B460M-A PRO Memory RAM Overclocking for 3000MHz
Status
Not open for further replies.
jw.borb42ca0618
Hi
Recently i've bought the motherboard ASUS B450M-A PRO and I'm using it with an i5 10th generation 10400F and Memoery HyperX Fury RGB, 16GB, 3000MHz, DDR4, CL15, BLACK- HX430C15FB3A/16.
I'm trying to use the memory ram at 3000MHz but at the bios i don't know or can't set it up to run at 3000MHz, i fully intent to do the overclocking of RAM memory allowing the XMP but i never have the option to run it at 3000MHz.
How can i set it up?
Thank you.
Status
