mentioned just The RX 6000 series so what about the other GPU like the RX 5000 Series and what was before them the um VEGA And the RX 5xx SeriesLooks like some boards are getting Agesa 1.2.0.0 already. B550m Mortar for instance has had the 1.1.9.0 removed form the support site and now lists 1.2.0.0
Have you updated yet? Have you got a backup of 1.1.9.0 as well just in case.Humm may be good More SAM support and no CPU mentioned just The RX 6000 series so what about the other GPU like the RX 5000 Series and what was before them the um VEGA And the RX 5xx Series
Version
7C94v157(Beta version)
Release Date
2021-01-12
Description
- Update to ComboAM4PIV2 1.2.0.0
- Support S.A.M technology (Re-size BAR function) to enhance GPU performance for AMD Radeon RX 6000 series.
Ya just did and OC is broken I normal Select CPU Overclocking PBO advanced number 2 and it not working with a Load line calibration of 4 or 5Have you updated yet? Have you got a backup of 1.1.9.0 as well just in case.
I think the SAM support for older cards would come in the form of driver updates. Looking at how long its been from the last AMD Adrenalin driver update its something they could be working on and validating against older cards. That's purely a guess though.
I have a RX580 installed and I have Resizable bar enabled. Don't have any ill effects but no performance increase either.
With the Resize BAr I notice the the access time in bench marks is much lower before I was gettin up to 50 to 60ms now is below 25ms for CPU and GPUHave you updated yet? Have you got a backup of 1.1.9.0 as well just in case.
Which benchmark? Ill see if can replicateWith the Resize BAr I notice the the access time in bench marks is much lower before I was gettin up to 50 to 60ms now is below 25ms for CPU and GPU
Its enabled I can see it in device manager, I just don't see any increase in anything. But I have only limited testing I must admit. I don't have assassins creed Valhalla. But ill look into itIf you go to Display Properties and see Large Memory Range then it is ON But so far that is about the only way to notice if it is on or not besides if you get a improvement in games
With the new Agesa and at stock settings did you notice any difference in vCore.No real difference from previous bios only real difference was total number of frames rendered and it is only minor
AGESA 1.1.9.0
AGESA 1.2.0.0
With Agesa 1.1.0.0 Stock my vCore in BIOS was 1.208v
With Agesa 1.1.0.0 Patch D Stock my vCore in BIOS is 1.216-1.224v
The former giving better Temps etc
I am going to go with hardware problem with the board Contact MSI support or return the board for replacement.Current Beta-BIOS Ver. 157 for B550M Mortar and also former Versions (154, etc.) is giving me a heavy USB disconnecting/reconnection issue.
Seems like the system is unplugging/replugging the motherborads internal USB 2.0-Hub every couple of minutes. there is nothing connectes to these USB-ports (Mouse, keyboard via USB 3.0). Everything @stock, optimized defaults settings. Is this an known issue? Otherwise where to bugreport it?Event Type Event Time Device Name Description Device Type Drive Letter Serial Number Vendor ID Product ID Vendor Name Product Name Firmware Revision USB Class USB SubClass USB Protocol
Unplug 17.01.2021 19:38:16 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:38:16 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:38:16 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:38:19 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Unplug 17.01.2021 19:38:19 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:38:19 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:38:19 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:38:20 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:38:20 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:38:20 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:38:46 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:38:46 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:38:46 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:38:48 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:38:49 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:38:50 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:38:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:38:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:40:22 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:40:22 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:40:22 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:40:25 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:40:25 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:40:26 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:40:26 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:40:26 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:42:07 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:42:07 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:42:07 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:42:09 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:42:10 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:42:11 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:42:11 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:42:11 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:44:23 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:44:23 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:44:23 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:44:25 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:44:26 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:44:27 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:44:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:44:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:44:54 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:44:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:44:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:44:57 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:44:57 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:44:58 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:44:58 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:44:58 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:45:40 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:45:40 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:45:40 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:45:43 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:45:43 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:45:44 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:45:44 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:45:44 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:46:32 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:46:32 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:46:32 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:46:34 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:46:35 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:46:36 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:46:36 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:46:36 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:46:52 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:46:52 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:46:52 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:46:55 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:46:55 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:46:56 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:46:56 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:46:56 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:49:49 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:49:49 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:49:49 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:49:49 