MSI B350 TOMAHAWK - Bricked BIOS Recovery Using Arduino UNO + W25Q128FW
Hello everyone,
I wanted to share a BIOS recovery procedure that successfully recovered an MSI B350 TOMAHAWK motherboard after a failed/problematic BIOS update.
After the BIOS update, the motherboard could no longer boot normally and was getting stuck around the VGA/POST stage. Since normal BIOS recovery methods were no longer available, I recovered the onboard SPI flash directly using an Arduino UNO.
The important part of this procedure is that I did not erase the flash immediately. I first created two complete independent backups and verified that both backups had exactly the same SHA256 hash.
Motherboard:
MSI B350 TOMAHAWK
SPI Flash:
Winbond W25Q128FW / 25Q128FWSQ
128 Mbit / 16 MiB
1.8 V device
Verified JEDEC ID:
EF 60 18
BIOS version used for recovery:
MSI 7A34v1M
E7A34AMS.1M0
Release date: 2019-01-30
Important Warning
This procedure directly erases and programs the motherboard SPI flash.
Do not perform CHIP ERASE until you have at least two complete 16 MiB dumps and both dumps produce exactly the same SHA256 value.
The W25Q128FW is a 1.8 V flash device. Do not connect the Arduino UNO 5 V logic outputs directly to the flash CS, MOSI or CLK signals.
Hardware Connection
The motherboard JSP11 service header was used.
Arduino UNO to JSP11:
D10 -> 1.8 kOhm series resistor -> node -> 1 kOhm to GND -> JSP11 Pin 5 / SPI_CS#
D11 -> 1.8 kOhm series resistor -> node -> 1 kOhm to GND -> JSP11 Pin 4 / SPI_DATAOUT / MOSI
D13 -> 1.8 kOhm series resistor -> node -> 1 kOhm to GND -> JSP11 Pin 6 / SPI_CLK
D7 <- direct input from JSP11 Pin 3 / SPI_DATAIN / MISO
Arduino GND -> motherboard GND
JSP11 Pin 1/2 -> CPU_1P8 / external laboratory PSU set to 1.80 V
JSP11 Pin 11 / SPI_WP#_R -> 10 kOhm pull-up to 1.8 V
JSP11 Pin 12 / SPI_HOLD#_R -> 10 kOhm pull-up to 1.8 V
ATX and CPU power cables were disconnected while externally powering the 1.8 V rail.
Arduino GND, laboratory PSU GND and motherboard GND were connected together.
The motherboard consumed approximately:
Read operation: 0.02 A
Erase/program operation: 0.03 A
Step 1 - Verify SPI Communication
Before reading or writing anything, I verified communication using the JEDEC ID command.
The flash repeatedly returned:
Manufacturer: 0xEF
Memory Type: 0x60
Capacity: 0x18
JEDEC:
EF 60 18
This confirmed that the Arduino was communicating correctly with the Winbond flash.
Step 2 - Create Two Independent Full Dumps
I read the complete 16 MiB flash twice.
bios_dump_1.bin
bios_dump_2.bin
Both files produced exactly the same SHA256:
5adbf6f7226a3b8124f219c0ffc560b7f97cef7e781f9b2427d3d0515ec5c652
This was my safety baseline.
If the two hashes do not match, do not continue with erase/programming.
Step 3 - Prepare the Official MSI BIOS
I used the official MSI B350 TOMAHAWK BIOS package:
Version:
7A34v1M
BIOS image:
E7A34AMS.1M0
Image size:
16,777,216 bytes
SHA256 of E7A34AMS.1M0:
3e14c954757398cf2ec4ffe75f0d374d1fb68fd0a74264e6a1466dcf65b10909
The official image and my existing flash dump were significantly different, so I did not simply copy a few bytes.
I created a board-specific restore image while preserving persistent DMI/SMBIOS NVRAM data from the original dump.
Important:
Do not use my personalized restore image on another motherboard.
DMI/SMBIOS/NVRAM data may contain board-specific information.
Each motherboard should use its own dumps and its own restore image.
The final restore image used on my board was:
E7A34AMS_1M0_DMI_PRESERVED.bin
Size:
16,777,216 bytes
SHA256:
db31227075b7980fbeb0a8adc385fd7f056dc5d359c950d236cce4e278bbfffc
This SHA256 is specific to my recovery image and must not be reused for another motherboard.
Step 4 - Safety Checks Before Erase
The PC-side programming script checks:
Image size
Image SHA256
JEDEC ID
The script does not automatically erase the flash when started.
