petran.burne159102db
- Aug 31, 2025
Hello all.
I have the above motherboard and thinking of upgrading mu cpu from R2700 to R5700x. I still have the BIOS the mobo came with (Agesa 1.0.0.3) from the old 2019.
1. Should i update straight to the newest BIOS (7C02v3K) or are there any inbetween older bios update steps that should be installed first?
2. When i install the new bios will my old cpu be supported or should i do it right before i upgrade to the new cpu? I mean can i do the BIOS update now with the R2700 on the system or will it stop working until i get the new cpu?
Thank you...
Thank you...
But everything else you may want to take a note like citay mentioned.
