brunoaduarte
- Dec 30, 2020
I'm having issues with my MSI B460M PRO-VDH WIFI motherboard when using it with compatible (QVL) 32 GB DRAM memory sticks CMV32GX4M1A2666C18
If i put only 1 x 32GB memory stick on DIMMA2 slot (single channel), everything works fine.
But when i place the secondary memory stick (exact same model) on the DIMMB2 slot (2 x 32 GB = 64GB dual channel) the computer will load Win10 but will restart a few seconds later after logged on (random time).
There's no blue screen or nothing else, the pc just shutdown (cooler stops) and restart.
I've tried upgrading to the latest beta bios 7C83v151(Beta version) (2020-12-15), and also with the latest stable 7C83v14.
I've tried multiple memory configuration presets (including all the "Try it" templates for 2666 MHz memory).
I've tried switching slots, and also tried using the secondary memory slots DIMMA1 and DIMMB1.
The CPU i'm using is also on the QVL.
It's a Intel® Core™ i9-10900 Processor (BX8070110900)
How do i fix diagnose or fix this?
