pete_talbo151002d2
- Apr 12, 2026
I have an MSI PRO B850M-A Wifi PZ Motherboard and an MSI MAG PANO 100R PZ Case. I have connected everything up as per the manuals. Everything works OK and windows boots as expected. The fans in the case all run and the leds light up and cycle through a pattern. The ARGB connector from the control panel has been connected to each of the JARGB motherboard connectors in turn (powering off before swapping it over) however Mystic Light and Signal RGB (with the MSI addin installed) both fail to make any changes to the lighting.
All firmware, bios and application updates are latest versions as of the date of posting.
I am completely at a loss, so any help is much appreciated. All I want to do is turn all the LEDS in the fans OFF.
Many Thanks for your assistance.
