B460M-A PRO Overclock Memory RAM 3000MHz
jw.borb42ca0618
Hi
Recently i've bought the motherboard ASUS B450M-A PRO and I'm using it with an i5 10th generation 10400F and MemoryHyperX Fury RGB, 16GB, 3000MHz, DDR4, CL15 - HX430C15FB3A/16.
I'm trying to use the memory ram at 3000MHz but at the bios i don't know or cant set it up to run at 3000MHz, i fully intent to do the overclocking of RAM memory allowing the XMP but i never have the option to run it at 3000MHz.
How can i set it up?
PS: I know it's possible with this processor cause i've seen benchmarks using i5 10400F + 3200MHZ. Link below:
Thank you.
Hi
ASUS is what you clearly said... Well, we at least you added B460M-A PRO somewhere above the text.
However no B460 or H410 board supports RAM oc. Intel limited this feature to Z490 boards regardless of the cpu used. Ram speed therefor depends on the cpu's highest default speed. Maximum ram speed possible with your i5-10400 is DDR4-2666. Nothing more is possible.