It requires the user to manually type:
ERASE
Only after all checks pass.
Step 5 - Erase
The Arduino performs a Winbond Chip Erase operation.
Expected result:
ERASE_START
ERASE_OK
Step 6 - Blank Check
After erase, the complete 16 MiB flash is read and checked for 0xFF.
Expected result:
BLANK_START
BLANK_OK
If BLANK_OK is not received, programming should not continue.
Step 7 - Programming
The BIOS is programmed in 256-byte pages.
Every programmed page is immediately read back and verified before the next page is accepted.
Expected final progress:
16777216 / 16777216
In my case the complete programming + page verify process took approximately 749 seconds.
Step 8 - Full 16 MiB Read-Back Verification
After programming completed, the entire flash was read again from address 0x000000 to the end.
The SHA256 of the data physically read back from the flash was:
Expected restore image SHA256:
Result:
VERIFY : BASARILI - BYTE-FOR-BYTE IMAGE DOGRU
In English:
VERIFY SUCCESSFUL - BYTE-FOR-BYTE IMAGE MATCH
This was important to me because I did not want to trust only a "program completed" message. The complete contents physically stored in the SPI flash were independently read back and hashed.
Result
After removing the Arduino, external 1.8 V supply and temporary programming connections, the motherboard was able to enter the BIOS setup again.
So the motherboard itself was successfully recovered.
Windows Boot Note
After recovering or downgrading the BIOS, the previous boot configuration may be reset.
If the BIOS detects the SSD/HDD but Windows does not boot, do not immediately assume that the disk or Windows installation is damaged.
Check:
Is the SSD/HDD detected in BIOS?
Is "Windows Boot Manager" available?
Is Boot Mode set correctly for UEFI/GPT?
Is CSM/Legacy configured correctly?
Is SATA Mode the same as before, for example AHCI or RAID?
A CMOS reset or BIOS downgrade can change these settings.
Recovery Checklist
- Confirm the motherboard model.
- Physically identify the SPI flash.
- Confirm the flash voltage.
- Do not apply Arduino 5 V logic directly to a 1.8 V flash input.
- Verify the JEDEC ID.
- Read the complete flash twice.
- Confirm both dumps are exactly 16,777,216 bytes.
- Confirm both dumps have identical SHA256 hashes.
- Keep both original dumps permanently.
- Verify the official target BIOS image size and hash.
- Preserve board-specific DMI/SMBIOS/NVRAM information where necessary.
- Keep WP# and HOLD# HIGH during programming.
- Perform CHIP ERASE.
- Perform a complete BLANK CHECK.
- Program using 256-byte pages.
- Verify every programmed page.
- Read the complete 16 MiB flash again.
- Compare the final read-back SHA256 against the image that was programmed.
- Do not disconnect the programmer or power the motherboard normally until the final hash matches.
Arduino Firmware
The Arduino UNO firmware used for this recovery supports:
J = JEDEC ID
E = Chip Erase
B = Blank Check
P = Page Program + immediate page verification
D = Full Flash Read-Back
I will include the Arduino firmware below.
Code:
// REV16
// MSI B350 Tomahawk - Winbond W25Q128FW/FWSQ
// External recovery programmer using Arduino UNO
// Commands: J=JEDEC, E=erase, B=blank check, P=page program+verify, D=full readback dump
#include <Arduino.h>
#define CS_BIT PB2 // D10
#define MOSI_BIT PB3 // D11
#define CLK_BIT PB5 // D13
const uint8_t PIN_MISO = 7; // AIN1 comparator input
const uint32_t FLASH_SIZE = 16777216UL;
const uint16_t PAGE_SIZE = 256;
inline void csLow() { PORTB &= ~_BV(CS_BIT); }
inline void csHigh() { PORTB |= _BV(CS_BIT); }
inline void clkLow() { PORTB &= ~_BV(CLK_BIT); }
inline void clkHigh() { PORTB |= _BV(CLK_BIT); }
inline void mosiLow() { PORTB &= ~_BV(MOSI_BIT); }
inline void mosiHigh(){ PORTB |= _BV(MOSI_BIT); }
inline bool readMISO() {
// ACBG=1: comparator + input is internal bandgap (~1.1 V), - input is D7/AIN1.
