All Games Crash and BSOD problem
Hi there,
I am facing issues in all games like GTA V, Apex Legends, etc are freezing and crashing on daily basis , and currently I am going through BSOD problem while playing any games. My temperatures are ok. I have done all things like disabling XMP profile, bios reset, driver check and of course format the machine and reinstalling windows. I tried using different graphics card, RAM and SSD but all same. Please help me.
My PC configuration-
Processor - AMD Ryzen 7 5800x
MOBO - MSI MAG B550 Tomahawk
RAM - Corsair 16+16= 32gb, 3600 mhz
GPU - Nvidia RTX 3060.
Does Amd ryzen 7 5800x with mag b550 tomahawk supports 3600 mhz RAM?
fauc
SECOND LIEUTENANT
1.Please also provide brand and model for power supply.
2.Please provide picture for all infirmation on this BSOD.
3.For game, please refer below link for modifying some setting value on NVIDIA control panel.
Example: Modify "Power management mode" to "Prefer maximum performance" in Manage 3D setting sheet.
How to Optimize Nvidia Control Panel For GAMING & Performance The Ultimate GUIDE 2020 Update
PSU - cooler master v850 gold
I have 3600 mhz RAM , Do msg b550 tomahawk with ryzen 7 5800 x supports 3600 mhz RAM??
fauc
SECOND LIEUTENANT
It is memory support list for MAG-B550-TOMAHAWK on MSI website.
Please click "Memory By RX-5xxx " icon and then input 3600 on search bar as attachment.
Alan J T
Hi there,
In a nut shell yes it will support 3600Mhz even 4000Mhz but it is not guaranteed to work
it is conditional on your CPU Memory controller and the total amount of ram not so much the motherboard.
One single ram stick will run at 4000 easily but put in two and well you may get 4000 but more than likely will only get 3800 or 3600
Bump that up to four 8GB stick and you can drop that down to 3600 or 3200 as higher is not likely to work.
