B450-A pro Max compatibility DDR4 Renoir
pvg3100129702b0
I cannot find a list of compatible DDR4 for Renoir CPUs. Who can tell me which DDR4 3200 model is compatible with this motherboard and a Renoir ryzen 3 4300GE CPU?
Thank you
Alan J T
🙈 🙉 Just 🐝 🤬😈
Memory RX-3X00 is for Matisse... and Renoir ?
Yep but you have to look at something and just because it no on the list does not mean it wont work
If you not care about RGB grab a set of Gskill RipJaw V 3200 CL16
Alan J T
🙈 🙉 Just 🐝 🤬😈
This model ?
Yep will work quite nicely From Reviews it is one of the more reliable RAM in AMD systems
And is on there QVL Tested list
Alan J T
🙈 🙉 Just 🐝 🤬😈
One last question, is this motherboard (https://www.msi.com/Motherboard/B450-A-PRO-MAX/Specification) compatible with windows 11?
According to the specifications, windows 11 is not listed but drivers are nevertheless available...
What do you think?
That is more to do with your CPU and I think yours is on the comptable list