// MISO > ~1.1 V => ACO=0.
return (ACSR & _BV(ACO)) == 0;
inline void spiWriteByte(uint8_t data) {
for (uint8_t mask = 0x80; mask; mask >>= 1) {
if (data & mask) mosiHigh(); else mosiLow();
clkHigh();
asm volatile("nop\n\tnop\n\tnop\n\t");
clkLow();
inline uint8_t spiReadByte() {
uint8_t value = 0;
clkHigh();
asm volatile("nop\n\tnop\n\tnop\n\tnop\n\t");
if (readMISO()) value |= mask;
clkLow();
return value;
void writeEnable() {
csLow();
spiWriteByte(0x06);
csHigh();
uint8_t readStatus1() {
csLow();
spiWriteByte(0x05);
uint8_t sr = spiReadByte();
csHigh();
return sr;
bool waitReady(uint32_t timeoutMs) {
uint32_t start = millis();
while (readStatus1() & 0x01) {
if ((millis() - start) > timeoutMs) return false;
delay(1);
return true;
bool checkWEL() {
return (readStatus1() & 0x02) != 0;
void startRead(uint32_t address) {
csLow();
spiWriteByte(0x03);
spiWriteByte((address >> 16) & 0xFF);
spiWriteByte((address >> 8) & 0xFF);
spiWriteByte(address & 0xFF);
void stopRead() { csHigh(); }
void printJedec() {
csLow();
spiWriteByte(0x9F);
uint8_t a = spiReadByte();
uint8_t b = spiReadByte();
uint8_t c = spiReadByte();
csHigh();
Serial.print("JEDEC=");
if (a < 0x10) Serial.print('0'); Serial.print(a, HEX); Serial.print(' ');
if (b < 0x10) Serial.print('0'); Serial.print(b, HEX); Serial.print(' ');
if (c < 0x10) Serial.print('0'); Serial.println(c, HEX);
bool chipErase() {
writeEnable();
if (!checkWEL()) {
Serial.println("ERR_WEL");
return false;
Serial.println("ERASE_START");
Serial.flush();
csLow();
spiWriteByte(0xC7);
csHigh();
if (!waitReady(300000UL)) {
Serial.println("ERR_ERASE_TIMEOUT");
return false;
Serial.println("ERASE_OK");
return true;
bool blankCheck() {
Serial.println("BLANK_START");
Serial.flush();
startRead(0);
for (uint32_t address = 0; address < FLASH_SIZE; address++) {
uint8_t v = spiReadByte();
if (v != 0xFF) {
stopRead();
Serial.print("BLANK_FAIL 0x");
Serial.println(address, HEX);
return false;
stopRead();
Serial.println("BLANK_OK");
return true;
bool programPage(uint32_t address, const uint8_t *data, uint16_t len) {
if (len == 0 || len > PAGE_SIZE) return false;
if ((address & 0xFF) + len > PAGE_SIZE) return false;
writeEnable();
if (!checkWEL()) return false;
csLow();
spiWriteByte(0x02);
for (uint16_t i = 0; i < len; i++) spiWriteByte(data[i]);
csHigh();
if (!waitReady(2000UL)) return false;
// Immediate page read-back verify before accepting next page.
startRead(address);
for (uint16_t i = 0; i < len; i++) {
if (spiReadByte() != data[i]) {
stopRead();
return false;
stopRead();
return true;
void dumpFlash() {
Serial.println("DUMP_BEGIN");
Serial.flush();
startRead(0);
Serial.write(spiReadByte());
stopRead();
Serial.flush();
bool readExactSerial(uint8_t *dst, uint16_t count, uint32_t timeoutMs) {
uint16_t got = 0;
uint32_t last = millis();
while (got < count) {
if (Serial.available()) {
dst[got++] = (uint8_t)Serial.read();
last = millis();
} else if ((millis() - last) > timeoutMs) {
return false;
return true;
void setup() {
DDRB |= _BV(CS_BIT) | _BV(MOSI_BIT) | _BV(CLK_BIT);
csHigh();
mosiLow();
clkLow();
pinMode(PIN_MISO, INPUT);
ACSR = _BV(ACBG);
Serial.begin(1000000);
delay(1500);
Serial.println();
Serial.println("REV16");
Serial.println("W25Q128FW RECOVERY PROGRAMMER");
Serial.println("WAITING");
printJedec();
void loop() {
if (!Serial.available()) return;
char cmd = (char)Serial.read();
if (cmd == 'J') {
printJedec();
else if (cmd == 'E') {
chipErase();
else if (cmd == 'B') {
blankCheck();
else if (cmd == 'D') {
dumpFlash();
else if (cmd == 'P') {
uint8_t hdr[5];
if (!readExactSerial(hdr, 5, 3000)) {
Serial.println("ERR_HEADER_TIMEOUT");
return;
uint32_t address = ((uint32_t)hdr[0] << 16) |
((uint32_t)hdr[1] << 8) |
((uint32_t)hdr[2]);
uint16_t len = ((uint16_t)hdr[3] << 8) | hdr[4];
if (len == 0 || len > PAGE_SIZE || ((address & 0xFF) + len > PAGE_SIZE)) {
Serial.println("ERR_PARAM");
return;
uint8_t buffer[PAGE_SIZE];
if (!readExactSerial(buffer, len, 5000)) {
Serial.println("ERR_DATA_TIMEOUT");
return;
if (programPage(address, buffer, len)) {
Serial.println("OK");
} else {
Serial.print("ERR_VERIFY 0x");
PC-Side Python Tool
The Python program performs:
Image size validation
Image SHA256 validation
JEDEC verification
Explicit ERASE confirmation
Chip erase
Blank check
256-byte page programming
Per-page verification
Complete 16 MiB read-back
Final SHA256 verification
Important:
The EXPECTED_SHA256 value inside the Python program belongs to the restore image being programmed.