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:49:51 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:49:53 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:49:53 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:49:53 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:50:49 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:50:49 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:50:49 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:50:49 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 19:50:52 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:50:52 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:50:52 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:50:53 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:50:53 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:50:53 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:51:24 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 19:51:26 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:51:26 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:51:26 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Plug 17.01.2021 19:51:26 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:51:27 Port_#0004.Hub_#0006 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:51:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:51:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:52:50 Port_#0004.Hub_#0006 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:52:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:52:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:52:50 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:52:52 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:52:54 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:52:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:52:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:58:13 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 19:58:13 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 19:58:13 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 19:58:13 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 19:58:16 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:58:16 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 19:58:16 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 19:58:17 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 19:58:17 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 19:58:17 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:04:39 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:04:39 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:04:39 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:04:39 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:04:42 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:04:43 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:04:43 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:04:43 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:05:32 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 20:05:34 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:05:34 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:05:34 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Plug 17.01.2021 20:05:34 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:05:35 Port_#0004.Hub_#0006 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:05:35 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:05:35 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:07:40 Port_#0004.Hub_#0006 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:07:40 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:07:40 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:07:40 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 20:07:43 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 20:07:43 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 20:07:43 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:07:44 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:07:44 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:07:44 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:05 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:08:05 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:08:05 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:05 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:08:07 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:08:09 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:08:09 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:08:09 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:27 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:08:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:08:27 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:27 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:08:29 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:08:31 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:08:31 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:08:31 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:50 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:08:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:08:50 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:08:50 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Unplug 17.01.2021 20:08:53 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 20:08:53 Port_#0011.Hub_#0001 Generic USB Hub Unknown 05e3 0608 Genesys Logic, Inc. USB-2.0 4-Port HUB 60.70 00 00 00
Plug 17.01.2021 20:08:53 Port_#0012.Hub_#0001 USB Input Device HID (Human Interface Device) A02020051203 1462 7c94 Micro Star International 0.01 03 00 00
Plug 17.01.2021 20:08:54 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Plug 17.01.2021 20:08:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Plug 17.01.2021 20:08:54 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Unplug 17.01.2021 20:16:55 Port_#0004.Hub_#0005 USB Composite Device Unknown 02483-11362 0c70 f001 MCT Elektronikladen 0.02 00 00 00
Unplug 17.01.2021 20:16:55 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 01
Unplug 17.01.2021 20:16:55 0002.0000.0000.011.004.000.000.000.000 USB Input Device HID (Human Interface Device) 0c70 f001 MCT Elektronikladen 0.02 03 00 00
Will be testing some older, non-beta bios tomorrow.
Agesa 1.2.0.0 non BETA is out for the B550 Mortar. Don't know if its any actual changes in it from the Beta. Non Beta out for more B550 and X570 as wellI am going to go with hardware problem with the board Contact MSI support or return the board for replacement.
May also be a fault with the Case USB connections unplug them and see waht happens.
Update time so should start to release for the rest of B550 boards very soon thenAgesa 1.2.0.0 non BETA is out for the B550 Mortar. Don't know if its any actual changes in it from the Beta. Non Beta out for more B550 and X570 as well
Okey Dokey Updated and set bios to my normal setting Looks like they finlay fixed the Bus speed as was all ways showing 99.1MHz so was setting the FS in bios to 100.896 and it is now showing that in Hardware info. So may set it back to AUTO or just leave it as is if there is no problem with it. Getting Same performance as before in 3D Mark runsUpdate time so should start to release for the rest of B550 boards very soon then
Maybe worth going back to stock just to test some stuff, I'm interested to see if when they release for the B450 Max boards if it will be beta or go straight to stable.Okey Dokey Updated and set bios to my normal setting Looks like they finlay fixed the Bus speed as was all ways showing 99.1MHz so was setting the FS in bios to 100.896 and it is now showing that in Hardware info. So may set it back to AUTO or just leave it as is if there is no problem with it. Getting Same performance as before in 3D Mark runs
Result
www.3dmark.com
And a 500 point increase in Cinebench R20
