B360m gaming plus VS H310m pro-vhl
joha453f063c
Hi, I have a recently purchased a MSI B360M Gaming Plus motherboard. Checking the bios settings I noticed the BIOS system info says I have a H310M Pro-Vhl motherboard.
Do any of you know what this means? Do I have the wrong bios installed?
microthunder
SECOND LIEUTENANT
To make sure of that, can you see what BIOS ver. it is shown? Is it E7B19IMS.190?
joha453f063c
thanks for the reply.
BIOS system settings:
BIOS version: E7B27IMS.170
MB: H310M PRO-VHL (MS-7B27)
Product Name: MS-7B27 1.0
Motherboard installed in PC is B360M Gaming Plus
above PCI-EI slot: B360M GAMING PLUS
BELOW PCI-EI slot: MS-7B19 VER1.1
S/N 601-7B19-020B1903002389
Definitely the wrong BIOS installed. Bought new motherboard from supplier, not part of OEM system or pre-build. www.evetech.co.za.
Physical appearance is as it should be, correct box etc.
Some features not working, eg. only 4 sata ports in bios working, mobo has 6. LAN port not working,
fatedust
FIRST LIEUTENANT
I'm guessing this is a second-hand board? Maybe the last owner flashed to a wrong version of BIOS?
