b450 tomahawk compatability
hi, new to this and looking for help. i currently run a b45 tomahawk board with a ryzen 5 2400g cpu updated to the latest bios 7CO2ASP.1E and i have just found out it is not supported for Windows 11. i know that my board will run series 3000 cpu but was wondering if it will run series 5000 cpu's. i was looking to upgrade to a 3600 cpu but thet are in very short supply. any comments would be appreciated.
jakub-p2
PRIVATE FIRST CLASS
I think you mistyped either your MoBo name or BIOS version, the newest non-beta I can find is 7C02v1E, the 5000 series needs 7C02v1H, so it should be fine. Also, in my opinion you don't need to stress yourself about W11 compatibility, I think sooner or later there will be a workaround for even older PC.
rafarquivo152202d0
like, if i understood well....i have a tomahawk (not max), can i use a 5800x on that ?? with 7C02v1E ?
id like to run more power for CS go, its just change and it will work ???
I upgraded to bios (7C02v1H6 (Beta version)) and upgraded to windows 11. Unfortunately, since then, oculus quest 2 has not been connected to usb. I've tried everything. I don't know what makes it bios or windows. All my other usb devices work. Can I download 7C02v1H5 from somewhere? Going back to Windows 10 is very tricky.
The link is good. Downgrading bios. But quest 2 is still not connected to the PC via USB. There are several options either the oculus sotware is not compatible with windows 11, or the AMD chipset drivers (USB) are bad for windows 11, or this installation is completely corrupted and needs a clean new.
