b450 gaming plus can't enable secure mode because System is not in User Mode
barrerabc915a202e2
I receive this warning message when trying to enable secure mode: System in Setup Mode! Secure Boot can be enabled when System in User Mode. Repeat operation after enrolling Platform Key(PK). What do I have to do?
Pro
Just update to the latest BIOS, it will enable it correctly for you by default. https://www.msi.com/Motherboard/B450-GAMING-PLUS/support
Update how-to:
barrerabc915a202e2
My motherboard model is "B450 Gaming Plus", but in the downloads I don't find the exact model. I find "B450 Gaming Plus MAX" and "B450 Gaming Plus MAX WIFI". Should I choose the first one?
barrerabc915a202e2
Update how-to:
Thank you, I alreday did it, but unfortunately it didn't work. It still says me secure boot is disabled. I entered the new BIOS and efectively it was disabled. I changed from CSM to UEFI and then tried to enable secure boot manually, but doing that, when I reboot, the BIOS appears again. If I change to CSM I can enter windows again, but the secure boot option is disabled this way. What should I do now?
Pro
See here. Your Windows was installed with the BIOS in CSM mode, thus when you set the BIOS to UEFI mode, it expects the drive to be prepared differently, so then it won't boot. You have to do the MBR to GPT conversion for the boot drive now. Secure Boot requires UEFI mode, and Win11 also requires UEFI mode.
