b450 gaming pro carbon max wifi mic wont work
teletubby_po
FIRST LIEUTENANT
Hi, is it your new build?
Have you installed all the necessary drivers? e.g. chipset, audio, mic drivers
How do you connect the device to your PC, is it from front or rear panel?
cmedck46eb0641
Its a new build by memory express. I have tried both front and back panels and usb as well. It shows that the mic is there and working properly but it doesnt work, so I have no idea. I am thinking I am going to have to take it back and have them look into it.
teletubby_po
FIRST LIEUTENANT
Can you check your device manager and see if there's any alert? Just to make sure if all drivers' installed
fatedust
FIRST LIEUTENANT
It would be great to share with us how it was solved, recently lots of people are having audio issue on this forum.