Do not copy my SHA256 value blindly.
Calculate the SHA256 of your own restore image and replace EXPECTED_SHA256 accordingly.
Code:
# REV17
# MSI B350 Tomahawk / W25Q128FW recovery writer
# Sequence: identify -> hash guard -> explicit ERASE confirmation -> chip erase -> blank check
# -> 256-byte page program (Arduino verifies every page) -> full 16 MiB read-back SHA256 verify.
import hashlib
import os
import serial
import sys
import time
PORT = "COM8"
BAUD = 1_000_000
FLASH_SIZE = 16_777_216
EXPECTED_SHA256 = "db31227075b7980fbeb0a8adc385fd7f056dc5d359c950d236cce4e278bbfffc"
EXPECTED_JEDEC = "JEDEC=EF 60 18"
PAGE_SIZE = 256
if len(sys.argv) < 2:
print('Kullanim: py REV17_bios_write_verify.py "E7A34AMS_1M0_DMI_PRESERVED.bin"')
sys.exit(1)
image_path = sys.argv[1]
readback_path = os.path.splitext(image_path)[0] + "_READBACK.bin"
if not os.path.isfile(image_path):
print("HATA: Dosya bulunamadi:", image_path)
sys.exit(1)
size = os.path.getsize(image_path)
if size != FLASH_SIZE:
print("HATA: Boyut yanlis:", size, "beklenen:", FLASH_SIZE)
sys.exit(1)
h = hashlib.sha256()
with open(image_path, "rb") as f:
for chunk in iter(lambda: f.read(1024 * 1024), b""):
h.update(chunk)
image_sha = h.hexdigest()
print()
print("REV17 MSI BIOS WRITE + VERIFY")
print("Port :", PORT)
print("Image :", image_path)
print("Boyut :", size)
print("SHA256 :", image_sha)
print()
if image_sha.lower() != EXPECTED_SHA256:
print("HATA: Restore image SHA256 beklenen degerle ayni degil.")
print("Beklenen:", EXPECTED_SHA256)
sys.exit(1)
ser = serial.Serial(PORT, BAUD, timeout=5, write_timeout=5)
def readline_text(timeout=10):
old = ser.timeout
ser.timeout = timeout
raw = ser.readline()
ser.timeout = old
return raw.decode("ascii", errors="ignore").strip()
print("Arduino bekleniyor...")
ready = False
jedec_ok = False
for _ in range(40):
line = readline_text(1)
if not line:
continue
print(line)
if line == EXPECTED_JEDEC:
jedec_ok = True
if line == "WAITING":
ready = True
if ready and jedec_ok:
break
# Explicit JEDEC request once Arduino is up.
ser.reset_input_buffer()
ser.write(b"J")
ser.flush()
line = readline_text(3)
print(line)
if line != EXPECTED_JEDEC:
print("HATA: JEDEC kimligi beklenen degil. ERASE YAPILMADI.")
ser.close()
sys.exit(1)
print()
print("Restore image ve flash kimligi dogrulandi.")
confirm = input('FLASH SILINECEK. Devam etmek icin tam olarak ERASE yaz: ').strip()
if confirm != "ERASE":
print("Iptal edildi. Flash degistirilmedi.")
ser.close()
sys.exit(0)
# ERASE
print("\nChip erase basliyor...")
ser.write(b"E")
ser.flush()
erase_ok = False
start = time.time()
while time.time() - start < 330:
line = readline_text(5)
if not line:
continue
print(line)
if line == "ERASE_OK":
erase_ok = True
break
if line.startswith("ERR_"):
break
if not erase_ok:
print("HATA: Chip erase tamamlanmadi. Yazma baslatilmadi.")
