Audio very low sound on one headphone MSI motherboard
Hello, I have bought new PC with MSI Motherboard H510M-PRO, I have installed windows 11 on it and have downloaded all audio drivers but there is very low sound on right headphone only, which is not hearable.
So I would like to know, what can be wrong?
I have tried all guides like installing drivers, uninstalling and re-installing it, Windows 11 update etc. nothing worked for me.
mnemonic
and please check the windows volume settings of that headset, it just might be the volume for left and right channel is not even and that may cause a low volume on one channel as if something is wrong with hardware, but it appears to be just a windows bug. Some boots i get that the volumes of both channels are not equal either but then a quick correction can be done in the windows volume settings. It's an odd error this.
Here are the full-spec
Windows 11 Pro
Version- 21H2
OSBuild - 22000.739
Processor 11th Gen Intel(R) Core(TM) i5-11400 @ 2.60GHz 2.59 GHz
RAM -8GB
SMBIOSBIOSVersion - 1.10
256GB -SSD
DMI Baseboard
vendor Micro-Star International Co. Ltd.
model H510M PRO (MS-7D22)
revision 1.0
