- Feb 11, 2012
attached is the document thats most usful for determining the AMI post codes that MSI boards use!
this is just used for referancing d-bug post codes that can happen and should help if you don't really know the code yourself!
hope you guys find it helpful.
with the codes look up the meaning via google and it will point you in the right direction of what has gone wrong and where to start narrowing down the problem to.