ser.close()
sys.exit(1)
# BLANK CHECK
print("\nBlank check basliyor...")
ser.write(b"B")
ser.flush()
blank_ok = False
start = time.time()
while time.time() - start < 300:
if not line:
continue
print(line)
if line == "BLANK_OK":
blank_ok = True
break
if line.startswith("BLANK_FAIL"):
break
if not blank_ok:
print("HATA: Blank check gecmedi. Programlama baslatilmadi.")
ser.close()
sys.exit(1)
# PROGRAM
print("\nProgramlama basliyor...")
start = time.time()
for page in range(FLASH_SIZE // PAGE_SIZE):
address = page * PAGE_SIZE
data = f.read(PAGE_SIZE)
if len(data) != PAGE_SIZE:
print("HATA: Image beklenmedik sekilde bitti.")
ser.close()
sys.exit(1)
packet = (
b"P" +
address.to_bytes(3, "big") +
PAGE_SIZE.to_bytes(2, "big") +
data
ser.write(packet)
ser.flush()
reply = readline_text(5)
if reply != "OK":
print(f"\nHATA: 0x{address:06X} sayfasinda program/verify hatasi: {reply!r}")
ser.close()
sys.exit(1)
if (page + 1) % 4096 == 0 or page == 0:
done = (page + 1) * PAGE_SIZE
percent = done * 100.0 / FLASH_SIZE
elapsed = time.time() - start
speed = done / max(elapsed, 0.001) / 1024
print(f"{done:>9} / {FLASH_SIZE} ({percent:5.1f}%) {speed:7.1f} KB/s")
program_time = time.time() - start
print("Programlama + page verify tamamlandi. Sure:", round(program_time, 1), "s")
# FULL READ-BACK
print("\nTam 16 MiB read-back SHA256 verify basliyor...")
ser.write(b"D")
ser.flush()
while True:
line = readline_text(10)
if not line:
print("HATA: DUMP_BEGIN gelmedi.")
ser.close()
sys.exit(1)
if line == "DUMP_BEGIN":
break
print(line)
remaining = FLASH_SIZE
read_sha = hashlib.sha256()
received = 0
start = time.time()
next_report = 1024 * 1024
with open(readback_path, "wb") as out:
while remaining:
want = min(16384, remaining)
chunk = bytearray()
retries = 0
while len(chunk) < want:
data = ser.read(want - len(chunk))
if data:
chunk.extend(data)
retries = 0
else:
retries += 1
if retries >= 15:
print("HATA: Read-back veri akisi kesildi. Alinan:", received + len(chunk))
ser.close()
sys.exit(1)
out.write(chunk)
read_sha.update(chunk)
received += len(chunk)
remaining -= len(chunk)
if received >= next_report or received == FLASH_SIZE:
percent = received * 100.0 / FLASH_SIZE
speed = received / max(elapsed, 0.001) / 1024
print(f"{received:>9} / {FLASH_SIZE} ({percent:5.1f}%) {speed:7.1f} KB/s")
next_report += 1024 * 1024
ser.close()
read_sha_hex = read_sha.hexdigest()
print("\n--------------------------------")
print("READ-BACK TAMAMLANDI")
print("Readback:", readback_path)
print("SHA256 :", read_sha_hex)
print("Beklenen:", image_sha)
if read_sha_hex.lower() == image_sha.lower():
print("VERIFY : BASARILI - BYTE-FOR-BYTE IMAGE DOGRU")
print("--------------------------------")
sys.exit(0)
else:
print("VERIFY : HATA - HASH ESLESMIYOR")
print("Anakarti calistirmayin; mevcut programlayici baglantisini koruyun.")
sys.exit(2)
Files I Recommend Keeping Permanently
bios_dump_1.bin
bios_dump_2.bin
Original MSI stock BIOS
Board-specific restore image
Final read-back image
Arduino programmer source code
Python write/verify tool
Final Notes
This was an in-circuit recovery performed on an MSI B350 TOMAHAWK using the onboard JSP11 service header and a Winbond W25Q128FW-class 1.8 V SPI flash.
The most important rule in the entire process was:
Never erase the original flash until you have two independent full dumps with identical SHA256 hashes.
And after programming:
Never assume that successful programming means the flash is correct. Read the complete flash back and compare its SHA256 against the image you intended to write.
I hope this helps someone recover a motherboard that would otherwise be considered dead.
